254 user(s) are online (208 user(s) are browsing Forums)
bogus Post clutch install issue
this isn't looking good.
push in the pedal... noises... I think it's the throwout bearing. I will record it tomorrow.
Posted on: 2015/2/22 3:05
BrianCunningham Re: Post clutch install issue
I know you're aware, but single or dual mass?
Posted on: 2015/2/23 0:02
bogus Re: Post clutch install issue
dual It's the right kit....
the problem is the pressure plate... I think LuK is playing games...
Posted on: 2015/2/23 2:12
I was running out of battery on my laptop last night!
Ok... here is the entire score as I see it:
1. LuK makes replacement clutches...
2. 01-0113 is the part number for L98 and LT1/4
3. 01-0114 was the number for the LT5
4. According to both LuK and Rockauto, there is one clutch for both, the 01-0113.
This cannot be accurate. There is a difference in geometry between the LT1(et.al.) and the LT5 pressure plates.
This is causing the clutch fork to rub the clutch diaphragm.
I have contacted Rock Auto.
Posted on: 2015/2/23 16:55
Oh, yea... not to forget...
HUGE props to NelsonV and his friend Mike, for coming over Saturday to help me get the transmission in.
TommyT-Bone Re: Post clutch install issue
Posted on: 2015/2/23 17:12
CentralCoaster Re: Post clutch install issue
Well shit, they did discontinue it it looks like. Yeah, I don't see how they expect the LT1 unit to magically fit the ZR1 now. At least not without a longer pivot stud at the very least.
Anyhow, this shouldn't concern you, assuming you have the dual mass or equivalent dimension FW. You use the LT1 kit. I don't know how you can get fork rub if you've got all the LT1 ZF parts on your car. I've seen it happen once where someone didn't have the fork fully onto the stud.
deleted
Posted on: 2015/2/23 22:37
Edited by CentralCoaster on 2015/2/24 5:21:33
Edited by CentralCoaster on 2015/2/24 5:27:22
Edited by CentralCoaster on 2015/2/24 5:31:59
Edited by CentralCoaster on 2015/2/24 5:32:37
Edited by CentralCoaster on 2015/2/24 5:48:58
BTW, the blue tag clutch sets have a plastic sleeve in the T/O bearing ID. The black tag is all metal in there, and slightly larger ID for the larger shaft.
I know this because I got a misboxed one once. And spent about 6 hours trying to stab a black tag input shaft into a blue tag clutch. I just about stabbed the Napa clerk after that experience. And I also have a blue tag trans now, in case that is all confusing as hell.
Posted on: 2015/2/23 22:47
Longer?
Does that mean you can shim it?
Posted on: 2015/2/23 23:46
I won't know what is up until I take it apart now...
oh, so very exciting... another weekend under my car...
sigh...
LuK is claiming that I cut the flywheel...
Posted on: 2015/2/24 0:18
I don't think that would cause grinding... too thick a flywheel could. Is your car originally a 6 speed or auto?
There are longer pivot studs available, I forget what's what. I might even have one.
But yeah, you can actually just thread it in less, and use the locking bolt to keep it there. So it's somewhat adjustable. I've never done it though.
Next time you're in there post up some photos or something and we'll figure it out.
Posted on: 2015/2/24 5:21
I deleted the p/n's I posted before, I had it wrong. I'd have to do some research. But the rest still applies.
Posted on: 2015/2/24 5:22
Edited by CentralCoaster on 2015/2/24 5:49:36
Stock OEM DMFW... the engine is a 96 LT1, and was an auto... but the engine should not be the factor here... I have the original OEM 1992 vintage black tag ZF6.
The last clutch I bought fit perfectly. This one is fighting me.
I guess the fork could have been bent during removal... but it strikes me as needing more than 20 lbs of torque on it.
Posted on: 2015/2/24 18:12
Which year or p/n bellhousing did you use? One is about 0.2" deeper than the other. Most people don't know this, which is why I find it amusing that people are so picky about the flywheel being off a few thousandths.
Posted on: 2015/2/24 19:39
NelsonV Re: Post clutch install issue
Sunny Southern CA
245 Posts
When? This coming weekend is loading up for me and I'm still fine-tuning details. But I may be able to spare a couple hours if the timing is right.
3/7-3/8 is pretty wide open so far except for Chachi's thing.
Posted on: 2015/2/24 20:56
OEM 1992 LT1.
Posted on: 2015/2/24 23:27
I am taking shit apart this weekend. I have no choice in that. Sunday afternoon would fit for reassembly.
Posted on: 2015/2/24 23:28
OEM 1992 LT1.
Ok. I believe that is the thinner of the two. So more critical to get everything right. I'll let you know what I'm up to this weekend, may have some time to swing by.
Posted on: 2015/2/25 1:50
cool!
Posted on: 2015/2/25 2:06
does anyone have a spare clutch fork? I would like to see pics of a good one so I can compare to mine... if I have to bend it back a touch, I will.
I suspect, over time, these things bend back... one or two removals, and all sorts of bending occurs... until that one time when it bends than last mm or 2... and it is tweaked.
