209 user(s) are online (175 user(s) are browsing Forums)
These are commo...
cuisinartvette 355 cfm ported and polished LT1 intake/TB
Thought Id share
1284 or GM LT4 gasket
52 or 58mm TB
Next ones getting the lid cut off
jpg  lt1.jpg (28.66 KB)
66_5443014571bc8.jpg 480X360 px
jpg  lt1port.jpg (17.91 KB)
66_54430171517c4.jpg 480X360 px
jpg  lt2.jpg (15.33 KB)
66_54430180f0243.jpg 320X240 px
jpg  lt3.jpg (8.35 KB)
66_54430194c3e00.jpg 320X240 px
jpg  ltp2.jpg (46.08 KB)
66_544301bfa8b8e.jpg 480X640 px
jpg  ltp3.jpg (28.87 KB)
66_544301d232df5.jpg 480X360 px
jpg  ltp4.jpg (28.25 KB)
66_544301e53643e.jpg 480X360 px
jpg  lttb1.jpg (23.14 KB)
66_5443022ce7539.jpg 480X360 px
jpg  lttb2.jpg (24.70 KB)
66_544302416de85.jpg 480X360 px
Posted on: 2014/10/19 0:14
Matatk Re: 355 cfm ported and polished LT1 intake/TB
22803 Posts
Impressive porting on the inside and polishing on the outside!
What are pre-porting numbers?
Posted on: 2014/10/19 1:17
cuisinartvette Re: 355 cfm ported and polished LT1 intake/TB
Didnt get a chance to do a before on this one.
Next piece I pick up that will happen
FWIW this one when flowed had all ports and injector bungs blocked off to give an honest #. Theres more in it.
#8 really lags and requires more work
Posted on: 2014/10/19 1:41
istter1 Re: 355 cfm ported and polished LT1 intake/TB
Bakersfield Ca
2336 Posts
pretty
Posted on: 2014/10/19 16:07
Carol Burnett
pianoguy Re: 355 cfm ported and polished LT1 intake/TB
Sweet!!
Posted on: 2014/10/19 16:22
BrianCunningham Re: 355 cfm ported and polished LT1 intake/TB
Nice
Posted on: 2014/10/20 12:40
Schrade Re: 355 cfm ported and polished LT1 intake/TB
WOW!
Where's the light switch? On, and EXTRA bright... Resized Image
Posted on: 2014/10/20 13:58
Thanks guys
Shrade....now theres a name I havent seen in awhile!!
Fun doing one of these once in awhile.
Been sitting around awhile not the example of my cleanest work but it is what it is. Should support some power Id think
Had a slight issue with the radius plate sure this goes a little more than it does. Next one shooting for high 3xx we will see. Gotta get moved with a real workspace though gave up my garage awhile back makes doing this tough for the time being. think more can be had with less work just in the right places. Some epoxy work inside would do the trick
Plus #8 has no radus to pull from so it needs more attention than the others to keep up. Even GM oversized it compared to the others but the "starved cyl" is addressable anyway if youre willing to spend the time.
What these would pull on a running motor could be a different story as the bench cannot simulate a running engine. Interesting stuff anyway.
I should be working on my ride I dont even own an LT or L98 car lol. Call it OCD
Trying to get some billet TB plates and better gaskets made all I see out there are cheap looking plates. Any interest let me know.
Posted on: 2014/10/21 13:10
