215 user(s) are online (113 user(s) are browsing Forums)
1st Gear: 2.74
2nd Gear: 1.57
4th Gear: 0.67
Reverse: 2.06
bogus ZF6 Drain Bolt Question
Does anyone know the specs on that thing? I need a new one... what is the thread size and count?
Thanks!
Posted on: 2015/1/23 20:18
BillH Re: ZF6 Drain Bolt Question
I think it's metric pipe thread, only thing a search shows is BMW and there's 2 different sizes.
Best bet is to call Bill.
Posted on: 2015/1/23 20:52
BrianCunningham Re: ZF6 Drain Bolt Question
Make sure if it's tapered or not
Posted on: 2015/1/23 21:00
Matatk Re: ZF6 Drain Bolt Question
"The oil fill/drain plug GM P/N is 10140673."
http://www.zfdoc.com/techinfo.htm
Posted on: 2015/1/24 2:14
CentralCoaster Re: ZF6 Drain Bolt Question
I googled it and then realized it doesn't matter, you're getting it from the dealer anyways.
But while we're there, ~70 OZ of fluid goes it in. I remember this because I wrote it on my empty bottle last time. I just picked up 3 qts of synchromesh for it.
Posted on: 2015/1/24 3:15
bogus Re: ZF6 Drain Bolt Question
yea, 2.2 quarts... got it already!
I had the part number, I was just hoping the find a regular bolt to fit into the fill hole...
I did get the old drain out, took about 90 minutes of prying and wacking at the damned thing... it was pretty smooshed.
Posted on: 2015/1/25 17:10
May want to chase the threads with a tap
Posted on: 2015/1/25 19:14
The threads into the box are fine... the plug is what took all the beating. Tested that last night...
Posted on: 2015/1/25 19:21
jonszr1 Re: ZF6 Drain Bolt Question
Lone Pine, CA
andy I have a spare I can mail you . here is a trick to get it out in the future drive the car around for a 1/2 hr it will heat up the case enough that it comes out pretty easy . let me know if you want me to send you one .bill gave me 8 spares.
Posted on: 2015/1/31 17:53
I will take a pic of the old one... it's not about being too tight... the head was folded over by speedbumps!
I simply could not get the tool into the allen head!!! I did finally get it out, and for the moment, I am going to swap the drain and the fill. Should be a-ok.
Posted on: 2015/2/1 21:29
Lone Pine, CA
andy pm me your mailing address and I will mail you spare
Posted on: 2015/2/2 3:52
oh, no need, Brad! Keep it! I am just swapping them!
I can use the old drain on the fill, and the old fill on the drain.... the old fill is perfect. I will also take a bolt and JB Weld it to the head of the fill and back it with a nut, JB Weld the entire thing together... quick fix.
For what I need, it will be perfect! I will worry about it in 18 months when the box goes to Bill for rebuild.
Those damned things are EXPENSIVE! $30 on eBay!
Posted on: 2015/2/2 5:11
