273 user(s) are online (203 user(s) are browsing Forums)
c4-zo7-91 rear sway bar fitting question/problem ??
312 Posts
hi guys,
you know how i fitted all new poly bushings to the rear and i couldnt get the rear to lower any more and we thought i might of made all the camber and trailing arm bolts too tight,which i checked and un dunn a little.
still no luck guys!!
the long spring bolts are wounded nut rite down to the bottom of the bolt.
im now thinking and wanted to know guys may be i fitted the 1991 26 mm diameter zo7 sway bar wrong ???
as in the sway bar might be on the wrong way up possibly ??
if so ,would this stop the rear suspnesion dropping down to the rite height ???
i have noticed in between the rear wheel i saw the sway bar hitting near some part of the body frame also??
also the sway bar brackets that bolts to the axle,i had them off also ,may be they are wrong way around ??
has any one got a picture on which way the sway bar should be fitted ??
or can it only be fitted on one way ???
any ideas guys please.
cheers
glen
Posted on: 2008/9/2 7:49
CentralCoaster Re: rear sway bar fitting question/problem ??
This kinda shows it.
Posted on: 2008/9/2 16:37
c4-zo7-91 Re: rear sway bar fitting question/problem ??
312 Posts
hi central coaster,
thanks for the pic mate!!
cheers
glen
Posted on: 2008/9/3 10:02
Slalom4me Re: rear sway bar fitting question/problem ??
Edmonton, AB
165 Posts
Has the rear spring been changed? If so, what spring
has been installed?
Posted on: 2008/9/3 16:45
312 Posts
g,day slalom4me,
how are ya!!
thanks for your reply and it was good to hear from ya!.
nah mate,same old zo7 spring not changed!!
cheers
glen
Posted on: 2008/9/3 19:34
Jeffvette Re: rear sway bar fitting question/problem ??
Glen, if you do have the sway bar mounted upside down, it will keep the rear end higher and no matter what you do, you won't be able to lower it.
Posted on: 2008/9/3 19:38
312 Posts
hi jeff,
how are ya mate!!!
good to hear from you mate.
ok then,looks like i fucked up hey,must of fitted it up side down the bloddy idoit i am!!!
i have will have a look,im sure now thats what iv done wrong with the help of you guys i will chane it around!!!!
so what do i need to do,turn it up side down or completly spin it around ??cheers
glen
Posted on: 2008/9/3 20:01
Edmonton, AB
165 Posts
See upper right corner of picture in post #2.
Install bar so that lever arms approach the rear spindles
in the fashion illustrated.
Posted on: 2008/9/3 21:13
Well, there's only two ways to install it, correctly, and backwards. So remove it and flip it the other way.
Posted on: 2008/9/3 21:17
312 Posts
hi guys,
ok thanks for your help!!
cheers
glen
Posted on: 2008/9/4 5:43
klkordzi Re: rear sway bar fitting question/problem ??
Pittsburgh, Penna
152 Posts
You're not alone. I read this thread as I had done the poly bushings and also installed coilovers all around. Went out and looked at how I re-installed the rear sway bar and sure enough there it was upside down.
Posted on: 2008/9/9 0:03
312 Posts
hi mate,thank god for that hey!!
im glad im not the only one that stuffed up,lol!!
cheers
glen
Posted on: 2008/9/9 8:46
BrianCunningham Re: rear sway bar fitting question/problem ??
Does this help?
Posted on: 2008/9/9 19:48
312 Posts
BrianCunningham wrote:
Does this help?
ahh thats it mate, thanks that will help alot!!
cheers brian
glen
Posted on: 2008/9/10 10:22
