234 user(s) are online (95 user(s) are browsing Forums)
1st Gear: 3.06
2nd Gear: 1.62
4th Gear: 0.70
Reverse: 2.29
bogus Starter?
20861 Posts
Yesterday, my 92 decided to not start... To make matters worse, all my tools are at our new house!!!
It won't crank... Turn key click. 12.1 volts.
Tried to jump it 13.9 volts. Still just a click and nothing...
I am thinking starter is bad... Thoughts?
Posted on: 2011/8/18 14:54
biggrizzly Re: Starter?
Same thing happened to mine a couple years ago. I blamed the battery. Went bought a new battery, same thing. Replaced the + cable. No help. New starter fixed it. Fairly easy job. Just don't let it hit you on the head on the way down. Ouch!
Posted on: 2011/8/18 15:20
captmike13 Re: Starter?
Hillsboro Mo
2166 Posts
That sure sounds like a starter. Could be the solenoid. When mine went bad that is what it did. Click but no crank. Replaced solenoid and all has been well since. You could bench test it with a battery charger and put power directly to the starter and bypass the solenoid. If starter turns you found the problem. It is really tough to test on the car.
Posted on: 2011/8/18 15:22
13 GMC 3500 dually
captmike13@yahoo.com
BillH Re: Starter?
Possible solenoid, not strong enough to overcome the spring.
Also possible, bad contact - brushes to starter or one bad pad on the armature not letting current flow.
Smack it with a hammer & try again.
Posted on: 2011/8/18 15:32
Matatk Re: Starter?
22812 Posts
I'd rap on it with a hammer/wrench and see if it goes. Sounds like a starter solenoid to me.
Posted on: 2011/8/18 15:41
bogus Re: Starter?
20861 Posts
Don't really have time to be fancy... Off to get a starter...
Posted on: 2011/8/18 16:24
istter1 Re: Starter?
Bakersfield Ca
2336 Posts
I agree gota get it running it is something simple.
Steve
Posted on: 2011/8/18 16:35
flyboy Re: Starter?
Just had the starter shield off on my '91 Caprice to do a brake line replace.
First ever look at the terminals on the solenoid.
Corroded?...it's a wonder it started.
Posted on: 2011/8/18 16:55
bogus Re: Starter?
20861 Posts
The starter is a reman from Advance Auto... it's 10 years old.
It still has a warranty, so I may claim in it! Have a spare that way.
The battery is a new (Oct 2010) Optima red top. The cables are new when I did the big engine out 2 years ago.
Posted on: 2011/8/18 18:11
bogus Re: Starter?
20861 Posts
New starter = starting car.
Thanks for the confirmation!
Posted on: 2011/8/18 19:53
BrianCunningham Re: Starter?
I remember you had some really bad oil leaks you fixed.
I had a starter die on me when my rear main seal went.
Yup, soaked in oil
Posted on: 2011/8/18 19:58
bogus Re: Starter?
20861 Posts
Those leaks are long gone. The starter was just old...
Posted on: 2011/8/19 1:37
klkordzi Re: Starter?
Pittsburgh, Penna
152 Posts
Back in the old days before fuel injection and computers the easy test was to turn on the headlights and turn the key. If the lights dimmed it was the battery. If the lights didn't dim, it was the solenoid.
Posted on: 2011/8/20 0:40
bogus Re: Starter?
20861 Posts
That should still work today... Can't see why not.
Posted on: 2011/8/20 2:37
Bakersfield Ca
2336 Posts
Are the starting problems taken care of now? Was the problem the starter?
Steve
Posted on: 2011/8/22 0:44
bogus Re: Starter?
20861 Posts
Starting is fine, thanks! I haven't had a chance to have the old one bugged out yet. I am going to have it locally rebuilt... that way I have a spare.
Posted on: 2011/8/22 4:03
RickAnthony Re: Starter?
ASE Master Certified
Downers Grove, IL
703 Posts
Was having the same problem recently.. after the car sat and cooled you might get the loud click no crank cycle the key a few times, click, click, crank.. if I shut it off after driving it and everything was warm it would crank no problem right away.. replaced the started no more issues..
-=Rick
Posted on: 2011/8/22 4:34
My Automotive Blog
CORVETTE SERVICE & REPAIR
RickAnthonyMotorsports.NET
