197 user(s) are online (110 user(s) are browsing Forums)
84bluec4 Spare Tire Sellers
Grass Lake, Michigan 49240
65 Posts
I took a look at the spare tire under the car today and yep, its flat! Upon further checking, it appears to be the original 1984 spare tire! I checked Tire Rack to see if I could order a t155/80/d16 and nothing shows up on the website.
Does anyone have a recommendation where to buy one?
How much do space saver tires go for?
Thanks
Mark
Posted on: 2011/6/4 23:44
M Moore
1984 Lt blue/Med blue, z51, automatic, 3.07
350 crossfire
blue cloth interior, Bose stereo,
everything still stock (for now)
josephf31 Re: Spare Tire Sellers
New Jersey
375 Posts
Thanks
Mark
If it doesn't have to be brand new (heck when is the last time you actually used your spare)? I would try one of the parts resellers, like my favorite www.vette2vette.com.
Joe
Posted on: 2011/6/4 23:54
Matatk Re: Spare Tire Sellers
22810 Posts
I've heard of guys using either the newer GTO spares or 4th gen camaro spares as they supposedly fit. Apparently some newer import model spares with the same bolt pattern fit, too.
Posted on: 2011/6/5 12:48
SpectatorRacing Re: Spare Tire Sellers
I have mine sitting in the garage where it's been for many years. If you ever get to the Detroit area it's yours...I dunno, $50, rim and all?
Posted on: 2011/6/5 13:45
vette079 Re: Spare Tire Sellers
svenljunga
15 Posts
Hm, wouldn´t it be enough with only a new tire, you don´t have to buy the whole thing new, would ya...?
Posted on: 2011/6/13 18:45
bogus Re: Spare Tire Sellers
There isn't much of a market for these things.
Do this, put air back in it, soak it in armor all tire dressing and that should be enough.
IF you ever need it, you won't drive more than 30 miles on it.
Posted on: 2011/6/14 6:03
RickAnthony Re: Spare Tire Sellers
ASE Master Certified
Downers Grove, IL
703 Posts
I have to respectfully disagree.. if the tire is all cracked ect.. you could risk a blow out ect.. you never know the situation you might be in when you need to use the spare, so if one is worried about it then get one, if one doesn't care ride at your own risk....
a 84' that tire is pretty old....
Posted on: 2011/6/15 0:40
My Automotive Blog
CORVETTE SERVICE & REPAIR
RickAnthonyMotorsports.NET
New Jersey
375 Posts
or one could always carry a can of that fix a flat stuff -- I know it doesn't do good things for your tires, but in a pinch hey...
or you pull a Mythbusters and use a manhole cover LOL
Posted on: 2011/6/15 2:04
22810 Posts
I don't know if you could find just the spare tire without a rim, but you could try.
Posted on: 2011/6/15 2:39
My point is that they are prone to failure even when new!!!
Posted on: 2011/6/15 4:57
svenljunga
15 Posts
Has one ever measured how much space there is in the spare tire holder, you might be able to fit a wider tire and rim in there.
Not original, but maybe it´s easier to find a 175 tire if it fits in there.
Not sure about the size of the rim, but maybe it fits a wider tire than a 155.
Just a thought.
Posted on: 2011/6/16 8:19
