175 user(s) are online (112 user(s) are browsing Forums)
wilsonbh Antenna replacement....
17 Posts
Well, it finally happened. My antenna would go up only half way and that was ok as reception was ok at half way up, but then it started going up 1/4 way and now it doesn't go up at all.
I probably need to replace it. Dread the job though. Has anyone done this? I don't see how to get to the thing.
Billy
Posted on: 2008/2/16 12:13
1994 LT1 Coupe, Automatic, Hypertech Tuned/160 mod, K&N Filter
Meziere HD Electric WP, MSD Optispark, Copper Metallic
patsfan05488 RE:Antenna replacement....
229 Posts
I did this about a month ago. The used one I bought from a forum member is working great. The job wasn't really that hard @ all. I just printed out the directions I found on this forum or forum X ( I forget which one ) and I used a Chilton's and factory service Manuel. I think it took a couple of hours, that's with me doing it, I'm slow and not anywheres near a mechanic. I did have to grab my 13 y/o son and his small hands to help me run some of the wires. if you have any questions just let me know ( as I just did it ).
Good-luck ,
Patsfan
Posted on: 2008/2/16 14:30
229 Posts
Here's some links to the direction I used
http://www.corvetteforum.com/techtips ... TopicID=260&TopicID=2
http://www.corvetteforum.com/techtips ... bTopicID=17&TopicID=2
http://www.corvetteforum.com/techtips ... TopicID=185&TopicID=2
As i said in my prior post it really isn't a hard job @ all to do. I wish I would have taken pictures as I did it so I could submit it to Bogus for are Tech Library. i hate to link ya over to site-X but that's where they are.
Again Good-luck ,
PatsFan
Posted on: 2008/2/16 15:04
mikeV RE:Antenna replacement....
Top of the world Ma
158 Posts
All good advice from pats fan. Really not hard.Don't think it was
needed to pull the speaker grill or the shade track on my "86
but I do suffer from CRAFT disease (can't remember a f$%^#$% thing
sometimes
Posted on: 2008/2/17 15:38
CentralCoaster RE:Antenna replacement....
Hardest part is reaching that plastic nut from underneath. You will probably need a 2nd person up top, for reattaching it if nothing else. I don't recall doing any work from inside the car.
I also had a helluva time finding which replacement antenna to use on my 85, there are so many variations over a few year span and I think some of the catalogs are wrong.
Mine had a Harada MX-22, which is used on many applications, and available cheap, but there's some corvette specific stuff on it.
Posted on: 2008/2/17 20:39
Ugolino RE:Antenna replacement....
7 Posts
The hardest problem I had was reinstalling the rubber grommet, there is no room under there to get the leverage you need to plug it back in again. Finally I just put some lithium grease around it and that helped to get it in again.
Posted on: 2008/2/21 17:19
skirlin RE:Antenna replacement....
Caledonia Michigan
277 Posts
The antenna mast on my 92 was broke off and I will be replacing it in a few weeks. Thanks for the info.
Posted on: 2008/3/4 6:21
LD85 RE:Antenna replacement....
Indianapolis, Indiana
784 Posts
What does a new mast cost? When I paint my car, I might just put a new one in, instead of putting hte old one back in.
Posted on: 2008/3/27 23:35
2005/Z51
