319 user(s) are online (259 user(s) are browsing Forums)
'W' Series:
5.7L 348ci - 1958 thru 1964
6.7L 409ci - 1961 thru 1965
7.0L 427ci (Z11...
tjpreul plug wires
I have a '92 LT1. There are two plug wires with straight boots. Do they go to number 6,8 cylinders? The previous owner had a universal set put on, so I want to make sure this is correct.
Thanks, I know what sensor you mean. I changed #8 last night.
Posted on: 2008/9/16 18:21
Qack Re: plug wires
274 Posts
Yes -- and have tons of fun with #8.
Posted on: 2008/9/16 18:44
SpectatorRacing Re: plug wires
yes. They're intended to clear the water temp sensor in the block between 6 and 8.
Posted on: 2008/9/16 18:46
Schrade Re: plug wires
6 and 8 ain't so tough (although I had a miserable time with the 8 wire snappin' on - I had to slide the wire INTO the boot to get it close enough to the plug).
To get 6 and 8 on easy, I climbed over the motor from the drivers side, and sprawled over the plenum. You can then get both hands easily onto the plug boot, just like it's yer own pecker!!! (not as comfy tho')
Posted on: 2008/9/16 20:08
Qack Re: plug wires
274 Posts
I discovered the "climb over the motor" technique with them as well, although I still wouldn't classify that approach as easy -- still a bitch!
Posted on: 2008/9/16 21:16
BillH Re: plug wires
#8's not that hard. Stand in the wheel well, face away from the car, install it with your right hand.
Posted on: 2008/9/17 14:50
