321 user(s) are online (252 user(s) are browsing Forums)
'W' Series:
5.7L 348ci - 1958 thru 1964
6.7L 409ci - 1961 thru 1965
7.0L 427ci (Z11...
anesthes Ever seen these weird long tubes??
Boston, MA
http://members.cisdi.com/~anesthes/wtf/
Thinking of buying them off a member, but he doesn't know who makes 'em or what the primary size is.. Anyone ever seen these before??
-- Joe
Posted on: 2008/8/7 1:45
jim420 Re: Ever seen these weird long tubes??
Ontario Canada
81 Posts
They look like the same headers i have old owner put em on i'll measure them out for you tomorrow and post the sizes no idea who makes em tho
Posted on: 2008/8/7 2:00
The Benevolent Stranger
Notorious Re: Ever seen these weird long tubes??
They look like LPEs. I believe these were available in stainless too, but these don't appear to be that. I'm pretty sure they have 1 3/4" pimaries but I can't say for sure. Both they and 1 5/8s may have been available. It likely was an LTx/L98 thing as far as primary size goes. I do know that it's been some time since LPE long tubes were available for C4s.
Posted on: 2008/8/7 2:02
I hate sporks...
anesthes Re: Ever seen these weird long tubes??
Boston, MA
Hi Jim,
Thanks for the offer to measure. That will help! Do you have angle plug heads?
If any one else has info on these headers i'd appreciate it..
-- Joe
Ontario Canada
81 Posts
anesthes wrote:
Hi Jim,
-- Joe
yeah i have angled plugs one thing i found when tearing motor down recently was that these headers were a right pain to get out I'm thinking of returning to ram horn style when i put the engine back in.
Posted on: 2008/8/7 2:07
tequilaboy Re: Ever seen these weird long tubes??
19 Posts
The tube configuration, air and egr fittings look like my LPE 1 5/8" long tubes.
These tubes are definitely larger than mine and the collectors also appear to be a bit different which makes sense given the larger tube diameter. My collectors step down from 3" to 2 1/2" for the LPE supplied slip fit y-pipe, intended for the L98 main cat.
Its hard to tell if these have the same step down 2 1/2" collector, since the slip fit y-pipe is in place, but its likely that they do.
I'd say that they appear to be old LPE 1 3/4" Long tubes.
Posted on: 2008/8/7 3:03
Ontario Canada
81 Posts
my apologizes i have been going crazy at work with no time to guru was out in shop today but became preoccupied with my own vette going to go out there tomorrow and will measure up headers and yeah they are the same just looked at pic again sorry for delay
Jimmy
Posted on: 2008/8/16 2:23
Matatk Re: Ever seen these weird long tubes??
So did you buy these or did you find something else?
Posted on: 2008/8/17 1:21
Schrade Re: Ever seen these weird long tubes??
-- Joe
AHHH Mr. Joe... I was finally able to drop the Pside cat pipe. Had not only to drop the Y-hanger, but also break the D-side cat-to-ex manifold joint. Whatapain.
Thanks...
ICC fault chase thread is now at DC. I'm believin' mice put the whammy on me there by chewin' wiring insulation under-dash.
The nightmare continues...
Posted on: 2008/8/18 5:00
Boston, MA
Bought some hooker 2051s. Sand blasted them, welded flowmaster ball+socket collectors, had them ceramic coated with the 2000f stuff, cut my Lt1 exhaust, welded the collectors and bolted it all in. Sounds pretty good.
For some reason I've gone from idling at 13hg to 11hg, so I did a compression test. 165-170 in every cylinder. So maybe I have a bad plug wire. Don't see how an exhaust change would LOWER my vac. Cam isn't that big.
-- Joe
Posted on: 2008/8/18 11:57
Boston, MA
Thanks...
Fun stuff. I have the LT1 cat back, and the offset oil filter adapter (nice part) but ditched the LT1 manifolds/cats. What a pain in the ass. Cost me like $200 to try something that didn't work.
Good luck on the wiring. I've had to replace a few stretches of wire on mine as well. I gotta rewire the HVAC eventually too.
-- Joe
Posted on: 2008/8/18 11:59
anesthes wrote:
Thanks...
-- Joe
There's a guy username zr1clone at corvetteforums.com (NOT CF) looking for lt1 exhaust parts for his l98...http://www.corvetteforums.com/m_56179/tm.htm
Posted on: 2008/8/18 14:15
