199 user(s) are online (78 user(s) are browsing Forums)
woody3882 Valve adjustment myths
Florida
51 Posts
My next venture is to adjust the valves on my 94 c-4 I have no problems attempting it but I need some advise on the myths that were recomended to me. One recomendation was to find TDC, use the spin method and adjust valves intake 1,2,5,7 and exhaust 1,3,4,8 THEN rotate the crank one full turn and set all the rest. The other recomendation was to set TDC, do #1, rotate 1/4 turn, do number 8, turn 1/4 turn, do number 4, etc.etc. 3,6,5,7,2, with a 1/4 turn in between. Which is believed the best way. TDC do intake 1257, exhaust 1348, one full turn do exhaust 1,3,4,8 OR turn 1,4 turn between each 18,4,3,6,5,7,2, adjustment. If you have done this I am sure understand what I am trying to ask. Any advise is greatly appreciated
Thanks
Woody
Posted on: 2013/3/9 23:35
Calm Re: Valve adjustment myths
Vancouver, Canada
608 Posts
Woody,
I do it old school.
A bit messy,sure.
But I trust it much, much more.
-Rod
Posted on: 2013/3/10 0:18
BillH Re: Valve adjustment myths
Calm wrote:
Woody,
I do it old school.
A bit messy,sure.
-Rod
Yea, doing it static is a base setting, you need to do it again running if you do it this way.
Rocker arm clips help the oil thing.
Posted on: 2013/3/10 0:43
Matatk Re: Valve adjustment myths
22996 Posts
Doing it running is nice but inconvenient on our cars with all the brackets and crap in the way of the valve covers.
When I did mine I did it the first way you have posted...do 4 then turn over the motor and do the other 4. Just be careful when setting them with the engine cold that you don't over compress (collapse) the lifter.
Btw, I have no problems that I know of from setting them that way.
Posted on: 2013/3/10 3:49
woody3882 Re: Valve adjustment myths
Florida
51 Posts
I now see why and agree that adjusting the valves running and hot is the best way to go, I do have a couple of questions first,
What is the best valve cover gaskets for the LT-1 ?
before I take the covers off I want to buy and cut up an old set to prevent the oil spill, so I want everything ready ahead of time, which includes making the welded handle on the socket, What size socket fits the stem nut?
What size allen wrench locks down the set screw?
Simple questions for those that know, tough for those that dont. I could not have gotten this far on my 94 vette project without great guys like yourself. Thanks for sharing the knowledge, I appreciate it
Thanks again,
Woody
Posted on: 2013/3/10 18:44
gasket - Felpro Dry Fit - VS50443R
Best price - RockAuto - $15.00
Posted on: 2013/3/10 19:23
EngineDoctor Re: Valve adjustment myths
La Habra Ca.
791 Posts
Yes, it is best to adjust valves running & hot imho.
Posted on: 2013/3/10 20:06
Florida
51 Posts
Thanks, I just ordered the gasket set you recomended (VS50443R),
If anyone has an old set of beaten up trash valve covers they would like to sell, please get in touch with me. I am going to cut them up for valve adjustment access.
Thanks
woody3882@aol.com
Posted on: 2013/3/10 20:09
Vancouver, Canada
608 Posts
Hi Woody,
You have center-bolt valve covers......which means you'd need to cut around the holes in order to access the rocker nuts yet still have enough meat to bolt down the covers?
I've never heard of this being done, and I suspect it won't actually work because the metal would not sustain enough hold-down pressure to seal the gasket.
What I do is warm up the motor, take one cover off, adjust, then replace cover. Repeat on other side. Then I let cool down and simple green and hose down each side.
Posted on: 2013/3/10 21:23
joeld Re: Valve adjustment myths
Calm wrote:
Hi Woody,
Yea, it would be tough to fab a set of center bolt covers for this. I've used this type of deflectors years ago with the stamped steel rockers, not sure if they would work on the later style such as yours.
http://www.summitracing.com/parts/mrg-1015
Posted on: 2013/3/11 2:18
Florida
51 Posts
Thank you, Now I understand, I will probably end up just placing a piece of cardboard to deflect the oil spray.
I do have another question, On the drivers side, I believe I have to remove the alternator and a/c bracket to give removal clearance for the valve cover, Can I squeeze the cover off or am I correct in that the bracket has to be completely removed, then put back on to run the car for the valve adjustment, then removed the bracket again to replace the cover, or is there an easier way. You have been a great help, Thanks I appreciate your time.
Woody
Posted on: 2013/3/11 16:29
Vancouver, Canada
608 Posts
I leave my alternator off, do the adjustment, then re-install everything.
It only takes about 5 minutes to adjust each side.
Posted on: 2013/3/11 17:43
Florida
51 Posts
I can see doing it with the alternator off if you have an electric water pump, but doesn't the water overheat with no belt on the water pump.
Woody
Posted on: 2013/3/12 15:20
22996 Posts
You aren't really putting a load on the engine and it's for a short period of time, I wouldn't worry about it.
Posted on: 2013/3/12 16:11
Vancouver, Canada
608 Posts
Woody
No, that's the thing with our LT1's....the pump is gear driven.
Posted on: 2013/3/12 16:43
Aboatguy Re: Valve adjustment myths
My Avatar was redistributed!
498 Posts
Calm wrote:
Woody
Yep...no belt for waterpump....
One other tip is I place a couple of rags over the rockers and remove the rag from the pair I'm adjusting, replace rag and move on. Seems to keep oil off of my headers, and as previously mentioned with the alternator off it only takes a couple of minutes per side.
Posted on: 2013/3/15 2:43
corvetteronw Re: Valve adjustment myths
Lowell, MI
I have done it both running and not running. I had very little oil splash with it running. Here is a video (not mine)
http://www.youtube.com/watch?v=EJKE4owhS7Y
Posted on: 2013/3/17 0:16
JrRifleCoach Re: Valve adjustment myths
1526 Posts
That vid is very disconcerning.
I mean that there so little oil being pumped around there.
Why is it so damn hard to keep the oil under the valve covers then?!?
Posted on: 2013/3/19 4:30
22996 Posts
When you rev the engine, the oil comes out faster. It will also pool in the head and leak around the gaskets.
Posted on: 2013/3/19 11:41
Edited by Matatk on 2013/3/19 16:42:11
