207 user(s) are online (159 user(s) are browsing Forums)
1st Gear: 3.06
2nd Gear: 1.62
4th Gear: 0.70
Reverse: 2.29
CentralCoaster HOW TO: Repair defective ZF6 clutch slave cylinders.
Most/all of the ZF6 clutch slave cylinders produced over the past 5 years or so are defective from the factory. The seals are installed backwards which results in incomplete clutch disengagement, and leaks.
The photos below, starting top-left, show how it's repaired. Bottom-right is the seal installed correctly and waiting for reassembly.
You can potentially damage the seal during this repair. If it makes you uneasy, send it to ZFdoc.com, he'll do it for you for a nominal fee. The snap ring groove may tear it as you're pulling it out. It may be possible to deburr it first, although I didn't try.
The piston is very difficult to remove from the slave. I tapped it against a block of wood to get it most of the way out, then pulled it the rest of the way using some snap ring pliers to grip the cup of the piston.
DO NOT put any tools on the ID surface of the aluminum cylinder. This is a finely machined hydraulic surface and you don't want to scratch it.
jpg  zf6clutchslave.jpg (209.71 KB)
793_496040ef5411b.jpg 1289X1161 px
Posted on: 2008/1/14 3:15
ninetyfivevette RE:HOW TO: Repair defective ZF6 clutch slave cylinders.
Rhode Island
81 Posts
How do you remove the rubber boot "retainer"? Do you simply pry back the tabs?
Could you apply air pressure to the hydraulic port to force out the piston?
I remember this thread from CF, but I refuse to go back to see how it ended- is there any markings or something to differentiate slaves that have been assembled correctly? Or do they still come off the shelf backwards?
Posted on: 2008/1/14 6:27
cuisinartvette RE:HOW TO: Repair defective ZF6 clutch slave cylinders.
Id be curious to hear about throwing some air to pop it out, also.
Took my chances and didnt reverse the seal on the one I put in last year.
What about the clutch master, any problems there also?
Posted on: 2008/1/14 7:18
CentralCoaster RE:HOW TO: Repair defective ZF6 clutch slave cylinders.
That little star retainer ring popped out easily. It's there to hold the rubber boot in. You can use a screwdriver if you need to, it's a non critical surface. Air pressure should do the trick also. I had to really rock the piston back and forth while tugging on it, which can't be good for the seal.
I don't know how to differentiate defective vs. good, or if there is such a thing as a good part.
The defective seals may have been with just the DOM (drawn over mandrel) steel units. The bulkier cast aluminum(?) ones may not have this problem.
Posted on: 2008/1/14 16:55
j3studio RE:HOW TO: Repair defective ZF6 clutch slave cylinders.
Interesting ...
Scary ...
Nice job, CC!
Posted on: 2008/1/14 17:18
MyFatNutz RE:HOW TO: Repair defective ZF6 clutch slave cylinders.
7 Posts
This is HUGE! THe past 2 slave cylinders, as well as a MASTER cylinder HAD the seal on backwards. I printed the info from the post in the STALIN forums, as well as ZFDoc's site a few years ago and kept it in my helms factory service manual.
To switch the seal is nothing to fear, it's cake, just be careful with the seal.
ALL MASTER and SLAVE cylinders MUST BE CHECKED, do it once, do it right.
Great info, thx!
Posted on: 2008/1/15 16:18
95 Yellow FE1, Zf6 LT1-->LT4 Heads, CompCams 304, pro magnum RR; C5/Z06 calipers/brake conversion
TorchRedRob RE:HOW TO: Repair defective ZF6 clutch slave cylinders.
Suwanee, GA
16 Posts
yes- air will remove the piston easily.
I stuck my air nozzle into the fluid inlet (heh, heh. . .heh, heh) and just barely squeeed the trigger until the piston came out. Just make sure you hold a rag or something over the open end to catch the piston when it pops out.
Posted on: 2008/1/21 3:07
Rex_Ruby RE:HOW TO: Repair defective ZF6 clutch slave cylinders.
Philly Suburbs
180 Posts
That probelm is supossed to have been corrected and all defective stock removed, according to GM. Not sure I believe it. I was one of the first to experience slave failures due to the improperly installed seal. I think I went through 5 slaves before this information was found out. The current slave has been on over a year now (knocking on wood)!!
Posted on: 2008/1/22 4:49
jhammons01 Re: HOW TO: Repair defective ZF6 clutch slave cylinders.
CC, I have to tackle my Clutch MC this weekend. Am I affected by this? Should I be looking into taking apart the MC prior to installation?
Posted on: 2009/1/4 2:21
bogus Re: HOW TO: Repair defective ZF6 clutch slave cylinders.
20861 Posts
No. You have the earlier style hydraulics.
Posted on: 2009/1/4 3:13
TommyT-Bone Re: HOW TO: Repair defective ZF6 clutch slave cylinders.
33809 Posts
I had the 90 style slave and had it replaced with the 91 style slave with the bleeder fitting on top thinking I would escape the dreaded seal issue. Two years later my slave is leaking again. I fill it once a month. Screw it.
Posted on: 2009/1/4 7:26
Schrade Re: HOW TO: Repair defective ZF6 clutch slave cylinders.
Get some Trans-X.
I had a '89 T-Bird with hardening valve body seals (according to a Ford shop tech). He said get the stuff.
3 drive cycles later, PERFECT shifting!
Seems the stuff softens and swells rubber.
Posted on: 2009/1/4 13:53
CentralCoaster Re: HOW TO: Repair defective ZF6 clutch slave cylinders.
Ok, but that won't do anything for a hydraulic clutch.
Posted on: 2009/1/4 16:22
33809 Posts
Why would it take two years for the leaking to begin? Wouldn't a reversed seal present itself sooner?
Posted on: 2009/1/4 16:25
Hmmm...
Are the piston seals made of rubber?
Posted on: 2009/1/4 18:06
Cheaper durometers (rubber) have properties that are lacking. Buna or natural rubber etc.....it is like anything else, cheaper materials don't last as long as others.
Many are under the impression that Rubber seals are rubber seals........I once had a list of all the different types of Rubber......it listed something like 75 different durometers.
Posted on: 2009/1/4 18:43
Jagdpanzer Re: HOW TO: Repair defective ZF6 clutch slave cylinders.
Northern VA
12 Posts
Has anyone had any luck locating a source for a replacement piston seal?
Surely there has to be suitable one out there in the world of fluid power cylinder repair parts.
Posted on: 2009/1/4 21:12
20861 Posts
To the best of my knowledge, there isn't a rebuild kit for these hydraulics.
The fix is to simply reverse the existing seal.
As for "rubber." Most is a silica compound... hell, most car tires are more silica than rubber.
Posted on: 2009/1/4 21:24
Blade_1 wrote:
Hmmm...
The brake fluid keeps the rubber plenty soft. The clutch cylinders generally leak due to a scratched or corroded surface.
The ZF6 slaves failed due to the seal being installed backwards, allowing pressure to force fluid past it rather than cause it to expand and seal.
Posted on: 2009/1/5 2:40
