Browsing this Thread:
2 Anonymous Users
BrianCunningham | My tuner's car | ||
http://forums.corvetteforum.com/c4-te ... 2196104-398-85-build.html
[QUOTE]SloRvette: Finally got a car put together for myself.:willy: [IMG]http://i102.photobucket.com/albums/m102/p8638/P1010044.jpg[/IMG] 12:1 4.040 bore GM 4 bolt 1 piece rear main seal truck block, Eagle 3.875" stroke crank, Eagle 6" rods, Ross pistons - Calico coatings turbo top, anti fricton sides, Canfield heads ported to 215 cc - intake flows 317 @ .700" lift, ported StealthRam - heads flowed the number with intake attached, injectors rolled over for direct port dry nitrous, custom plenum with Accufab Lightning Monblade throttlebody, solid roller cam 242/250 @ .050" .672" gross intake lift .688" gross exhaust lift, Comp solid roller lifters with high pressure roller oiling, custom 3" stainless exhaust, Hooker 2151 headers, FAST XFI, 60 lb injectors, Walbro 340 pump feeding Bosch 044 pump [IMG]http://i102.photobucket.com/albums/m102/p8638/P1010040.jpg[/IMG] [IMG]http://i102.photobucket.com/albums/m102/p8638/P1010042.jpg[/IMG][/QUOTE] |
Posted on: 2008/12/2 15:44
Schrade | Re: My tuner's car | ||
Pretty tight.
'Bout 600hp? |
Posted on: 2008/12/2 18:43
pr0zac | Re: My tuner's car | ||
that is about the same as my car but mine is hydraulic roller and only a 385.
Posted on: 2008/12/2 19:53
will he do obd2 lt1's if the person has the tuning program?
Posted on: 2008/12/2 19:55
BrianCunningham | Re: My tuner's car | ||
Yes!
New, old, he's pretty much done everything. |
Posted on: 2008/12/2 20:06
should i just pm him?
Posted on: 2008/12/2 20:25
Notorious | Re: My tuner's car | ||
I'll bet that mofo honks! Beautiful craftsmanship and I love the gold finish on the car too. That's one extremely nice C4.
Posted on: 2008/12/2 20:45
If your on the other forum. I PM'ed him about this thread. So, who knows he might sign up. |
Posted on: 2008/12/2 23:10
bobges | Re: My tuner's car | ||
Nice ride
Posted on: 2008/12/3 0:19
jsup | Re: My tuner's car | ||
I love the color...
Posted on: 2008/12/3 0:20
Update
EDIT more info Quote: SloRvette; |
Posted on: 2009/4/6 2:10
Epimax | Re: My tuner's car | ||
Very Nice!
Posted on: 2009/4/6 10:14
Matatk | Re: My tuner's car | ||
That car is a beast. A lot to handle, too.
Matthew |
Posted on: 2009/4/6 11:36
