197 user(s) are online (165 user(s) are browsing Forums)
DUBIE Service engine light
NY
33 Posts
I get a service engine light come on almost exactly at the same point along a certain route, on a highway just starting up a grade---it checks out as a code 32---i do not notice any change in performance and if I stop and shutoff the engine and restart the light remains off for the rest of the trip. Does not come on around town. It's a 91 L-98. Any ideas--anybody know the primary cause of a code 32-EGR??
Posted on: 2007/2/8 16:58
bogus RE:Service engine light
you need a new EGR valve.
Posted on: 2007/2/11 22:25
DUBIE RE:Service engine light
NY
33 Posts
Thanks---That was easy enough!!!!
Posted on: 2007/2/12 23:12
runner140 RE:Service engine light
Ft. Lauderdale, Florida
721 Posts
I had that code on my 96'......purchased a new egr valve on ebay for about $40.00 thru "thepartsladi". Its an easy install, 15-20 minutes tops.
Posted on: 2008/1/28 20:25
It's a lot harder on an L98...
Posted on: 2008/1/28 20:43
MK 82 RE:Service engine light
Palm Beach Gardens, FL
439 Posts
It's the round device between the fuel rails.
Posted on: 2008/1/28 22:57
96 CE Roadster LT4
CentralCoaster RE:Service engine light
If its EGR, give yourself about 2 hours to be safe. Lots of b.s. stuff to remove to get to it.
Actually you can probably save a lot of time by not removing the runners.
Posted on: 2008/1/28 23:23
CFI-EFI RE:Service engine light
Top of Utah
372 Posts
Bad advice. That is the typical, "Shoot the messenger" mentality.
More often than not a code 32 is NOT cured by the replacement of
the EGR valve. Follow the trouble shooting steps in your FSM for a code 32,
and save yourself from throwing money at the problem. It is possible that
in your case you really do need a new EGR, but wouldn't you rather know,
before you waste your time and money?
RACE ON!!!
Posted on: 2008/1/29 0:50
Top of Utah
372 Posts
It's the round device between the fuel rails.]
Is it really necessary to stretch this whole thread with a 1024 pixel wide
picture of an EGR valve?
RACE ON!!!
Posted on: 2008/1/29 0:59
RACE ON!!!
I think I might leave it that way too since you didn't ask nicely. :tongue:
Posted on: 2008/1/29 2:58
RACE ON!!!
Normally, I would agree with you. But by 1991, the ECU had gotten smart enough to diagnose the EGR switch.
When the engine is keyed on, the ECU goes through a POST. That test will check for a problem with the switch. If the SES fires with a EGR code, then you know WHY the code has fired. If it happens at start up, it's the switch, if it happens after a drive, then it's the valve.
Now, with all of that said, I should have included an inspection of the vacuum lines, but gee, those are such a bitch to reach on the L98, you have to go through the same process to check them as you do to replace the damned valve!
Posted on: 2008/1/29 3:24
Nah, you can change all the vacuum lines out without pulling anything apart, I've done in on a few L98s. There's a few HVAC lines and a cruise control line that are a bitch, but otherwise it's easy.
Posted on: 2008/1/29 3:59
Subman RE:Service engine light
WHITTIER, CA
35 Posts
I can only speak from my expereince, so here's what's up with the above.
The SES light would come on after 4-5 minutes of driving at somewhat consistent speed (freeway driving). After clearing the code, driving back and forth the 7 minutes to the office, no SES. Back on the freeway, 4-5 minutes, SES. Having gone through the FSM tests and then some, I found the EGR valve was good (held vacuum for longer than required), the vacuum lines held required vaccum, checked the 2 electrical wires to the EGR vacuum solenoid all the way back to the ECM, finally re-read all the instructions again and found the solenoid did not preform as it was supposed to.
Now the down side is - - find a EGR vacuum solenoid - I have spent hours with the local a/p stores and their warehouses - there is another post regarding this - Standard is still up in the air if they are going to manufacture again, B/W is out of stock on the part number, as is Blue Streak and AC - J&D, if they have a used one, is "somewhere around $125.00".
All that said, re-read the FSM and all the test proceedures before throwing $ and time only to find the valve was ok and it's the ECM or the solenoid or a broken wire that's the culprit.
Good luck
Subman
Posted on: 2008/1/29 6:08
interesting. I thought the 90 ECU was smart enough to find that.
I know the 92 is and I woulda sworn I had read that the 90 did the same thing.
I will check...
Posted on: 2008/1/29 6:19
Top of Utah
372 Posts
RACE ON!!!
I wasn't talking to you. I was addressing the inconsiderate boob that posted it.
RACE ON!!!
Posted on: 2008/1/29 16:41
Top of Utah
372 Posts
find that.
thing.
I will check...
At least he'll end up with a new EGR valve, whether he needed it
or not. Let's hear it for throwing money at the problem. Any problem.
Only fools waste time diagnosing problems.
RACE ON!!!
Posted on: 2008/1/29 16:45
439 Posts
Fixed it. Didn't have my pixel ruler handy!
Posted on: 2008/1/29 16:54
96 CE Roadster LT4
439 Posts
[/quote]I wasn't talking to you. I was addressing the inconsiderate boob that posted it.
RACE ON!!![/quote]
You are a piece of work. Who pissed in your corn flakes today
Posted on: 2008/1/29 16:58
96 CE Roadster LT4
Top of Utah
372 Posts
What did you do? Lose your right mouse button? (Right click, then select "properties" to check the pixel size). You couldn't SEE how that impossibly and unnecessarily wide picture made you pan across the screen to read a post?
Apparently you missed the multi-day global discussion that has been taking place over picture size. Pass your corn flakes this way. I'll fix 'em up for you.
RACE ON!!!
Posted on: 2008/1/30 1:02
439 Posts
RACE ON!!!
Somehow I imagine you as a small, shriveled little man hiding behind his keyboard and passing out insults to the unwashed, ignorant masses. You are not worth my time.
Posted on: 2008/1/30 1:57
96 CE Roadster LT4
Whoa guys hold back on all the lovin'.
Posted on: 2008/1/30 1:59
dan0617 RE:Service engine light
Good luck
Subman
So, did you get a new or used solenoid? Are you running your car with the SES light on? What was your fix?
Posted on: 2008/1/30 2:06
Posted on: 2008/1/30 2:10
Oaklands RE:Service engine light
Morristown, TN
480 Posts
In dis corner weighing in at 218lbs fighting out of.......
Have fun, don't fight!
Posted on: 2008/1/30 4:44
I booted CFI and Droptop from posting anymore in this thread, doesn't look like they have much more to say on the EGR issue.
Posted on: 2008/1/30 7:16
WHITTIER, CA
35 Posts
Still searching for the part. Since the SES doesn't come on during the drive to work, I cleared the code and drive on. Hopefully, some mom & pop a/p store has one sitting on a shelf collection dust somewhere.
Good Luck
Subman
Posted on: 2008/1/30 12:06
I think I have a used one. Is it the part that was held to the intake by one of the waterneck bolts? If so, I have one from an '89 L98 vette. I'll take a pic of the part and email it to you. If it is what you are looking for, I'll ship it to you. If it solves your problem then send me a paypal or money order for $25. If it doesn't solve your problem ship it back to me. If it doesn't work (it worked when removed, I think, I had no problems or ses light) just throw it away and let me know it was bad. PM me your email address if you are interested and I'll email you the pics of it.
Posted on: 2008/1/30 21:07
