241 user(s) are online (185 user(s) are browsing Forums)
Does it work?
vetteblondie Headlight jigglies, dash text and stall....
Jonesboro, AR
4652 Posts
Just a few things with this 'new to me' '02....
The passenger side headlight jiggles. Body shop friend has messed with it and thinks I'll need a new assembly or whatever in there. Seriously? There a way to fix that for now?
Also, on the dash when you start the car, his '06 lets him program what it says, but mine only says 'Corvette by Chevrolet' or something like that. Can I change it?
And, there's been a cam added (288/588) but stock stall left. Suggestions?
Posted on: 2011/8/9 19:43
�Ugol's Law
1Fast04Vert Re: Headlight jigglies, dash text and stall....
This threasd from CF might help on the HL issue, particularly response #17:
http://forums.corvetteforum.com/c5-te ... -shakes-will-driving.html
Depending upon the lope in the cam the stock convertor might be OK.
Posted on: 2011/8/9 20:16
Ultraman Re: Headlight jigglies, dash text and stall....
14746 Posts
I'm just learning about the C5 also.....here is a site that has some info on the issues you asking about.
http://www.corvette-web-central.com/C5repair.html
Posted on: 2011/8/9 21:03
BrianCunningham Re: Headlight jigglies, dash text and stall....
the bushings in the assembly are probably shot.
not sure if you can buy new ones
the motors? sure
the assembly? not so much
Posted on: 2011/8/9 21:36
14746 Posts
I have looked and I don't think you can reprogram the start up wording on a C5. TB might know I'm thinking. How does the car drive and run down the road?
Posted on: 2011/8/9 22:00
vetteblondie Re: Headlight jigglies, dash text and stall....
Jonesboro, AR
4652 Posts
The car runs good, very different from what I 'm used to. The faster I go the lighter it feels. In the C4, the faster I went the more it seemed to squat and grab the pavement. Cornering is different as well. The cam is nice, but it does need that low end. It's supposed to get tuned sometime in the next few days. Getting the seat rebuilt this week. Also, got a "kit" that's supposed to fix that seat 'sliding' issue I've heard about from others. We'll see if that works.
Posted on: 2011/8/9 23:30
�Ugol's Law
BillH Re: Headlight jigglies, dash text and stall....
That was introduced on the 2005's, Letty.
At least it doesn't say "Buckle Your Seatbelt" .
Posted on: 2011/8/10 12:47
14746 Posts
Ah geez, I guess I hadn't heard about a seat sliding issue on these cars....Mine don't but they may have been worked on already. I am sure a little old man owned my car and only drove it to church and back....hmmmmm..he must have gone to church a lot because the car had 75K on it when he got his new one....
According to the car fax I got with the car at 26K the Body Control Module was replaced and replaced again at 28K miles. That was all on warranty but I think the module cost 1300 bucks.....now I just need to figure out what that module does.....
Posted on: 2011/8/10 13:11
Jonesboro, AR
4652 Posts
damn, I want to change mine. Surely there's a way to hack that.
I've heard about the seat sliding issue from a few people and supposedly there was a warranty fix for it, not sure. A friend has a Z06 and his is doing it also.
Posted on: 2011/8/10 13:34
�Ugol's Law
bogus Re: Headlight jigglies, dash text and stall....
You can get the Helm manual for these things off ebay for chump change. It's all on a DVD now! Like $30 for 1998-2010.
Congrats on the new ride! I hope it works out for you. My biggest fear of the C5 is all the modules that can pop... and cost... same rules apply, make sure grounds are good and clean!
Posted on: 2011/8/10 15:07
14746 Posts
Yes they are starting to get older and racking up some miles so maybe more and more issues will come to light. Overall I think they have been dependable to this point.
I did learn that the dreaded Column Lock issues do not involve cars made from 2001 to 2004.
Posted on: 2011/8/10 15:22
volzfan Re: Headlight jigglies, dash text and stall....
Kingsport, TN
306 Posts
The seat rocking issue is common, both my seats were that way at 56k miles. There are kits available with nylon washers to fix them, or you can do like I did and buy some nylon washers at Lowes and make them square to fit. I think there is a pictorial how to online somewhere.....I remember seeing it. Anyway, if anyone decides to do it themselves, let me know and I'll tell you the steps as I remember them. We (Trae and I) did mine in a couple hours.
And the Column Lock thing, in my experienced opinion, is not nearly the terrible problem that one would think by reading threads on the CF. Teebee helped point me in the right direction when I had issues with mine, and as it turned out, the only issue I had was trying to avoid the problem!
Enjoy the new ride......and let's see some pics!
Posted on: 2011/8/10 23:54
Vettes of the Smokies
Jonesboro, AR
4652 Posts
Here ya go:
jpg  car1.jpg (82.39 KB)
619_4e43281d34cf8.jpg 900X408 px
jpg  car2.jpg (70.59 KB)
619_4e432829bdccd.jpg 900X504 px
jpg  car3.jpg (72.83 KB)
619_4e43283608372.jpg 750X835 px
jpg  car4.jpg (66.97 KB)
619_4e4328423b859.jpg 900X411 px
Posted on: 2011/8/11 0:54
�Ugol's Law
Lookin' good, Letty.
Posted on: 2011/8/11 12:44
biggrizzly Re: Headlight jigglies, dash text and stall....
I like the custom body panels and the roll bar! I'd set that bad boy up for autocross!
Posted on: 2011/8/11 12:49
14746 Posts
That car is bad ass and I think it goes well with your hair......mmmmmmm just saying.....
Posted on: 2011/8/11 13:11
Kingsport, TN
306 Posts
Very, very nice.....I especially like the color! :tongue:
Posted on: 2011/8/11 16:01
Trae1976 Re: Headlight jigglies, dash text and stall....
Johnson City, TN
832 Posts
I really like the Tigershark treatment. Very nice!
Posted on: 2011/8/11 22:44
Jonesboro, AR
4652 Posts
Thank y'all
This one's gotta do me a while, come January, I'll have had the '96 for 12 years. It's time for something else.
Posted on: 2011/8/12 2:00
�Ugol's Law
