179 user(s) are online (66 user(s) are browsing Forums)
BrianCunningham [update] this should keep it cool
oil cooler accusump & filter where the spare used to be
Photobucket
installed w fan and LARGE filter
radiator needed to come back out.
4in intake blocked one of the radiator opennings
new neck welded on an reinstalled
Exotic Muscle long tube headers fit no problem
Posted on: 2011/5/30 21:42
bogus Re: [update] this should keep it cool
20878 Posts
this is gonna be one sick SOB! Impressive!
Posted on: 2011/5/30 22:30
pianoguy Re: [update] this should keep it cool
Rawk!
Posted on: 2011/5/31 0:21
FICINJECTORS Re: [update] this should keep it cool
Gold Sponsor Vendor
117 Posts
Outstanding!!!
Posted on: 2011/5/31 1:18
flyboy Re: [update] this should keep it cool
Cooler than dang it!
Posted on: 2011/5/31 1:59
SpectatorRacing Re: [update] this should keep it cool
Nice...so are you close to driving it?
What's the plan for getting air across the oil cooler, some fans?
Posted on: 2011/5/31 13:04
BrianCunningham Re: [update] this should keep it cool
Just some minor things left, lengthening wires etc
There's a 1300cfm fan on it
I'll take a better pic later
Posted on: 2011/5/31 16:41
biggrizzly Re: [update] this should keep it cool
Brian -- Very impressive! I thought about an oil cooler too, but I just don't know if I really plan on tracking this car or not. I know I will do some Autocross with my club, probably 6-10 events per season. But I sure like the set-up you have. Nice big cooler too! Are you putting a fan on the cooler?
Posted on: 2011/5/31 18:49
Don, be reminded that power makes heat. I didn't have to worry about temps until I did my first rebuild. Blew it up the first time on track because I added 100 horse power and no cooling power.
I'm not saying you will need it, but be aware that you certainly might.
Posted on: 2011/5/31 20:32
Matatk Re: [update] this should keep it cool
22959 Posts
Looks impressive! Are you concerned about possible damage to the cooler due to road debris?
Posted on: 2011/6/2 2:07
Not really I've seen them mounted there on racecars
Posted on: 2011/6/2 16:15
I put mine here, but I think that's where the cruise control bubble and AIR were.
jpg  IMG_1949.JPG (0.00 KB)
Posted on: 2011/6/2 20:44
Not bad, I'm reserving that area, and it's twin, in case I need and intercooler in the future.
Posted on: 2011/6/5 20:37
BV85 Re: [update] this should keep it cool
12 Posts
Brian this is BV85. Where did you get those protective pieces to keep the heat off the floorboardes. They have a blue sticker on them. TIA
Posted on: 2011/7/2 5:20
Update - had trouble keeping the oil cool in this location. I think it would be fine for the intercooler, but the extra power seems to need more flow. I put the cooler back in front of the radiator. I may buy a fancy expensive cooler and try here again, but it's working now so who knows...
Such a nice bracket going to waste.
Posted on: 2011/7/2 14:16
20878 Posts
The Corvette Racing C5R and C6.r use the rear license plate area for a cooler - but that's for the trans and diff assembly.
First thought, that's a lot of line to run for the oil... and 2nd, if you flush mount it, how will it get airflow?
Posted on: 2011/7/2 15:00
Airflow restricted, only way to package it w/o cutting a hole in the bumper, but I got a large fan on it.
Heat is what kills FI engines, so getting all that heat out of the engine compartment seemed to be the way to go.
Posted on: 2011/7/2 17:58
