171 user(s) are online (110 user(s) are browsing Forums)
djxib Single mass flywheel w/unsprung clutch hub
North Georgia
456 Posts
I just received my Spec stage 3+ clutch and the clutch disk hub is unsprung. I spoke to LMPerformance (Spec) and they told me that it is designed with a solid hub (contrary to the description on their website).
My 1992 LT1 has a single mass flywheel, which is why I ordered the Spec.
I'm kind of OK with having an unsprung hub / single mass flywheel, but wanted some opinions on street drivability before I decide whether to install the clutch or maybe shop around for a sprung version.
Posted on: 2011/7/21 20:54
Andy
89Vette Re: Single mass flywheel w/unsprung clutch hub
135 Posts
The only guy who I read about installing a SMF and unsprung clutch ended up converting to an automatic transmission. That's because he HATED the driveability and noise.
Posted on: 2011/7/21 21:26
rklessdriver Re: Single mass flywheel w/unsprung clutch hub
The Stage 3+ is crap load of clutch.
All of the Stage 3+ I have seen were sprung hub. The Stage 4 is solid hub but it's a puck style. Maybe you got a clutch set up for the Dual Mass FW??
I run the regular Stage 3 (sprung disk 6 puck) and it hit's so hard (if I just dump it) that I can explode the rear end at will. Took me a few tries to learn how to launch the car without destroying stuff (wa an expensive learning curve).
I would not run an unsprung disk with a Single Mass FW.
Posted on: 2011/7/21 21:32
SJW Re: Single mass flywheel w/unsprung clutch hub
Central Maryland
51 Posts
I can't speak from personal experience (I'm running a sprung-hub Stage 2 Spec clutch with their extra-weight billet steel SMF in my '94), so I can't comment on driveabilty issues, but I would be very wary of installing a solid-hub clutch disc in a car with a SMF. Those hub springs help to soften driveline shock, and without them, or the springs in a DMF, I'd be worried about grenading gearboxes, D44s, driveshafts and halfshafts.
Did Spec recommend you go ahead and install that solid-hub disc with your SMF?
Live well,
SJW
Edit: Looks like the previous reply got there while I was typing mine. So... What he said!
Live well,
SJW
Posted on: 2011/7/21 21:33
bogus Re: Single mass flywheel w/unsprung clutch hub
20860 Posts
it won't be fun.
Posted on: 2011/7/21 21:37
BrianCunningham Re: Single mass flywheel w/unsprung clutch hub
this is for the YSI install?
you kind of limited to what's going to be able to hold that puppy.
that's the reason I went with the dual disk, which is also going to be grabby.
I'm less worry about that, more worried about the shock to the drivetrain.
Posted on: 2011/7/21 21:50
djxib Re: Single mass flywheel w/unsprung clutch hub
North Georgia
456 Posts
SJW
Initially, yes, but they are going to go check.
Posted on: 2011/7/21 22:13
Andy
North Georgia
456 Posts
Yes - for the YSi install.
I'm also concerned about the drivetrain, but I have some experience with race clutches and feel confident that I could control the launch with a bit of slip/higher revs.
I'm going to wait on Spec, but at this point I am planning to agree/return the clutch for a sprung hub unit.
Posted on: 2011/7/21 22:16
Andy
