ninetyfivevette | Looking for GM part numbers | ||
Does anyone have links to factory part number lists, LT1 specifically? I'm looking for some odd things that my usual sources are not turning up. In particular, I'm looking for the crossover tube, banjo bolts and sealing washers.
Having a database of part numbers would be useful anyway- that would make a good addition around here. |
Posted on: 2008/2/18 18:13
Notorious | RE:Looking for GM part numbers | ||
I don't believe the crossover tube is available from GM anymore. If you can get a number though, some dealers may still have one in stock. Good luck.
Posted on: 2008/2/18 18:16
toptechx6 | RE:Looking for GM part numbers | ||
The part number for a 95 is 12556260, the description indicates it comes with bolts and seals, GM Parts Direct shows it as still available. PM me for a copy of the parts CD if interested.
Posted on: 2008/2/18 21:29
rayquayle | Re: Looking for GM part numbers | ||
Does anyone have links to factory part number lists, LT1 specifically? I'm looking for some odd things that my usual sources are not turning up. In particular, I'm looking for the crossover tube, banjo bolts and sealing washers. Will this help? |
Posted on: 2008/2/19 6:44
Ray Quayle in England '86 Indy PaceCar, 4+3 NCM Founder #2896 NCM Lifetime #672 Graduate of Gordon's School |
MK 82 | RE:Looking for GM part numbers | ||
Hey Ray,
How do you make links like that? |
Posted on: 2008/2/19 15:00
96 CE Roadster LT4 |
Jeffvette | RE:Looking for GM part numbers | ||
The part number for a 95 is 12556260, the description indicates it comes with bolts and seals, GM Parts Direct shows it as still available. PM me for a copy of the parts CD if interested. GM shows 21 on hand. |
Posted on: 2008/2/19 16:22
ninetyfivevette | RE:Looking for GM part numbers | ||
Thanks guys! I got my parts ordered up yesterday.
Ray, I'm downloading your PDF as we speak- at 190MB something tells me it will be very useful! Thanks! |
Posted on: 2008/2/19 16:39
rayquayle | RE:Looking for GM part numbers | ||
Posted on: 2008/2/19 18:33
Thanks guys! I got my parts ordered up yesterday. And my link is not very good, so it will take a while, sorry 'bout that. |
Posted on: 2008/2/19 18:45
It just finished- BIG THANKS! :thumbright:
Posted on: 2008/2/19 19:28
It just finished- BIG THANKS! :thumbright: Wow! I knew it would be slow, but 3 hours! I'm really sorry, the problem is at my end. Hope it proves worth it. |
Posted on: 2008/2/20 6:40
