288 user(s) are online (179 user(s) are browsing Forums)
76Nordic Headliner opinions needed
Dumbass
Brea, CA
239 Posts
I bought the hard plastic, covered headliner from MAM. Today I get home from work, and it is sitting on top of the seats. Seems the glue on the velcro strips basically just gave way. What would your recomendations be to fix this prob? TIA for any replies Mark
Posted on: 2011/6/24 0:26
The Definition of insanity; Doing the same thing over and over again, and expecting different results.....Einstein
hdfire Re: Headliner opinions needed
Crest Hill, IL
48 Posts
I've used 3M 77 adhesive before for upholstery work, it holds up pretty well.
Posted on: 2011/6/24 0:33
76Nordic Re: Headliner opinions needed
Dumbass
Brea, CA
239 Posts
Not familiar with this adhesive, can I get it at a local parts place?
Posted on: 2011/6/24 15:36
1Fast04Vert Re: Headliner opinions needed
I would contact MAM. They should now that the glue on velcro strips will let go when it gets hot, so they should have a fix and not even charge for it. Of course that is just my opinion.
Posted on: 2011/6/24 15:43
BillH Re: Headliner opinions needed
Mark, you can actually get 77 at Home Depot in the paint section. It's decent, I keep a can in the shop.
Make sure you let it skin before attaching the velcro. And I'd clean off the velcro adhesive with some brake clean on a rag before spraying the 3M.
If that fails, 3M makes a hi temp contact cement that's really good but usually has to be internet ordered.
Posted on: 2011/6/24 15:45
Dumbass
Brea, CA
239 Posts
Thanks Guys!! The idea of contacting MAM sounds like a great idea. Will try that first
Posted on: 2011/6/24 15:47
biggrizzly Re: Headliner opinions needed
I just destroyed one of my plexiglass fog/parking light blackouts because the Velcro adhesive let loose when it got to hot. It fell off and I drove over it. Pisses me off, because they don't sell them exactly like the old one's any more.
Posted on: 2011/6/24 16:23
Here are two good articles. I like the first one and plan to do something those lines to mine. I'm just not sure what design to emboss on the surface.
http://www.corvettefever.com/techarti ... replacement/photo_01.html
http://www.mamotorworks.com/pressreleases/pdf/2006/10013.pdf
Posted on: 2011/6/24 17:58
Fredbird Re: Headliner opinions needed
San Antonio, Texas
103 Posts
I've used the 3M 77 on an old 1982 Chevrolet S-10 headliner I fixed up in high school as a low rider. Worked Great! never fell back down all the time I owned it. (1993 - 1998) I've also used it on some problematic Sun Visors on another car. In fact, I'll be using it soon to repair my sunvisors in my 1991 Corvette. It's designed exactly for this type of application.
Just remember to shake well and apply to both surfaces. Don't get it so wet that it soaks through. A good light-med. layer is enough (Depending on the weight and how porrus the headliner will be.)
Posted on: 2011/6/24 23:45
Dumbass
Brea, CA
239 Posts
Thanks for all the info guys! I am still going to try MAM on monday first, seeing as I haven't had it all that long, maybe a warranty type fix? Ya I know, dreaming. Definately going to homo depot to get the 77 anyway. Have the carpet on the doors starting to sag, and will try it on those. Thanks again guys Mark
Posted on: 2011/6/25 0:22
Jeffvette Re: Headliner opinions needed
I've got mine to replace as well, lost the headliner after shooting up to 120 with the windows down.
I bought some Alcantara to use as my material. Just need to sit down and cut the template and glue it in.
Posted on: 2011/6/25 18:47
Dumbass
Brea, CA
239 Posts
Bit of a thread jack, but Jeffvette was it you that I talked to about a stereo you were selling? I know I was talking to someone..brainfart on my end
Posted on: 2011/6/25 19:36
Sorry, wasn't me on the radio. Got your PM, I'll get your parts out to you when I get back home.
Posted on: 2011/6/26 16:45
Dumbass
Brea, CA
239 Posts
Thanks Jeff, let me know what I owe ya
Posted on: 2011/6/28 0:20
movnviolation Re: Headliner opinions needed
Hesperia, Calif
188 Posts
Took my top to a auto upholsterer and left it. he replaced the old with a new black headliner that looks better than the original one ever did.
Cost was $100.00. No muss, no fuss!
Posted on: 2011/6/28 2:45
Mods
JrRifleCoach Re: Headliner opinions needed
1524 Posts
Posted on: 2011/7/2 0:24
