241 user(s) are online (157 user(s) are browsing Forums)
matts85vet opinion on scat 383 forged rotating assembly
Toledo, Ohio
58 Posts
http://www.adperformance.com/index.ph ... uct_info&products_id=1051
this is the kit i'm looking at for my winter 383 project
anyone ever used this kit before? any comments are appreciated.
thanks
Posted on: 2013/11/22 22:06
85 coupe, 383, TPIS Miniram, auto 700R4, 3.75 gears, afr 180 eliminator heads 58cc, 12:1 compression ratio, comp cams 280XFI hydraulic roller cam, 1.65 roller rockers, 52mm throttle body, c5 calipers, hedman elite longtube headers, pypes dual exhaust w/x-
Matatk Re: opinion on scat 383 forged rotating assembly
Looks like a nice kit, just make sure you get the right piston for your head compression, that one says 11:1 at 64 cc. Also, despite it being "balanced" from the factory you should still get it balanced by your machinist.
Posted on: 2013/11/22 22:11
bogus Re: opinion on scat 383 forged rotating assembly
most important - is it USA made? If so, good... if China? run.
Canada, Japan, Taiwan, Germany, Poland, Australia all good.
Posted on: 2013/11/22 22:31
PeteK Re: opinion on scat 383 forged rotating assembly
Crank and rods are decent.
Closely inspect the thrust surface of the crank. Every now ant then Scat leaves them rough, and they chew up the thrust bearing. It's been years since I ran across it, but it costs nothing to check it.
Rods are decent, but will likely be 2-5 tenths tight. Have the big and small ends checked.
As Matt said, don't trust the balance. Have it spun locally to verify.
Posted on: 2013/11/22 23:53
matts85vet Re: opinion on scat 383 forged rotating assembly
Toledo, Ohio
58 Posts
so is there any reason to buy the kit balanced if i have to have it balanced again anyway?
Posted on: 2013/11/23 3:18
No.
Choice is yours.
Posted on: 2013/11/23 4:13
I have heard many stories of "balanced" assemblies, not being balanced.
It's a safe bet to simply buy unbalanced and have it balanced.
Posted on: 2013/11/23 22:14
Toledo, Ohio
58 Posts
thanks for the advice!
i think i may go for this kit:
http://www.flatlanderracing.com/scatsr-chevysbcast.html
1-90455 with the 7/16 rod upgrade for an extra$79
Posted on: 2013/11/23 22:43
Posted on: 2013/11/24 0:19
rklessdriver Re: opinion on scat 383 forged rotating assembly
On the first kit... It dosent say what ring package they use... if its 1/16 rings then thats a good kit. If it has 5/64 rings find something else...
I have same Scat 4340 forged rods and crank in the engine I built for 93ragtop.... he ran 11.18@124mph first time out. Makes 462RWHP thru an automatic trans so you can build a pretty decent engine with the stuff.
All I will say about Flatlander is they rarely have anything in stock, so expect to wait a hot min for your parts to ship.
Posted on: 2013/11/24 3:03
