191 user(s) are online (136 user(s) are browsing Forums)
[IMG]http:/...
pappyfreebird 84 ironhead valve cover gaskets
1028 Posts
are they easy to swap out gaskets??? not having car here i cant look..stanard 3fitys were 4 bolts and fairly easy??how bout these vet covers??
Posted on: 2008/1/22 23:26
CFI-EFI Re: 84 ironhead valve cover gaskets
Top of Utah
372 Posts
Capital letters? Punctuation?
stanard 3fitys were
WHAT is that???
The '84 crossfire is a conventional SBC, same as introduced in 1955.
RACE ON!!!
Posted on: 2008/1/22 23:33
CentralCoaster RE:84 ironhead valve cover gaskets
Easy to change, but hard to get them to seal properly without leaking later on.
I've had the best luck with the right stuff and thicker rubber gaskets. But even those start leaking eventually. It's very hard to get a good seal against the rough head surface. Don't tighten the bolts too much.
Someone else suggested using only RTV and no gasket.
Posted on: 2008/1/22 23:36
MK 82 Re: 84 ironhead valve cover gaskets
Palm Beach Gardens, FL
439 Posts
It's just like any stanard 3fity made prior to 1986!
I speak Jive!
Posted on: 2008/1/23 0:23
96 CE Roadster LT4
pappyfreebird RE:84 ironhead valve cover gaskets
1028 Posts
thanks rednecks preciate the input!! do remember mine has rtv stickin out of em ,,,thats why asked...so ifn dry i leave em be...thanks again
ps hey nawt bad you honky white boy drop t wahahahaha!!
Posted on: 2008/1/23 14:04
Z51 RE:84 ironhead valve cover gaskets
OREGON
127 Posts
i've changed mine a couple of times, and first time it took me 9 hours, but now 2 hours tops i can have them swapped out
Posted on: 2008/1/24 0:43
1990 roadster
jhammons01 RE:84 ironhead valve cover gaskets
dammit, I have to do mine one day soon.
Posted on: 2008/1/25 20:27
You said that 6 months ago. I think there's been revolutions that lasted less than that.
Posted on: 2008/1/25 21:12
"They/Them/you" are starting to catch up with my procrastination.
yeah, I've been putting a lot of stuff off. I don't feel bad about it though. I've been busy and the car does run really good. I'd give it a 80%.
Posted on: 2008/1/26 1:46
Sounds good. So if you're driving back from San Bernardino, how long does it take to walk 20% of the way?
Posted on: 2008/1/26 5:37
that made me laugh
Posted on: 2008/1/26 6:02
sprint7677 RE:84 ironhead valve cover gaskets
Oxford, Pa
127 Posts
Not hard to replace, but since I had them off I decided to add 1.6 rockers, and repaint the valve covers. Some silicone on both sides of the gasket and so far no leaks. I did re-tighten two times though. Using Mobile one and no leaks anywhere from the engine.
Posted on: 2008/1/30 3:30
Touringmike RE:84 ironhead valve cover gaskets
Sussex,Wi
569 Posts
9 hours?
Are you talking 'bout an L98?
It's a 30 minute/1 beer job, tops. 8 bolts total.
Posted on: 2008/1/30 18:13
´85 4+3
Oxford, Pa
127 Posts
Only one beer?
Posted on: 2008/1/30 21:40
1984 Corvette mostly stock, many new parts
Sussex,Wi
569 Posts
Only one beer?
Yeah. Dr. says I gotta cut back on the suds.
(I'm allergic to alcohol)
Posted on: 2008/1/31 3:29
´85 4+3
CorvetteArchives RE:84 ironhead valve cover gaskets
65 Posts
I've had good luck with the rubber ones. No leaks for about 5 years and 20K :-) . Got em at Autozone I think
Posted on: 2008/2/4 4:19
