232 user(s) are online (155 user(s) are browsing Forums)
runner140 Anyone have a 96' with the dreaded HVAC problem ?
Ft. Lauderdale, Florida
721 Posts
Looking for tips or sympathy attacking the problem. I use a FSM which describes the problem BUT it is very difficult to get at. Straight up from the gas pedal, about a foot and a half.
Put the steering wheel up, put the seat all the way back and get on your back, and look up. The nipples on the controller/programmer have to be trimmed back because of the heat, they collapsed. Then reconnect the vacuum hoses and your done.
Sounds like a one Chiropractor job.
Seriously any tips will be greatly appreciated.
Posted on: 2008/5/20 16:02
Ramrod Re: Anyone have a 96' with the dreaded HVAC problem ?
S. California
296 Posts
I've never heard of that one, what are the symptoms?
If ya feel acrobatic you could remove the seat and rails. Lay on your back, and make sure you have a cell phone within reach.
Posted on: 2008/5/20 16:20
1996 LT-1
DynaSpark Opti, Tapered Rear Wheel Bearings, SS Brake Lines, Speed Bleeders, MC Bias Spring, Hawk HPS Pads, MSD Wires,NGK Iridium, lowered, etc.
runner140 Re: Anyone have a 96' with the dreaded HVAC problem ?
721 Posts
I was curious and looked on the "other" forum. There were about 25 guys with 96's with that specific problem. Pull the seat sounds like good advice.
Thanks...
Posted on: 2008/5/20 16:28
MK 82 Re: Anyone have a 96' with the dreaded HVAC problem ?
Palm Beach Gardens, FL
439 Posts
Mine was replaced before I bought it. Now I know why.
Posted on: 2008/5/22 2:15
96 CE Roadster LT4
pianoguy Re: Anyone have a 96' with the dreaded HVAC problem ?
I had similar symptoms (where it was blowing out of the defroster vents), and replacing the vacuum check valve under the passenger-side fuel rail cover solved my problem. I got one at NAPA for a little over $2 - might be worth a shot.
Posted on: 2008/5/22 10:31
721 Posts
I'm going to get into this on Sat. or Sun. Thats what I call a tip....$2.00 to replace, easy to get at and R&R. I'll give it a try.
Thanks,
Ed
Posted on: 2008/5/22 11:26
RollaMo-LT4 Re: Anyone have a 96' with the dreaded HVAC problem ?
Trivia Winner
Rolla, Missouri
422 Posts
I have a '96, but haven't had any issues with it. I have heard of the '96 being the most prone to a vacuum controller issue though.
Here is a link on the other forum that might shed some light on this (if this is in fact the problem your having).
http://forums.corvetteforum.com/showt ... 2&highlight=ac+controller
Posted on: 2008/5/22 11:33
721 Posts
Thanks for the link, it will help alot. Getting at it is the real "bitch".
Thanks again.
Posted on: 2008/5/22 11:52
Thanks,
Ed
In my case, it would blow out of the defroster vent, and then slowly (like having to drive down the block before it would switch) switch over to blow out of the A/C vents. Disclosure - it actually cost me about $202, as I impulse-bought the low-profile jack they had on sale - LMAO! ;-)
Posted on: 2008/5/22 12:19
Trivia Winner
Rolla, Missouri
422 Posts
Oh, my wife hates it when that happens.
According to her, there are no "low cost" fixes for anything.
Posted on: 2008/5/22 12:24
