212 user(s) are online (162 user(s) are browsing Forums)
brian seafoam
193 Posts
anyone no where to get it and how to use it?
Posted on: 2008/3/25 16:45
DaleD Re: seafoam
Cuyahoga Falls, Ohio
1389 Posts
The guru has come of age. Seafoam is here.
Autozone sells it.
Pour 1/2 or even a whole can in the gas tank after filling. You can also get a hose, and suck 1/2 can into the intake through a vacuum. You have to be careful not to let it go to fast or you'll hydrolock the car.
Posted on: 2008/3/25 16:56
brian Re: seafoam
193 Posts
ok so put it in my gas tank? then i just rev the car up?
Posted on: 2008/3/25 17:28
DaleD Re: seafoam
1389 Posts
Just like any additive. Put it in the tank and drive the car normally.
When you're sucking it into the intake, that's when you rev it. And make sure you don't do it too fast.
Posted on: 2008/3/25 17:39
brian Re: seafoam
193 Posts
k sounds good thanks for the advice.
Posted on: 2008/3/25 17:41
pappyfreebird Re: seafoam
1028 Posts
any parts house...ol beer bottles n fill em...shtuff couple ol rags in tops n yer ready fer fire
Posted on: 2008/3/25 17:43
NEVRL8T Re: seafoam
Little Rock, AR
74 Posts
It can mist an 02 sensor on an LT1 if you suck it up through the intake and may or may not throw a code.
Posted on: 2008/3/25 17:44
mojo92 Re: seafoam
Tifton,Ga.
58 Posts
seafoam in the red and white can that is for bad gas, put a hold can in, it will take awhile maybe the whole tank of gas for it to work right. Seafoam dries up the water in the gas but it's not a over night thing. When my car started running fun I had a full tank of gas and I put 2 cans of seafoam in. We have a really big problem with the gas stations puttong gas in to make it last aliddle longer.
Posted on: 2008/3/25 23:24
Dads90 Re: seafoam
Pearland, Tx
318 Posts
Just pour it into the brake booster vacuum hose and it sucks it straight into the plenum, might kill multec injectors though. Did mine. Ran great for a week and then it
Posted on: 2008/3/26 3:22
Ramrod Re: seafoam
S. California
296 Posts
WOAH!!! Wait a minute. It may not have anything to do with it but I put a can of Foam in my tank. Few days later I had to change my fuel filter????? Coincidence? maybe yes maybe no. The sock on the fuel pump was also plugged so much it was sucked up into the pump???
Posted on: 2008/3/26 4:55
1996 LT-1
DynaSpark Opti, Tapered Rear Wheel Bearings, SS Brake Lines, Speed Bleeders, MC Bias Spring, Hawk HPS Pads, MSD Wires,NGK Iridium, lowered, etc.
runner140 Re: seafoam
Ft. Lauderdale, Florida
721 Posts
Love the "stuff". Driving 20000 miles a year, I use it one or two times a year.(the above instructions for use are correct)
Also use it in my power generator. (hurricanes/loss of electricity)
Posted on: 2008/3/26 11:44
721 Posts
Anyone want to talk about 160 vs 180 thermostats? Just kidding.
Posted on: 2008/3/26 11:46
LD85 Re: seafoam
Indianapolis, Indiana
784 Posts
I used it on all of my high mileage engines, I just poured a can in the tank with tank 3/4 full or so, drive it out, rinse lather, repeat
Posted on: 2008/3/27 11:24
2005/Z51
