102 user(s) are online (46 user(s) are browsing Forums)
1st Gear: 2.52
2nd Gear: 1.52
- 13 Bolt ...
jhammons01 Tranny Noise (AKA when it rains it pours)
So, I'm driving along and everything is good...then a regular stop light turns green, I gas it a bit and hear something. I turn down the radio and start to hear what sounds like a loose washer on a spinning shaft....like a bearing going bad almost....but
...only in First and Third gear and only at the lower RPMs (yes it is an '84 4+3)
shit Gurus what does that sound like to you?
Posted on: 2009/1/19 23:37
pianoguy Re: Tranny Noise (AKA when it rains it pours)
Sounds like time to get one of those nice Tremec 5-speeds?
Posted on: 2009/1/20 1:16
bogus Re: Tranny Noise (AKA when it rains it pours)
I would agree. The 4+3 is best replaced with a T500...
the entire package is just sooo much nicer... The shifter is shorter and internal, much more modern.
You can always pickle the old 4+3 and OD unit incase it ever gets to the point where it matters.
It's a 6 hr job... R&R... tops...
Posted on: 2009/1/20 2:26
BrianCunningham Re: Tranny Noise (AKA when it rains it pours)
The T10 part is fine, it's the overdrive that has issues.
When's someone going to come out with a spool or something for that part?
Posted on: 2009/1/20 2:31
CentralCoaster Re: Tranny Noise (AKA when it rains it pours)
Yeah, and it only costs more than his car is worth.
John, does it still rattle with the clutch in? Under acceleration? Coasting? Feathering throttle?
Does overdrive effect it?
Posted on: 2009/1/20 3:10
cuisinartvette Re: Tranny Noise (AKA when it rains it pours)
[QUOTE]John, does it still rattle with the clutch in?[/QUOTE]
Ditto
Posted on: 2009/1/20 3:12
jhammons01 Re: Tranny Noise (AKA when it rains it pours)
Only under 25% acceleration. Heavy acceleration and the noise is not prevalent.
Not when the clutch is in...
Over drive was not used when I started hearing this
Posted on: 2009/1/20 4:50
Don't be so quick to say that... The T10, over time, becomes as big a problem as the OD unit.
They are ok boxes, but after 20+ years an a lot of miles, they get gnarly.
Kevin, bmwgsa and now John here have all had various degrees of problem with the box.
Posted on: 2009/1/20 5:24
Still cheaper than a car payment.
There is a fine line between value and worth...
Posted on: 2009/1/20 5:25
So basically only when there's slack in the drivetrain.
Under load in either power or coast tightens it up. Causes the helical gears to ride against their bearing surfaces. Causes the springs in the clutch hub to load up.
Hmmm. Just thinking out loud.
Makes me wonder how bad it'd sound on jackstands at idle...
Posted on: 2009/1/20 5:41
We're not sure about John's problems yet.
As for me, I chewed the dogs off 1st and 3rd gear because I went drag racing without enough clutch fluid. I don't fault the 4-speed for that. Although the rebuild kits for them appear to be crap. I think they're a great setup other than the sloppy shifter and poor control strategy used on the overdrive. And that by the time the overdrive weaknesses were addressed, their reputation was already unsalvageable.
Hell, I broke a ZF too. How many have done that?
Posted on: 2009/1/20 5:48
dan0617 Re: Tranny Noise (AKA when it rains it pours)
IF it did it in any gear with all other symptoms the same I'd say U-joint. I've had them act exactly like that, no noise while slowing down or accelerating hard, but noisy under light throttle. If it really is only 1st and 3rd then it must be a problem in the tranny.
Posted on: 2009/1/20 13:48
what is "chewing the Dogs off"? And if that is caused by too little clutch fluid, then wouldn't I have committed the same infraction due to my recent bout with the Clutch MC???
Posted on: 2009/1/20 14:55
I was thinking the exact same thing.
Posted on: 2009/1/20 15:28
which two gears go out when the O/D goes out? Reverse and 2nd?
Could this be a symptom of that about to occur?
Posted on: 2009/1/20 19:17
while searching around, I came across a description that was good.
This noise sounds sort of like a Dieseling or bad fuel knock along with that spinning sound of a bearing going out......whirrrr whirrr clatter clatter whirrrr clatter
But in on First and Third.
Posted on: 2009/1/20 19:33
Do you use the regular clutch when you it the OD button?
Posted on: 2009/1/20 20:05
Yeah, I always push in the clutch in and out of OD
Posted on: 2009/1/20 20:23
But that's wear issues more than design issues.
Posted on: 2009/1/20 20:35
John, low clutch fluid wears out the synchros prematurely. Keep going, and it chews the dogs up.
