113 user(s) are online (89 user(s) are browsing Forums)
smooth C5 Brake upgrade
Formerly "Aquavet" in Pa.
386 Posts
I just finished up my brake project....well, sort of. I got everything put together and bled the brakes, went out for a test drive and got a nasty constant screech from the passenger side. Damn rattle clip! Doesn't want to stay seated. It will have to wait for another day. Its starting to rain here...
[IMG]http://i241.photobucket.com/albums/ff216/berkworks/DSC00258.jpg[/IMG]
Posted on: 2008/4/1 19:58
Alan
2001 Navy Blue Metallic
JeepCycle Re: C5 Brake upgrade
Nesquehoning, PA...Pocono Mt.s
30 Posts
Did you buy a kit or did you piece it together yourself?
Posted on: 2008/4/2 12:38
LD85 Re: C5 Brake upgrade
Indianapolis, Indiana
784 Posts
Nice job, the Brake upgrade was the easiest project I did recently
Posted on: 2008/4/4 0:23
2005/Z51
30 Posts
Did you buy a kit or put the parts together yourself?
I saw on another forum where a guy had ordered all the parts separately from different places(each place = best price) and did the whole thing for around $400.00 U.S.
He ended up with essentially the same parts as the kits...be darned if I can remember which forum though...I ask because that is on my hunny dew list for my Black Beauty this month...
Posted on: 2008/4/4 12:34
784 Posts
OK, I got a set of new C5 Front Calipers, Pads and Brackets for a reasonable price, $190 from a member , FLYLOW in the C5 section of CF
RockAuto has Rotors for $21.00 each, with shipping = $54 total.
Looks like the Bolts are Grade 8,,,,14mm X 2mm X 47mm long and cost @ $2.00 each. I already have new SS braided lines
Made my own brackets or you can buy them
BeforeResized Image
AfterResized Image
Posted on: 2008/4/4 14:08
2005/Z51
Matatk Re: C5 Brake upgrade
LD - you stole those calipers, pads, and brackets for $190!
I also pieced my own system together. I bought some used calipers from a low milegage wreck, got the brackets with them. My corvette mechanic buddy gave me some barely used take off rotors and pads from and old customer for free. Bought Jeffvette's adapter brackets (a little more difficult to make on my own since I have an 89). I kept my stock brake lines. Painted the calipers and rotor hats and did a brake bleed and I was done. Overall, for around $300 I have a killer brake system 100 times better than my stock.
ps- aqua - let me know if you want those rattle clips we discussed earlier.
Posted on: 2008/4/4 14:27
784 Posts
Yep, did it opretty cheap with all new parts, even added SS braided lines.
Posted on: 2008/4/4 16:34
2005/Z51
30 Posts
Awesome...thanks guys....is there anything else I'll need?
Is there a picture and or measurements of the needed brackets?
This definitely sounds like the way to go...
Will they fit with the stock wheels from 96?
I gotta get some pics of my car...
Posted on: 2008/4/4 23:39
CentralCoaster Re: C5 Brake upgrade
Try contacting Jeffvette for the brackets, there are 84-87 brackets and 88-96 brackets.
I'm not sure about the wheel clearance. Some years don't clear the face of the caliper.
Posted on: 2008/4/5 0:26
I've heard the A-molds will clear it but the later sawblades won't. I know I test fitted my sawblades from my 89 and it barely cleared it. My aftermarket C6 repros fit with no issues.
I have a picture of the brackets from cad that someone else did, but you'd need a machine shop to make them.
You'll also need the little stuff such as brake fluid, banjo bolts, slide lube, and a bleeder can make the job easier. Some people use speed bleeders (I don't).
BTW, why do you want the upgrade, from what I've read the 96's had good brakes already - better than earlier years?
Posted on: 2008/4/5 6:16
30 Posts
96 wheels...85 Coupe...
Posted on: 2008/4/5 23:48
Post some pics of your ride already!
Posted on: 2008/4/6 0:39
30 Posts
I'm not real good at that...especially when you have to make the pictures tiny and all that...I have a hard time getting the pics from the phone or camera to the puter then to get them anywhere else is sheer torture...I tried getting some off a disk I made but it gave me a bunch of bs and I said screw it til another day...
You know, I can build these things really well, but I can hardly get to the net once their running...
I'll get it done...I promise
Posted on: 2008/4/7 5:15
Thanks,
JC
Black 1985 Coupe
redhose Re: C5 Brake upgrade
3 Posts
the one in the center hole of the caliper... hang em on your wall...those impede air flow thru caliper...never heard pads rattle on mine w/o the clip
Posted on: 2008/4/16 14:54
Danspeed1 Re: C5 Brake upgrade
Mooresville, North Carolina
1121 Posts
Not to hi-jack the thread... my C6 brakes are going on this week... do you actually need the backing plates for the pads?
DG
Posted on: 2008/4/22 16:58
1972 Chevelle SS 454
1995 Corvette Convertible
1996 Ford Explorer
2009 Cadillac CTS-v
SpectatorRacing Re: C5 Brake upgrade
The backing plates are for noise...
in my opinion, no. In almost everyone else's, yes.
Posted on: 2008/5/6 19:17
Oh I thought they were for people that turn their rotors too much or are too cheap to replace pads before the pistons fall out.
Posted on: 2008/5/9 0:21
