187 user(s) are online (159 user(s) are browsing Forums)
bam high volume oil pump or standard?
missouri
250 Posts
Am rebuilding my 93 LT1 engine. Hot cam, new heads (trick flow), bored 30 over. Planning to rev no higher than 6200, opened up the mains and rods to 20 to 25 thou. a stock oil pump should be fine right? Any thoughts?
Posted on: 2012/1/6 16:22
1Fast04Vert Re: high volume oil pump or standard?
Yep. Stock will handle it just fine.
Posted on: 2012/1/6 17:48
rklessdriver Re: high volume oil pump or standard?
Standard volume oil pump will be fine.
Be sure of which pump body you get - Do not buy a Melling M55 without looking at the casting. The Melling Select 57710553 and Milodon 18755 are both good heavy duty castings.
Posted on: 2012/1/6 18:02
bam Re: high volume oil pump or standard?
missouri
250 Posts
I bought a M55 should I just take it back or what should I look for in the casting?
Posted on: 2012/1/6 18:19
vis_croceus Re: high volume oil pump or standard?
VA
260 Posts
Why use a cam that makes it's power outside the range you're willing to rev to?
Why build a new bottom end to a 6200 rpm target that a worn out stock bottom end can handle all day long?
Why use a cam that, 10 years ago, was old tech that was being beaten across the board by other cams?
Sorry if you've already answered these, I don't follow this board closely...
Posted on: 2012/1/6 18:46
94 vert
Lightweight casting on the left. You DO NOT want the lightweight one, they tend to crack and will trash your motor.
Also incase you didn't know.
All the std volume pumps come with a 5/8" inlet, but the stock LTX pump uses a 3/4" inlet - You will need to buy a new pickup tube.
Melling PN 55-S3 is what you need.
Posted on: 2012/1/6 20:53
tjpreul Re: high volume oil pump or standard?
The 3/4" pick up is the M155. Does this one have the same casting problem?
Posted on: 2012/1/6 21:37
Yes - some of the M155's had the lightweight casting as well.
Just look at the bolt pad on whatever you have and compare to the pic.
Posted on: 2012/1/6 22:26
383tpimachine Re: high volume oil pump or standard?
Corpus Christi
976 Posts
At what point is a high volume needed? I will never need the highest end billet but do plan a supercharged 600rwhp setup
Posted on: 2012/1/6 22:39
1970 El Camino-Awaiting LSX
It all depends on demand on the oiling system. Stuff like External coolers, loose brg clearances, piston squirters and spring oilers. Sometimes one of those is enough to require a HV pump - but everything about a racing engine is application specific.
Posted on: 2012/1/7 3:39
missouri
250 Posts
Thanks Will.
Posted on: 2012/1/11 16:33