This should have no effect on the trans noise. It will leave you with some metallic gear oil and cause the trans to pop out of gear occasionally when decellerating at high RPMs. Fixing worn dogs requires, well, throwing the transmission away. I don't think this is your problem though.
Getting the car on jackstands and running it while crawling underneath should really exaggerate the clattering noise and allow you to pinpoint it.
I just hate tearing stuff apart without knowing for sure where the problem is. Once the trans is off the car you lose the ability to diagnose anything.
Posted on: 2009/1/21 1:56
What does the gear oil look like?
How much is in there?
When is the last time it was changed?
Any metal on the magnetic drain plug?
BTW, the common form of overdrive failure effects reverse gear only.
Posted on: 2009/1/21 1:59
Reverse is fine....and since I put the new Clutch MC on, the thing is really shifting smoothly....smoother than it ever did since I've owned it.
I'll drain the Gear Oil Tomorrow.
It sounds like you can get a rebuilt Super T-10 for around $500
Posted on: 2009/1/21 5:47
A nash version of it? They'd probably need yours.
I recall synchros plus bearings are about $200-$250. I'm having flashbacks already. Make it stop. I rebuilt mine a few times in a row due to some shims in the rebuild kit that weren't manufactured correctly. 2nd rebuild kit from a different source was the same way. I ended up paying another $100 to have this pos $2 shims machined down.
Posted on: 2009/1/21 20:26
I give up....it's not there today. No sounds at all.
Posted on: 2009/1/21 21:02
I lied, its back.
It has to get really warm. Say above 200° F
Posted on: 2009/1/21 22:54
So a lot was done to isolate this noise.
It is there when the OD is engaged but only in 3rd
It is there in Reverse, First and Third.
I can chug around the parking lot it it is loudest at low rpms.
It is not there when the clutch is in. Only after the car starts to roll forward.
I can shift from 1st to 3rd and keep the noise
I can start in 2nd and shift to 4th and it is not there.
I'm jacking it up to get the rear wheels off the ground. Then I'll let it roll and see if I can pin point it.
Another sound that kind of describes it is....it sounds like a pneumatic pump pumping air bubbles....sort of.
Posted on: 2009/1/21 22:59
Up on Jack stands. The noise is only there while in the Higher gears.
Not reverse, not 1st...barely in 2nd but in 3rd and 4th is is there.....
But to be honest, and when I can get someone else to sit in the car and rev the motor while in 4th and slightly holding the brake......I'm think it is the left rear Half shaft coming apart at the U-joints...the inner one to be exact.
I'm still confused why this noise is not there now and not there in 2nd and 4th while rolling down the road
Posted on: 2009/1/21 23:47
My 13 year old just came home........The inside of that half shaft is about to fling apart.
Posted on: 2009/1/21 23:54
Whoa, that was a most fortunate find!
Posted on: 2009/1/22 0:07
U-joint or rear end bearings?
Posted on: 2009/1/22 0:54
How can I tell? Rear end being the pumpkin??
I seem to see the u-joint bouncing up and down.....and I can grab the half shaft and slight move it back and forth and roll it just a bit without the rest of the drive train moving.
I sure hope this is the issue...I don't wanna deal with a crapped out tranny
Posted on: 2009/1/22 1:57
Does the shaft going into the pumpkin have any slop?
To check ujoint play I put my finger between the halfshaft and the yoke then put the ebrake on and car in neutral then rotate the driveshaft by hand back and forth. If the yoke and halfshaft move relative to each other, it's sloppy.
If its bad of course, replace all 6.
Posted on: 2009/1/22 2:09
^^We replaced two at your place. I only need the half shafts at this point.
I can see the Ujoint on the inside move....The half shaft moves and the yoke moves....but what it connects to (leading into the pumpkin) does not move at all.
Then I put it in fourth gear and ran it with the rear wheels off the ground. ~1200 RPMish. and that thing was just wobbling up and down pretty bad. I think I've isolated my vibration.
Posted on: 2009/1/22 2:18
great!!!!
Posted on: 2009/1/22 3:19
Schrade Re: Tranny Noise (AKA when it rains it pours)
Could be sympathetic vibration. Same as a loose heat shield vibrating at the exact same RPM in every gear. Has to do with 2 different masses (objects) being in-phase or out-of-phase at some point. It's a stretch, but possible.
Did you had the driveline disassembled before this started?
Posted on: 2009/1/22 3:22
^^not since about 18 months ago when we did the clutch.
But your explanation is similar to what I was thinking.
And get this, while it is up on jack stands, I can only get the noise to occur while the brake is lightly applied. So yeah, some sort of phase vibration thing occuring.
Posted on: 2009/1/22 3:27
So....NO.....the u-joints/rear wheel bearing didn't fix this issue at all.
The bearing that is going bad is clanking when the gear shift is in Neutral, First and Third. It is getting louder.
Posted on: 2009/3/1 20:24
