268 user(s) are online (230 user(s) are browsing Forums)
1st Gear: 2.43
2nd Gear: 1.49
4th Gear: 0.75
Reverse: 2.07
Oaklands door sills
Morristown, TN
480 Posts
I have been looking for some door sills to protect the carpet while getting in and out of the car. The only ones I can find cover where your feet come out. Has anyone seen longer ones that would cover where your butt drags across?
I have searched and have not found anything.
Thank you
Posted on: 2008/2/6 3:19
TommyT-Bone RE:door sills
I think ebay has them for $49.95. Ecklers $59.95 and I'm sure they are available elsewhere. Maybe Madvet (Mid America). I have bought two sets. One clear with Corvette written across the length, one black with white lettering. On ebay do a search like (90 Corvette) and all the parts for a 90 will come up along with some accessories too.
Posted on: 2008/2/6 3:28
Oaklands RE:door sills
Morristown, TN
480 Posts
Are these the length of the whole door sill? The ones I have seen aren't long enough to cover where your feet and your butt come out. My carpet has war where the previous owner slid his butt across.
Posted on: 2008/2/6 3:58
I'll give it a close look this morning and let you know.
Posted on: 2008/2/6 10:55
CasetheCorvetteman RE:door sills
Change to 84-87 style sills, they are plastic all the way along with a vinyl insert.
Posted on: 2008/2/6 11:02
Nope they are not full length. Just the foot area like you said. You could get an L shaped piece of stainless or go to your local upholstery shop and have them make you a cover for the area maybe in leather or vinyl to match the seats.
Posted on: 2008/2/6 15:53
Morristown, TN
480 Posts
I may give the upholstery shop a try. It's amazing to me that longer ones are not made. Both 88's I have owned have been worn out by sliding your $ss across them, mine included.
Posted on: 2008/2/6 20:08
sprint7677 RE:door sills
Oxford, Pa
127 Posts
My 84 has a plastic sill with a little pad on it where you slide across, it matches the interior color, I thought it was factory?
Posted on: 2008/2/6 22:07
1984 Corvette mostly stock, many new parts
Morristown, TN
480 Posts
The door sills are apparently different for an 84 vs 88. I don't know if that was an option on yours or not. I do know it is hard to find what I am looking for. I am going to visit a fabricator tomorrow and see if he can come up with something for me in a brushed aluminum finish.
Posted on: 2008/2/7 1:33
Dads90 RE:door sills
Pearland, Tx
318 Posts
My door sill covers arent long enough. I find that spot where I put my hand , climbing in and out, is starting to wear. Or if your hands are dirty they will eventually stain that area.
Posted on: 2008/2/7 5:23
Oxford, Pa
127 Posts
Resized Image[/URL][/img]
Posted on: 2008/2/7 5:39
They are different on 84 to 87, and they will be the answer to your issue.
That is normal on 84-87.
Posted on: 2008/2/7 7:45
Morristown, TN
480 Posts
Case,
Then you are saying they are the same size for an 88. I think I saw a set of these at Eckler's or somewhere. Now I have to find the site.
Thanks.
Posted on: 2008/2/7 14:34
Youll need to modify your carpeted sills, but yes, there is no reason why it wont work like a machine.
Posted on: 2008/2/8 8:09
Morristown, TN
480 Posts
What do you mean modify? Do you mean remove a section of the carpet?
Posted on: 2008/2/8 11:34
Yes mate.
Posted on: 2008/2/8 18:10
kentucky_vetter RE:door sills
somerset, ky
154 Posts
Do what i did, get some .030 stainless sheeting and make your own. Polishes up real pretty !
Posted on: 2008/2/8 18:26
Oxford, Pa
127 Posts
Pic???
Posted on: 2008/2/8 19:51
Morristown, TN
480 Posts
I'd like to see a pic as well and see what it looks like.
Thx
Posted on: 2008/2/8 20:40
somerset, ky
154 Posts
Ill try to post some pics in the morning for you. My drivers side was showing some wear and i got the idea from a pair that Ekclers sells. Theirs are short so i just made a pair to cover the whole length. Resized Image
Posted on: 2008/2/8 20:49
Oxford, Pa
127 Posts
Hey they look great! Nice Job
Posted on: 2008/2/8 21:19
somerset, ky
154 Posts
Those are not mine, those are what ecklers sells. I just took that idea and made a full length set.
Posted on: 2008/2/8 21:21
MK 82 RE:door sills
Palm Beach Gardens, FL
439 Posts
I have the half length ones and have no problems. Maybe a butt reduction is in order!
Posted on: 2008/2/8 22:03
96 CE Roadster LT4
Oxford, Pa
127 Posts
I wonder why the ones for an 84 will not work in an 88?
Posted on: 2008/2/8 23:03
Who said they wont? The sills are exactly the same underneath the sill covers.
Posted on: 2008/2/9 0:36
Oxford, Pa
127 Posts
Then if they found sills out of an 84 - 86 it would fully cover and have a pad for sliding in and out. Keep looking at ebay, it will come up sooner of later
Posted on: 2008/2/9 3:48
84-87 mate yes
Posted on: 2008/2/9 4:16
