matts85vet | opinion on scat 383 forged rotating assembly | ||
http://www.adperformance.com/index.ph ... uct_info&products_id=1051
this is the kit i'm looking at for my winter 383 project anyone ever used this kit before? any comments are appreciated. thanks |
Posted on: 2013/11/22 22:06
85 coupe, 383, TPIS Miniram, auto 700R4, 3.75 gears, afr 180 eliminator heads 58cc, 12:1 compression ratio, comp cams 280XFI hydraulic roller cam, 1.65 roller rockers, 52mm throttle body, c5 calipers, hedman elite longtube headers, pypes dual exhaust w/x- |
Matatk | Re: opinion on scat 383 forged rotating assembly | ||
Looks like a nice kit, just make sure you get the right piston for your head compression, that one says 11:1 at 64 cc. Also, despite it being "balanced" from the factory you should still get it balanced by your machinist.
Posted on: 2013/11/22 22:11
bogus | Re: opinion on scat 383 forged rotating assembly | ||
most important - is it USA made? If so, good... if China? run.
Canada, Japan, Taiwan, Germany, Poland, Australia all good. |
Posted on: 2013/11/22 22:31
PeteK | Re: opinion on scat 383 forged rotating assembly | ||
Crank and rods are decent.
Closely inspect the thrust surface of the crank. Every now ant then Scat leaves them rough, and they chew up the thrust bearing. It's been years since I ran across it, but it costs nothing to check it. Rods are decent, but will likely be 2-5 tenths tight. Have the big and small ends checked. As Matt said, don't trust the balance. Have it spun locally to verify. |
Posted on: 2013/11/22 23:53
matts85vet | Re: opinion on scat 383 forged rotating assembly | ||
so is there any reason to buy the kit balanced if i have to have it balanced again anyway?
Posted on: 2013/11/23 3:18
No.
Choice is yours. |
Posted on: 2013/11/23 4:13
I have heard many stories of "balanced" assemblies, not being balanced.
It's a safe bet to simply buy unbalanced and have it balanced. |
Posted on: 2013/11/23 22:14
thanks for the advice!
i think i may go for this kit: http://www.flatlanderracing.com/scatsr-chevysbcast.html 1-90455 with the 7/16 rod upgrade for an extra$79 |
Posted on: 2013/11/23 22:43
Posted on: 2013/11/24 0:19
rklessdriver | Re: opinion on scat 383 forged rotating assembly | ||
On the first kit... It dosent say what ring package they use... if its 1/16 rings then thats a good kit. If it has 5/64 rings find something else...
I have same Scat 4340 forged rods and crank in the engine I built for 93ragtop.... he ran 11.18@124mph first time out. Makes 462RWHP thru an automatic trans so you can build a pretty decent engine with the stuff. All I will say about Flatlander is they rarely have anything in stock, so expect to wait a hot min for your parts to ship. Will |
Posted on: 2013/11/24 3:03
