djxib | My Blow Off Valve is bigger than yours | ||
....just sayin'
Posted on: 2011/9/18 20:08
Andy 1996 Greenwood Collectors Edition LT4 Previously 1992 Convertible Polo Green. 383 LT1/LT4 forged/balanced. V7-YSi, Alky. 608RWHP... Now sitting at a dismantler with a salvage title. Still runs... |
BrianCunningham | Re: My Blow Off Valve is bigger than yours | ||
Are you running a MAF?
If not, how are you dealing with boost? Stock computer? |
Posted on: 2011/9/18 20:28
1Fast04Vert | Re: My Blow Off Valve is bigger than yours | ||
Sure looks pretty too. You are sure building an awesome vette.
Posted on: 2011/9/18 20:52
djxib | Re: My Blow Off Valve is bigger than yours | ||
Hi Brian, 1992 is a speed density car so no MAF. I deal with boost in the PE vs. RPM tables. Kind of pluses and minuses on a 1992. I'll probably upgrade to a FAST in the spring - all this constant driving/scanning and table adjustments are killing me! |
Posted on: 2011/9/18 21:45
Yeah, knew about the speed density, just wondering if you put a later computer in.
FAST is a nice setup, just need to piggyback the old one in to keep the dash going. worse things than driving a Corvette around Looking forward to seeing what you make |
Posted on: 2011/9/18 22:11
Thanks! |
Posted on: 2011/9/19 1:38
Matatk | Re: My Blow Off Valve is bigger than yours | ||
Out of my league...but wow!
Posted on: 2011/9/19 2:05
mistaben | Re: My Blow Off Valve is bigger than yours | ||
/knowthatfeelbro - lol anyways.... i thought the 92 was an LT1/MAF w/ a SD back up in case of MAF failure? or was that the 94? and btw, your engine looks gorgeous! |
Posted on: 2011/9/19 4:00
AKS_Racing | Re: My Blow Off Valve is bigger than yours | ||
You will be making adjustments with the FAST as well, just easier to adjust. And MUCH more functionality. |
Posted on: 2011/10/1 3:17
Miss Nasty: Bigger SBC with C4SP and just shy of 30 psi boost. Low 9.0s with low 160+MPH with a decent 60' (1.72 is decent for me these days). :thumbleft: |
