50 user(s) are online (34 user(s) are browsing Forums)
ianh C4 headers
uk
3 Posts
Hi gents. New to the site - from the UK.
A wealth of knowledge here, so I thought I'd ask a question.
Will aftermarket headers for the LT1 fit the L98 engine?
I've a chance to get some at a good price over here.
Thank and I look forward to posting further when I've read all of the entries I can!! :thumbright:
Posted on: 2006/11/27 13:23
Ian Harris
88´ Corvette
03´ ZRX 1200
PeteK RE:C4 headers
Good question. I am not sure of the answer, but I "think" they will interchange. Do not buy them until someone smarter than me chimes in
Posted on: 2006/11/27 19:54
hulagan808 Re: C4 headers
hawaii, maui
58 Posts
I would look at the gasket sets at your local parts store to compare port shape-size. Aloha
Posted on: 2008/6/30 20:23
88 vert, gen 7, superram, blah blah blah for days
Notorious Re: C4 headers
It depends upon both the headers and the type of L98. You have an '88? If so, it should have D-port heads so that's in your favor. Do you know what brand the LT1 headers are?
Posted on: 2008/6/30 23:26
I hate sporks...
CentralCoaster Re: C4 headers
I have more questions than answers. But it may help you.
Will the external EGR hook up to them?
Will the smog tubes hook up to them? (Assuming you even need the smog headers.)
Posted on: 2008/7/1 18:13
BrianCunningham Re: C4 headers
Emissions hookups are the real issue.
Here's my LT1/4 headers I bought from Exotic Muscle
[IMG]http://i242.photobucket.com/albums/ff87/swiftwood/BayStateCorvetteClub/members/Brian%20Cunningham/blower%20build/emHeader.jpg[/IMG]
Posted on: 2008/7/2 16:52
Slalom4me Re: C4 headers
Edmonton, AB
165 Posts
Another issue may be interference/contact between primaries
and the L98's fuel supply & return line segments that run
from the area of the fuel filter (beneath the pass side
footwell) and the fuel rail fittings at the front of the
engine.
The fuel lines for the LTx run up vertically back near #6
& #8 then over to the rear of the intake manifold (rather
than along the frame rail and up the front of the block in
the case of the L98.) Larger diameter primaries are
frequently used for LTx headers - 1-3/4 or 1-7/8. Because
of this difference in the location of the fuel lines,
header layouts for LTx engine likely anticipate having
greater room for #2 & #4 primaries to exit from the flange
and snake down under the car. Using such headers on an L98
may require changes to the fuel line routing.
ultraviolet70's OEM L98 fuel lines
mrc24x's approach of fuel line relocation for a TPI-style intake
98Red's approach for an HSR
TJM's L98. An example of #2 primary interference with the
fuel lines. (Close proximity to suspension control arm
pivots, too.)
Posted on: 2008/7/15 18:39
I'd put some heat wrap on that!
Posted on: 2008/7/17 2:25
