JonnyAngle | Say I want 47psi... | ||
...of boost that is. No, just kidding. Say I want 47 psi for my fuel pressure...
When testing it: Do I have the FPR hose disconnected or connected? Do I have the car idling, or just in the run position? How long after I kill the motor should it hold this pressure? Thanks in advance. |
Posted on: 2008/9/9 20:41
When I die, I want to go peacefully like my Grandfather did, in his sleep -- not screaming, like the passengers in his car. |
bogus | Re: Say I want 47psi... | ||
The engine idling, with the vacuum hose off.
It should hold it for a good 15~20 minutes. I had a fuel pump problem a month ago, and it would hold 40 PSI for about 2 minutes, then drop off like a rock to 30. |
Posted on: 2008/9/9 20:53
Matatk | Re: Say I want 47psi... | ||
What do you need 47 psi for? Are you testing something or is it for mods?
Matthew |
Posted on: 2008/9/9 22:10
CentralCoaster | Re: Say I want 47psi... | ||
What year?
Fuel pressure on my 85 is less than 40 psi. |
Posted on: 2008/9/9 22:27
Schrade | Re: Say I want 47psi... | ||
Fuel pressure should be tested static (motor off, fuel rail primed), idle with vacuum on FPR, idle with vacuum off of FPR, and pedal down - gauge taped to windshield.
Entire article here: http://www.corvetteforums.com/m_37283/tm.htm |
Posted on: 2008/9/9 23:05
Mekanic | Re: Say I want 47psi... | ||
Correct. And you should have right around 43psi |
Posted on: 2008/9/10 0:41
JonnyAngle | Re: Say I want 47psi... | ||
according to tpis, that's what i should run at. (back of package on adjustable fuel pressure reg). Headers, and basically straight pipes are my performance mods. |
Posted on: 2008/9/10 0:43
You wont see any performance gains at all upping the fuel pressure, just a loss of mileage and possibly some codes
Posted on: 2008/9/10 0:52
I agree. I don't think with those mods you'll need to up your FP. From what I've read/been told, the computer can adjust for these type of mods without a problem.
Matthew |
Posted on: 2008/9/10 1:25
