163 user(s) are online (98 user(s) are browsing Forums)
Mekanic Awesome vid of the LT5
Tampa Bay Florida
827 Posts
Being built!!
Never seen this before..
Posted on: 2008/7/15 11:26
~Rich
Polo LT4
CSS996 Re: Awesome vid of the LT5
Mega Guru
Central PA
3644 Posts
NEAT!
Thanks for posting that.
Posted on: 2008/7/15 14:30
Currently "Between Vettes".
Jeffvette Re: Awesome vid of the LT5
Keep in mind, it took GM almost 20 years to build another engine like they built the LT5. Everything basically done by hand, with both the LT5 and LS7.
Posted on: 2008/7/15 19:54
TommyT-Bone Re: Awesome vid of the LT5
33768 Posts
Vettes towing boats? Of course.
Posted on: 2008/7/15 20:25
CentralCoaster Re: Awesome vid of the LT5
Except for the LT5 being subbed out to Lotus and Mercury Marine.
Posted on: 2008/7/15 22:18
pianoguy Re: Awesome vid of the LT5
Sweet! I wish I had done more homework on the LT5 before I bought - I shied away from them, thinking they'd be much more trouble. If I had been armed with better info, I might have tried to find one.
Posted on: 2008/7/15 23:05
Because GM did not know how to build a motor. I mean come on the best they could come up with was the L98.
Posted on: 2008/7/16 16:21
BrianCunningham Re: Awesome vid of the LT5
Cool video.
Barbeque paint?
Posted on: 2008/7/16 19:46
And then the LT1 intake and reverse cooling ideas were stolen from others outside of GM.
Posted on: 2008/7/16 23:06
