224 user(s) are online (174 user(s) are browsing Forums)
sgin flip up headlights
5 Posts
Hey everyone,
I'm new to the forum and really need some help. My 92 headlights when turned to off retract properly but seem to pulse like they are not fully up or down. Is there a limit switch that needs adjusting ? i have to disconnect because it drains battery.
Posted on: 2011/5/22 0:00
Stl94LT1 Re: flip up headlights
128 Posts
Sounds like bad headlight bushings.
Posted on: 2011/5/22 0:21
sgin Re: flip up headlights
5 Posts
not sure what you mean about a headlight bushing ?
Posted on: 2011/5/22 0:27
bogus Re: flip up headlights
Inside the electric motor assembly is a gear box. That gear box has these cute little delrin bushings. Over time, the delrin gets beat to death and turn to powder.
These need to be replaced.
The parts are about $10, the labour, tho, is annoying.
Posted on: 2011/5/22 0:30
128 Posts
Posted on: 2011/5/22 0:32
5 Posts
do i understand this right ? the bushings are shot therefore any limit sensor/switch is not getting correct reading ? where can i get the bushings ?
Posted on: 2011/5/22 0:34
128 Posts
I recently replaced my headlight bushing with Home Depot nylon bushings. They are located in the Hardware section in the drawers with specialty bolts/bushings. For less than $2 you can get enough bushings (6) to do both sides.
It was easier for me to remove the entire headlight assembly to do the repair.
Crown Bolt brand
27/64 long
29/64 OD
SKU # 3069987278
Posted on: 2011/5/22 0:47
Pretty much, yes. These bushings are in them selves something of a limiter.
You can get them from Ecklers.
You should get a Helm Factory Service manual for it, www.helminc.com or eBay.
I just unassed the $37.00 to find out how good it is:
http://cgi.ebay.com/ebaymotors/1992-C ... ature&hash=item56433d5cd2
That is a CD with the manual on it... if this works out, I will be buying these for my library and not books! I see another advantage - not having to scan pages to share info.
And no lost pages.
Posted on: 2011/5/22 0:50
5 Posts
hey guys thanks a lot. i think i will pull the motor apart and check out the bushings. and home depot is up the block.. thanks
Posted on: 2011/5/22 1:01
You won't find the bushings at HD! If you do, let me know.
Again, check Ecklers, they are not expensive and they include instructions.
This will help: http://www.vetteweb.com/tech/vemp_090 ... lamp_motors/photo_01.html
Posted on: 2011/5/22 18:13
1Fast04Vert Re: flip up headlights
They are the same bushings that Ford used in their power windows for years, every auto parts store should have them.
Posted on: 2011/5/22 19:39
128 Posts
Bogus, first picture is from your article. Second pic is the Home Depot bushings. They are a bit different, but for ~25 cents/each you can't beat the price and they have a pretty good track record.
Posted on: 2011/5/22 19:56
pianoguy Re: flip up headlights
And no lost pages.
Awesome - I just ordered one, too! Never saw those before.
Posted on: 2011/5/22 19:57
128 Posts
One of my headlight motors still had the bushings intact, and they looked almost exactly like the ones you are refering to. They were about $9 per side.
I never considered looking for alternatives to the bushings. This is one of those things I do once... and if the new ones are that great, that's it!
Good shopping!
Posted on: 2011/5/22 20:02
128 Posts
Bogus, I can't take credit for the HD bushings. Read about them on another thread.
Posted on: 2011/5/22 20:03
BillH Re: flip up headlights
/files/1/5/4/6/6/img_0088__medium.jpg[/img]
Yep, I have a couple sets of those in my "new spare parts" box. Bought them about 4 years ago.
Posted on: 2011/5/22 21:52