Posted on: 2015/2/25 23:37
EngineDoctor Re: Post clutch install issue
La Habra Ca.
791 Posts
Andy... If it is bent , discard it......It's tinsel strength is gone......This sounds like a T/O bearing or press. plate issue.... Without seeing it IDK> Good luck !
Posted on: 2015/2/26 1:08
neither do I, Dave... the problem is that clutch forks for ZF6's are rarer than rare... I am hoping to find one in a salvage yard, but can't be sure of quality.
I could reheat it and then quench it real quick... that might recover some of the strength...
Posted on: 2015/2/26 1:31
La Habra Ca.
791 Posts
Maybe Jack has one ? Did you check with him??
Posted on: 2015/2/26 1:54
I can check... but I would be shocked... He doesn't mess with C4s that much...
I am afraid JD may have it, but I hate dealing with them...
Posted on: 2015/2/26 2:08
The part that would rub only moves as much as the slave cylinder pushes it... whether its bent or not. Bent would cause low pedal engagement I guess.
Despite the noise, how does that feel compared to before?
Grind it a few times while you're in there so we can look for the shiny spots.
Posted on: 2015/2/26 18:36
Posted on: 2015/2/26 18:38
oh, there will be a shiny spot... I am half tempted to estimate and grind away on the fork what isn't needed...
thoughts?
Posted on: 2015/2/26 19:15
depends, you could weaken it
Posted on: 2015/2/26 20:28
yea, well, that ship has sailed, I think.
finding a fork is not coming easy... GM discontinued them a long time ago.
We need someone to make a few...
Posted on: 2015/2/26 22:00
Posted on: 2015/2/26 22:41
damned good find! THANKS!!!!
Posted on: 2015/2/27 0:11
my only concern... the site hasn't been updated in 4 years.
Posted on: 2015/2/27 0:18
Well... I sent the guy an email... and get a 200 word essay, berating me for not buying from him in the first place.
I replied equally snarky.
Posted on: 2015/2/27 20:10
thoughts?
Only bad ones. No reason it can't be done right.
Can you hold off until next weekend? Looks like rain in the forecast, (so I might as well go snowboarding.)
Posted on: 2015/2/27 20:11
I am thinking the same thing. It's already spritzing rain here... that does not bode well. If it is dry, I will pull it apart, but if not, I will simply do a lot of house cleaning.
Posted on: 2015/2/27 22:08
This weekend is a washout... aiming for next, and with all correct OEM parts.
Posted on: 2015/3/1 21:41
Which day? I'll bring some stuff, if we can't get this done, I'll retire my tools and Corvette and get a prius.
Posted on: 2015/3/3 17:28
Sunny Southern CA
245 Posts
Are you guys shooting for a complete R&R in one day? I think I have a trap shoot Saturday morning, but Sunday is wide open for me (so far).
It looks like the weather is going to cooperate.
Posted on: 2015/3/3 19:04
If the parts arrive, we can get this hammered out in no time.
Remember, everything is nice and clean now... so not so much grime to deal with.
Which day is good for you, Kevin?
Posted on: 2015/3/3 20:28
Either day.
We'll have it slapped in and done by lunch time Nelson, and in line for tech at the drag strip.
What parts are you waiting on?
Posted on: 2015/3/3 22:33
pressure plate and throw-out bearing.
should have both by Saturday mail.
Posted on: 2015/3/3 22:57
Parts are on their way... New friction disc and a new throw-out.
Both OEM parts.
yay! Power Torque Systems knows their shit!!
Posted on: 2015/3/4 20:53
La Habra Ca.
791 Posts
So have you figured out what the problem is yet Andy ?
Posted on: 2015/3/4 23:12
oh, yea... junk parts not made to OEM spec.
The clutch in the front is a SPEC clutch. New.
The fitment is exactly what my LuK RepSet is doing; pushing the diaphragm out from the pressure plate.
This is WRONG.
The clutch in the rear is how it should look.
Most everyone is now getting these junk Chinese pressure plates that are not made to spec. Valeo is out of the business...
jpg  IMG_5069.jpg (131.47 KB)
3_54f79b276d479.jpg 600X800 px
Posted on: 2015/3/4 23:51
La Habra Ca.
791 Posts
Wow !!! Slight difference there......What a waste of time, glad you got it figured out.
Posted on: 2015/3/5 0:09
the image at the bottom is what cued me to a problem in the first place, but LuK said it was ok...
They are lying...
The other brands will use the terms "radius" the clutch fork... things like that. But the forks are pig metal... they don't do well getting material cut off.
Posted on: 2015/3/5 0:11
La Habra Ca.
791 Posts
There is definitely a lot of crap parts out there these days ! I see it all the time in the engine biz....
Posted on: 2015/3/5 0:18
Yeah that front setup looks way off. I'll bring my spares just in case.
Posted on: 2015/3/5 19:06
I am lucky in that I do have a good, tho used, Valeo PP... a quick hit from scotchbrite and it should be perfect again.
A new friction disc and bearing on inbound. Should be here tomorrow.
Posted on: 2015/3/5 20:49
what's the plan? Saturday or Sunday?
Posted on: 2015/3/6 17:01
