249 user(s) are online (212 user(s) are browsing Forums)
'W' Series:
5.7L 348ci - 1958 thru 1964
6.7L 409ci - 1961 thru 1965
7.0L 427ci (Z11...
biggrizzly Exhaust Manifold Bolt Shoulders?
Since I'm installing Hooker Shorties, I figured I could get away with wire wheeling the old bolts and using them to install the headers. Well, it appears that the bolts have a shoulder and skirt around them that prevent seating the bolt next to the header tube.
What bolts should I use? Do I have to grind the shoulders off all these bolts? That would suck. Some of the bolts have both ends threaded to secure accessories too.
Any suggestions from you wise exhaust gurus?
Posted on: 2008/2/23 13:11
toptechx6 RE:Exhaust Manifold Bolt Shoulders?
south Florida
362 Posts
Check out Jegs or Summit for a huge selection of header bolts to suit nearly any set, most use a smaller head with washer to make installation easier.
Posted on: 2008/2/23 15:59
BBShark RE:Exhaust Manifold Bolt Shoulders?
Cincinnati, OH
29 Posts
I used 12point flange head screws on mine. I got them from Mcmaster-Carr. Solved my socket clearance problem and you still have the flange on the screw.
Posted on: 2008/2/23 16:32
jsup RE:Exhaust Manifold Bolt Shoulders?
1778 Posts
get the ARP with the 3/16 allen wrench provision in the middle of the bolt. This helps in tight spaces.
I ground off that shoulder on mine for the AC and oil stick bracket.
Posted on: 2008/2/23 16:41
biggrizzly RE:Exhaust Manifold Bolt Shoulders?
Thanks guys - I went to Advance Auto and looked at the crap they had on the shelf and walked out empty handed. I'm probably going to order the ARP bolts from Summit and then use the accessory bracket bolts from my factory fasteners with the shoulders ground off.
Posted on: 2008/2/23 17:03
south Florida
362 Posts
It would be kind of slick if someone would make an assortment package since the position often dictates the type of bolt that will work best, but suppose that is dreaming.
Posted on: 2008/2/23 17:40
MK 82 RE:Exhaust Manifold Bolt Shoulders?
Palm Beach Gardens, FL
439 Posts
That's what I did on my 86.
Posted on: 2008/2/23 21:50
96 CE Roadster LT4
Notorious RE:Exhaust Manifold Bolt Shoulders?
I use 3/8" x 1" NC stainless bolts w/ a 5/16" allen head. If you have a bolt specialty shop locally (such as Fastenal or etc.) you can get a set of them for under $10. Much cheaper than buying equal quality "header" bolts. I've been using the same set for quite awhile. And after the initial recheck and re-tightening once you've gone through a heat cycle or two, I've never had a problem with loosening. I also use copper gaskets and have stainless steel headers with 3/8" flanges.
You may have to retain and reuse one or two of your stock bolts with suitable spacers, to retain any critical component reinforcing brackets.
Posted on: 2008/2/23 23:06
I hate sporks...
Strick RE:Exhaust Manifold Bolt Shoulders?
Lake Wylie, SC
129 Posts
I did the exact same thing. The only OEM bolts I used were the ones holding the a/c and alt bracket braces with a standoff. Oh, I also used the OEM bolt that holds the dip stick plus a standoff. The only grinding I had to do was on the brace so it would fit next to the tube.
Posted on: 2008/2/23 23:44
I carefully ground the mounting bracket off of my dipstick tube, finished it and repainted it. You can't tell it was ever there. I then attached it below the head, with a cushion clamp and simple bracket, utilizing an unused, threaded hole in the block. Not only does it hold it securely, but it also allows me to turn the tube at will, making plug changes and R&Rring the RH valve cover easier.
What's the latest, Tom? Are you and your group going to visit the shop anytime soon? I look forward to hearing from you.
Posted on: 2008/2/23 23:56
I hate sporks...
Lake Wylie, SC
129 Posts
With a group this big, everything needs to be approved. I'll be up there as soon as I change my rear bearings which I haven't bought yet. How come the image posting doesn't work?
Posted on: 2008/2/24 21:15
CentralCoaster RE:Exhaust Manifold Bolt Shoulders?
Why not just install some sleeves under the bolts? Then you can actually get a wrench on them.
Posted on: 2008/2/26 0:55
