270 user(s) are online (197 user(s) are browsing Forums)
NC Kid Injectors tick
North Carolina
1671 Posts
I was wondering this. I read that sometimes injectors tick. I think mine are ticking. I tried using a piece of tubing to locate the ticking but the sound hurts my ears being that close with a tube in my ear. Would my stock injectors be prone to ticking?
Posted on: 2008/1/28 20:41
bogus RE:Injectors tick
yes. they all are.
Posted on: 2008/1/28 20:58
NC Kid RE:Injectors tick
North Carolina
1671 Posts
What about the Ford SVO injectors? I heard they are good....Why do injectors tick? Is it a sign of failure?
Thanks...
Posted on: 2008/1/28 22:58
CentralCoaster RE:Injectors tick
It helps if they aren't bottommed out in the rail or base. The clips help prevent this.
Do you have the stock intake base and injectors? Have they or the fuel rail ever been removed?
Posted on: 2008/1/28 23:24
North Carolina
1671 Posts
Everything is stock to my knowledge. I had a intake manifold gasket replaced awhile back...I also had my heads checked because I thought it was either that or a blown head gasket but they were ticking before then so I don't know beyond that...At first I thought it was a lifter or something, because our old jeep had a ticking sound and another mechanic said it was a bad lifter...My oil is changed regularly so... It's just really annoying.
Posted on: 2008/1/28 23:41
cuisinartvette RE:Injectors tick
with the others dont sweat it.
Posted on: 2008/1/29 0:12
Jer RE:Injectors tick
24 Posts
I replaced mine with new Ford pink injectors not too long ago and they tick pretty loud. Heard this is just normal. Car runs great.
Posted on: 2008/1/29 0:30
CFI-EFI RE:Injectors tick
Top of Utah
372 Posts
An injector is a solenoid. Just like the solenoid in your starter. When the ECM energizes the injector the coil of wire along with it's movable ferris core becomes an electromagnet, and pulls the core out of it's at rest position. That ferris core is the pintle. It is opened as described by the ECM and allowed to seat under spring pressure when the coil is de-energized. Noise is a natural byproduct of the pintle seating.
RACE ON!!!
Posted on: 2008/1/29 0:36
North Carolina
1671 Posts
RACE ON!!!
Sjeez, that sucks...
Posted on: 2008/1/29 0:40
dan0617 RE:Injectors tick
Ticking sucks but the description is perfect. I always wondered how.....and what....with injectors. Now I knoooooow. Thanks CFI.
Posted on: 2008/1/29 1:59
Top of Utah
372 Posts
An amazing and versatile device, the solenoid. Wait until the camshaft is replaced by solenoids, one for each valve. You will be able adjust your duration, lobe centers, overlap, etc, by programming with your laptop. You will be able to have short duration for strong low rpm torque, gradually blend into a wild, long duration, grind for all out top end power. It will be the ultimate variable valve timing device.
RACE ON!!!
Posted on: 2008/1/29 2:14
Havent' they already done this on a production car? Electronic valves?
Posted on: 2008/1/29 3:00
Lichen RE:Injectors tick
Scottsdale, Arizona
166 Posts
I figure that as long as they're ticking, they're working.
Posted on: 2008/1/29 18:40
MK 82 RE:Injectors tick
Palm Beach Gardens, FL
439 Posts
I have to say that your avator is by far the most revolting one I have ever seen. I hope that is not on your body!
Posted on: 2008/1/29 18:49
96 CE Roadster LT4
439 Posts
Careful, you are bordering on insubordination!
Posted on: 2008/1/29 23:30
96 CE Roadster LT4
Top of Utah
372 Posts
Not that I am aware of, but it certainly could be.
RACE ON!!!
Posted on: 2008/1/30 0:15
jsup RE:Injectors tick
1778 Posts
and I don't say that much....
Posted on: 2008/1/30 0:41
Electric/Electronic valves on a production car? Not that I am aware of.
Ford and Renault have been working on them, but they haven't reached production... hell, they aren't even close as of last read. I would also suspect Ferrari to be working on it, too.
F1 is where we would see cam-less engines first... if we ever do. A couple of years ago, before the FIA closed development on F1 engines, Renault was working on a cam-less engine, and the rumours had it spinning upwards of 25k RPM.
Considering that the cammed, but pneumatically controlled valves used in F1 currently will allow the smaller 2.4L V8s spin over 20k RPM (ungoverned), I would expect a cam-less engine to spin higher. Either way, it's sick.
Posted on: 2008/1/30 0:50
RACE ON!!!
Have you ever thought of going farther with that idea? See if it is invented or patented yet, and if not, pursue it yourself? It is a great idea. Sure would take the stress off of having the "perfect" intake runner length and "perfect" head size for the engine and the engine's practical uses. I could tow a camper, then change "modes" and run a drag race.
Posted on: 2008/1/30 0:53
the R&D behind this has been mind boggling. The #1 reason the automakers are pursueing it is for savings... no more starters are needed. They can start the engine by firing off one plug and let the rest follow.
Posted on: 2008/1/30 1:03
Top of Utah
372 Posts
I only WISH I could take credit for the idea. It may take a while, but you'll see it. The concept has been around for ages. I also have a mental picture for a desmodromic valve system. Born 30 years too late.
RACE ON!!!
Posted on: 2008/1/30 1:14
Top of Utah
372 Posts
There is more than just cost savings involved. Think of the fuel mileage of an engine that is constantly running in it's most efficient, "sweet spot". With a "cam" timed for the conditions, the emissions could be incredibly low, also.
RACE ON!!!
Posted on: 2008/1/30 1:22
And here, I was only thinking of more power. What is wrong with me? I guess I've got it bad.
Posted on: 2008/1/30 1:29
Top of Utah
372 Posts
[quote]And here, I was only thinking of more power. What is wrong with me? :tard]Me too! And the potential for great power is there, but if you are going to get the automotive manufacturing giants of their dead and dying... to develop something, there had better be a bigger motivation than a bunch of hot rodders. Something like the EPA???
RACE ON!!!
Posted on: 2008/1/30 1:37
EPA? OOH, that's right. Stands for Enough Pollution Already!!
Posted on: 2008/1/30 1:38
I know this is getting way off the topic of the thread, but not a day goes by that I don't think of how long our earth's oil supply can last. Look at the trucks and cars and equipment running in 1 town or on 1 interstate, then think of the size of the earth. It is amazing we haven't already ran out. Anything to save gas on a large scale would be good. Alternative fuels are a must for our generation. My company mandates that I drive a 3/4 ton truck, then they reimburse me for it and for my fuel. It makes me sick that 1/2 the time I could drive something and get 30mpg, but they make me run my truck and get 13. I drive nearly 60,000 miles a year on average. It makes me sick thinking of all the gas I waste because they won't reimburse me unless I run the vehicle they want me to run. I know there are many days I need the truck but on the days I don't it is such a waste!
Posted on: 2008/1/30 1:43
