309 user(s) are online (233 user(s) are browsing Forums)
donhall A.I.R. pipe insulation - 1992
297 Posts
The photo is the A.I.R. pipe...... as you probably have experienced, the insulation starts to unravel if you just look at it. The more you trim, the more it unravels, as you can see to the left of the photo.
I'm considering replacing the insulation mess with hi-temp (420 deg max.) nylon split wire loom: http://www.skycraftsurplus.com/splitloom1inch-1.aspx
Anyone know the temp of that pipe during operation?
Posted on: 2012/11/1 22:05
1Fast04Vert Re: A.I.R. pipe insulation - 1992
It would melt the nylon tubing. Maybe some header wrap?
Posted on: 2012/11/1 23:39
donhall Re: A.I.R. pipe insulation - 1992
297 Posts
In that case, Andy, I will wrap the pipe with exhaust wrap: http://www.amazon.com/gp/product/B000 ... ef=oh_details_o01_s00_i00)
Thanks for the suggestion.
Posted on: 2012/11/2 0:21
BillH Re: A.I.R. pipe insulation - 1992
Do what you want if it makes you more comfortable.
Mine's been like that for 6 years, probably more, with no problems.
Make sure those wrapped plug wires are on the outboard of the dipstick.
Posted on: 2012/11/2 0:31
297 Posts
The 'wrap' just looks ugly, Bill. The insulation must be there to protect
anyone from the heat that has migrated into the pipe from the exhaust header,
so you are correct that missing insulation is not a problem, unless you come in contact with a hot pipe.
Yep, the plug wires are routed outboard of the dipstick tube.
Posted on: 2012/11/2 1:51
tjpreul Re: A.I.R. pipe insulation - 1992
I used the 1" wrap on mine. It took some time to get it done.
jpg  wrap.jpg (451.64 KB)
1727_50933076cbc49.jpg 900X675 px
Posted on: 2012/11/2 2:32
297 Posts
Nice looking job, Tyler. I have similar wrap, but lost patience with the slow progress. That is when I started thinking about a split hi-temp loom, but Andy (1Fast04Vert) reminded me that I was dealing with exhaust temps.
Thanks for the reply.
Posted on: 2012/11/2 2:58
297 Posts
For those of you interested in replacing the frayed insulation over
the A.I.R. pipe, you might read about this product:
http://www.cableorganizer.com/convoshield/
Split side for easy installation.... just cut to length, and slip it on.
Withstands heat up to 1000 deg f.
Posted on: 2012/11/3 17:15
pianoguy Re: A.I.R. pipe insulation - 1992
Great find!
Posted on: 2012/11/3 23:53
joeld Re: A.I.R. pipe insulation - 1992
So, are you going to be the test mule for this? I would like to hear how it stands up to heat.
Posted on: 2012/11/4 0:23
297 Posts
Yep..... it's on order. Will post photos. (May just chrome the whole engine compartment, and glue on an LT5 badge on the rt. rear bumper)
Posted on: 2012/11/4 1:17
