315 user(s) are online (242 user(s) are browsing Forums)
traiconghoa 96 Vette....NEED HELP!!!
27 Posts
I have a 96 Corvette automatic, with 115,000 miles. It start and reverse fine. But does not seem to accelerate at all after 20 mph, especially when I press on the gas pedal hard, but when I release the pedal and press it again then the it start picking some speed. However, the RPM is very high for that normal speed. I suspect the car doesnt changing gear. Please help me to fix this problem. Thank you very much!
Posted on: 2008/7/17 4:57
bogus Re: 96 Vette....NEED HELP!!!
are you getting any codes? Does the Service Engine Soon light come on?
Where are you located? Autozones will read engine codes for free. Just to make sure.
I wonder if you have a transmission problem brewing, tho...
Posted on: 2008/7/17 6:03
Matatk Re: 96 Vette....NEED HELP!!!
That's also a sign of a bad fuel filter or fuel delivery problems. Like Andy said, codes are the first place to check. We need a little more info to help give a better diagnosis.
Posted on: 2008/7/17 13:15
runner140 Re: 96 Vette....NEED HELP!!!
Ft. Lauderdale, Florida
721 Posts
I was thinking the same. Fuel filter/fuel pump.
Posted on: 2008/7/17 13:20
Mekanic Re: 96 Vette....NEED HELP!!!
Tampa Bay Florida
827 Posts
check fuel pressure.
But it sounds like a plugged cat to me.
Posted on: 2008/7/17 14:43
~Rich
Polo LT4
I was thinking plugged cat, but it wouldn't come back to life after a throttle stab.
Posted on: 2008/7/17 14:45
Tampa Bay Florida
827 Posts
ahh, touchet, I didn't read that part correctly. I thought he was saying stabbing it it fell on its face, then partial throttle it would accelerate.
Posted on: 2008/7/17 14:56
~Rich
Polo LT4
traiconghoa Re: 96 Vette....NEED HELP!!!
27 Posts
Dear Mekanic,
I will check the fuel pressure. But not sure of what you mean by plugged "cat" is it the catalytic converter? Im truly sorry for this question, since im not the mechanic and don't know much of mechanic's terminology. If it is, what is the best way to fix the plugged cat? Thank you very much
Posted on: 2008/7/17 21:01
CentralCoaster Re: 96 Vette....NEED HELP!!!
I don't know where you guys are going with these fuel ideas.
It sounds like the trans is slipping up to higher rpm, but when he backs off, it drops into the next gear, allowing him to finally pick up speed. My Ford did when the TV cable came unhooked.
TV cable adjustment?
Low tranny fluid?
Burnt clutches?
Posted on: 2008/7/17 21:07
27 Posts
Dear CentralCoaster,
What is the TV cable, where is it located and how to adjust it? Thank you very much
Posted on: 2008/7/17 21:22
1Fast04Vert Re: 96 Vette....NEED HELP!!!
You don't have one. Your trans is totally electronic controlled thru the PCM (under hood computer). Aamco advertises a free computer scan for problems, you might want to have them scan it for you. It does sound more like a tranny than an engine problem to me, but over the internet diagnostics are not often reliable.
Posted on: 2008/7/17 23:31
Yeah, just don't let Aamco work on it.
What inputs does the ECM use to control pressure in the trans?
Posted on: 2008/7/18 1:35
He doesn't have an ECM either, it is a PCM. I would not suggest Aamco as a repair point, but the free scan does not require any committments.
Now where is PeteK when we need him?
Posted on: 2008/7/18 13:05
Ahh... that changes everything.
Posted on: 2008/7/18 18:53
Randy93 Re: 96 Vette....NEED HELP!!!
Winter Park, Fl
51 Posts
No TV cable, his tranny is electronic. You have the same problems I did, go get a tranny guy to take a look at the car. Bet you have burnt clutch bands and check the fluid level.
Posted on: 2008/7/20 19:20
27 Posts
Dear Randy,
How much did it cost you to fix it? Since, I don't know much about car, can you tell me what did the mechanic did to your car. Thank you very much
Posted on: 2008/7/21 7:00
Winter Park, Fl
51 Posts
Mine was $1750 w/new 2300 T/C.
Posted on: 2008/7/21 21:19
