317 user(s) are online (274 user(s) are browsing Forums)
The ...
djxib My Blow Off Valve is bigger than yours
North Georgia
456 Posts
....just sayin'
jpg  BOV2.JPG (290.20 KB)
1691_4e764fb6680a1.jpg 765X1024 px
Posted on: 2011/9/18 20:08
Andy
BrianCunningham Re: My Blow Off Valve is bigger than yours
Are you running a MAF?
If not, how are you dealing with boost?
Stock computer?
Posted on: 2011/9/18 20:28
1Fast04Vert Re: My Blow Off Valve is bigger than yours
Sure looks pretty too. You are sure building an awesome vette.
Posted on: 2011/9/18 20:52
djxib Re: My Blow Off Valve is bigger than yours
North Georgia
456 Posts
Stock computer?
Hi Brian, 1992 is a speed density car so no MAF. I deal with boost in the PE vs. RPM tables. Kind of pluses and minuses on a 1992.
I'll probably upgrade to a FAST in the spring - all this constant driving/scanning and table adjustments are killing me!
Posted on: 2011/9/18 21:45
Andy
Yeah, knew about the speed density, just wondering if you put a later computer in.
FAST is a nice setup, just need to piggyback the old one in to keep the dash going.
worse things than driving a Corvette around
Looking forward to seeing what you make
Posted on: 2011/9/18 22:11
North Georgia
456 Posts
Thanks!
Posted on: 2011/9/19 1:38
Andy
Matatk Re: My Blow Off Valve is bigger than yours
Out of my league...but wow!
Posted on: 2011/9/19 2:05
mistaben Re: My Blow Off Valve is bigger than yours
141 Posts
Stock computer?
/knowthatfeelbro - lol
anyways.... i thought the 92 was an LT1/MAF w/ a SD back up in case of MAF failure? or was that the 94?
and btw, your engine looks gorgeous!
Posted on: 2011/9/19 4:00
AKS_Racing Re: My Blow Off Valve is bigger than yours
62 Posts
I'll probably upgrade to a FAST in the spring - all this constant driving/scanning and table adjustments are killing me!all this constant driving/scanning and table adjustments are killing me!
You will be making adjustments with the FAST as well, just easier to adjust. And MUCH more functionality.
Posted on: 2011/10/1 3:17
Miss Nasty: Bigger SBC with C4SP and just shy of 30 psi boost. Low 9.0s with low 160+MPH with a decent 60' (1.72 is decent for me these days). :thumbleft:
