166 user(s) are online (140 user(s) are browsing Forums)
Sheet Molded Compound.
The onl...
« 1 (2) 3 »
Randyj75 Re: Air Flow Research (AFR) 195's VS Trick Flow Specialties (TFS) 195's - Test within
MD
129 Posts
What's up w/ this?
Third Gen.org
Posted on: 2009/3/15 15:30
Josh Re: Air Flow Research (AFR) 195's VS Trick Flow Specialties (TFS) 195's - Test within
Those are not the heads I am using. Those are street port heads, I'm using competition port heads for the test. The competition port heads are about ~$750 more than the street port heads.
Posted on: 2009/3/16 2:25
As far as updates, I've had strep throat for the last few days, so I didn't get much done. I did finally feel well enough to mess with the car a little tonight. I got the balancer and crank pulley on, and discovered that my stock pushrods are the correct length, which is great. I quit before adjusting the rockers, but hopefully I'll start to feel better soon. I was hoping to have the motor sealed up this weekend, but I just didn't feel up to it with the painful throat and all.
Posted on: 2009/3/16 5:41
rickreeves1 Re: Air Flow Research (AFR) 195's VS Trick Flow Specialties (TFS) 195's - Test within
New Orleans
96 Posts
I didnt read through entire post yet but have yall seen the new Trickflow 21 degree heads for the LT1?
http://www.corvette-guru.com/modules/ ... t_id=78591#forumpost78591
Posted on: 2009/3/17 16:26
Made some good progress tonight. Here's some pictures:
[IMG]http://i652.photobucket.com/albums/uu241/joshkinzey/DSCF0782.jpg[/IMG]
[IMG]http://i652.photobucket.com/albums/uu241/joshkinzey/DSCF0780.jpg[/IMG]
[IMG]http://i652.photobucket.com/albums/uu241/joshkinzey/DSCF0781.jpg[/IMG]
[IMG]http://i652.photobucket.com/albums/uu241/joshkinzey/DSCF0783.jpg[/IMG]
[IMG]http://i652.photobucket.com/albums/uu241/joshkinzey/DSCF0784.jpg[/IMG]
Posted on: 2009/3/18 5:16
I won't be able to work on the car again until this Sunday. My girl has been bugging me to go drag racing (what a problem, right) and I have to get her car up and rolling before this Saturday. She's got an 87 Buick Regal with a factory 3.8L turbo. Here's a video of her making a pass last July. She's the dark blue car, the white car is an NA Monte Carlo.
http://videos.streetfire.net/video/86 ... k-T-Type-boost_171735.htm
The 12.1 in the video is the fastest the car has gone. We're hoping to get it into the 11's this coming weekend, assuming I can get the charging/alternator problem solved before Saturday.
Posted on: 2009/3/18 5:19
dan0617 Re: Air Flow Research (AFR) 195's VS Trick Flow Specialties (TFS) 195's - Test within
Nice clean engine bay on your car. Looks great. I wish mine looked 1/2 that good. Every part and hose under my hood that is stock looks crummy, and I don't have the time or money to replace them all. How many miles are on your car? Looks very well maintained under there.
Posted on: 2009/3/18 13:58
81 or 82K I think right now.
Posted on: 2009/3/18 16:32
I got some flow numbers for my AFR heads today, from the same shop/bench that flowed my TFS heads.
Here's the numbers, the numbers on the far right are the difference between these and the TFS heads:
Intake:
.200 = 157 +17
.300 = 207 +7
.400 = 257 +12
.500 = 287 +13
.550 = 292 +12
.600 = 304 +22
Exhaust:
.200 = 127 +19
.300 = 178 +34
.400 = 210 +34
.500 = 229 +39
.600 = 236 +32
Posted on: 2009/3/25 21:59
88BlackZ51 Re: Air Flow Research (AFR) 195's VS Trick Flow Specialties (TFS) 195's - Test within
481 Posts
Anything new with the project?
Posted on: 2009/4/6 9:59
It would have fired up this weekend if I had the fuel lines. I should be able to get my new fuel lines made either today or tomorrow, so I expect it to take its first breath one evening this week.
Posted on: 2009/4/6 12:28
Took the car out for a drive this weekend. Everything seems pretty normal, no issues. I fought a fuel leak for the better part of a day, but other than that the fire up and maiden voyage was pretty uneventful.
I was able to put about 100 miles on it this weekend. I laid on the throttle some, and right now I think the car is probably capable of ~116-118 MPH trap speeds. I'm hoping to have it on the dyno for final tune this Thursday, and then head to the drag strip this Saturday.
Posted on: 2009/4/13 12:42
mseven Re: Air Flow Research (AFR) 195's VS Trick Flow Specialties (TFS) 195's - Test within
Motor City Madhouse
247 Posts
sounds good, better to be uneventfull and no big issues.
Posted on: 2009/4/13 13:09
CFI-EFI Re: Air Flow Research (AFR) 195's VS Trick Flow Specialties (TFS) 195's - Test within
Top of Utah
372 Posts
That sounds like good progress. RMR had it's season opening T&T circus last Saturday. You didn't miss a thing. Continued good luck with the comparo.
RACE ON!!!
Posted on: 2009/4/13 14:13
RMR has a nice drag strip, but it's so poorly managed that I'm suprised it's still open. If Larry Miller had done a drag stip along with the road course, I suspect RMR would be a thing of the past.
Thanks for the compliments, I'll be back later in the week with some more information.
Posted on: 2009/4/13 17:05
1989GTA Re: Air Flow Research (AFR) 195's VS Trick Flow Specialties (TFS) 195's - Test within
61 Posts
Good to hear that things are moving along nicely. Can't wait for the tests.
Posted on: 2009/4/14 2:28
Top of Utah
372 Posts
And speaking of poorly run, RMR just switched from NHRA to IHRA. They have lost their NASCAR affiliation, too. I don't think I'm alone in hoping and praying that MMP will put in a strip and sign up with NHRA. Years back, before MMP was started, I saw a plat map of the then future racing facility that included a drag strip on the plat. It is speculated that there is/was some sort of agreement between the Youngs and the Millers for only one drag strip in the area. You may not be aware, but Larry Miller died this winter. Come on MMP drag strip!
But I digress. Now back to your regularly scheduled head test.
RACE ON!!!
Posted on: 2009/4/14 14:23
Dyno session is confirmed for tomorrow. I should have some kind of news by tomorrow night.
Posted on: 2009/4/15 17:32
Unfortunately, I didn't get any dyno time this week. I did however get to the drag strip.
My best pass of the day was:
1.84
7.78 @ 92.38
11.98 @ 118.61
That was my only 11 second pass. I had a couple 12.2's, but just about every pass was 118 MPH.
All in all, I'm pretty happy with the car. I'm not too impressed with my ability to launch the car, but the engine performed well. 118 MPH right out of the box is about what I expected, and I think with some fine tuning and a few more miles on the motor it will see 120. If I could have driven the car well I think it would have have gone 11.6 or so today.
Posted on: 2009/4/19 0:56
61 Posts
Very good. The mph is the key. The dyno numbers will be interesting to see how they compare to the track times/mph.
Posted on: 2009/4/19 3:58
BeachBum Re: Air Flow Research (AFR) 195's VS Trick Flow Specialties (TFS) 195's - Test within
751 Posts
Hey, some results !! Pretty cool.
118 mph is pretty stout for 1st time out.... I suspect you could find a bit more with some time and tuning.
good luck
1.84
7.78 @ 92.38
11.98 @ 118.61
Posted on: 2009/5/9 4:03
Yeah, I need to get some more dyno time/track time with it. I really want to lay down what I feel are some honest numbers before I do the head swap.
I've been finding little issues here and there as I drive the car, so I'm slowly picking those off one at a time as I go. As soon as my money tree starts to sprout I'll hit the dyno and drag strip again.
Posted on: 2009/5/11 12:55
I managed to make the drag strip last night. This is the final step with the TFS heads, and I'm starting the AFR swap today.
Track was Rockingham, NC. Actual track elevation is 325, corrected DA was about 2000. My best pass of the day was as follows:
11:04 PM for those who want to look up exact weather conditions:
60- 1.814
330 - 5.176
1/8 - 7.885 @ 89.57
1000 - 10.193
1/4 - 12.115 @ 119.34
All in all, I'm pretty pleased with the car. The DA last time I was out with it was about 1200, and the best MPH the car managed last time out was 118, so it picked up 1 MPH in worse weather, so I'm pretty happy with that.
Some things to note:
My best pass prior to last night was a 11.98 @ 118. I didn't get in the 11's last night, but I went 119 MPH, in worse air.
My 11.98 @ 118 was with the exhaust cut-outs open, last night was through mufflers.
Last night I had a passenger all night, so the car was 150 lbs. heavier.
With no passenger, equal air, and the car un-corked I think it would have gone 120-121.
Anyway, I'm tearing the heads off the car tonight to start the AFR install.
Posted on: 2009/6/14 20:44
61 Posts
Hi Josh
Any progress reports with the AFR heads?
Posted on: 2009/7/2 1:44
Both AFR heads are bolted on and torqued down. I still need to hook everything back up, install the intake, headers, accessory bracket, etc...
I'm hoping to fire it this weekend.
Posted on: 2009/7/2 12:17
61 Posts
Thanks. I know a lot of us are looking forward to the results.
Posted on: 2009/7/2 18:33
Calm Re: Air Flow Research (AFR) 195's VS Trick Flow Specialties (TFS) 195's - Test within
Vancouver, Canada
608 Posts
Posted on: 2009/7/2 21:05
I have made plans to hit the drag strip on the 11th of July. I should have the car driveable again this weekend, hit the dyno during the week, and get the final numbers on the 11th.
Posted on: 2009/7/2 22:19
61 Posts
The DA propably will not be the best in July for the track. However with the corrections it won't make much difference on the dyno.
Posted on: 2009/7/3 0:42
Eh, there's really no other option, it's not like I can control the DA on race day or anything.
I always post here when I get a new best, so over the course of the coming fall/winter you'll see me posting new times (hopefully ).
Posted on: 2009/7/3 12:19
61 Posts
I understand but it is something to consider in an AB test. Depending it can make quite a difference.
Posted on: 2009/7/3 21:55
Yeah, I agree. I've done my best to post weather conditions are corrected elevation for each track trip so far.
Posted on: 2009/7/4 0:20
Steve40th Re: Air Flow Research (AFR) 195's VS Trick Flow Specialties (TFS) 195's - Test within
1114 Posts
This a good thread. Thanks
Posted on: 2009/7/14 7:03
Ko'u ohana aia ku'a ikaika
I'm anxious to see what you end up running for overall timing at WOT with the AFR heads. I'm only running 28 degrees. 30 or more and I get audible detonation (with the knock retard system disabled). I even had it coming down from that 1 to 1.5 degrees every 400 rpms below 4400 and I still get detonation. Have to start at 28 from 4400 up and bring it down from there as the rpms come down.
With my old stock bottom end, reworked 113 heads, (about 10.7 SCR), 224/230 cam, everything else the same, it liked 36 degrees, no detonation till 38. I had the 36 all in by 3200 rpms and it had no detonation.
I'm now running the AFR Eliminator street ports, shaved down to 60cc chambers, and a 383, giving me 11.5 SCR and 9.2 DCR, and I only run 28 degrees. I know that with these heads and a free flowing exhaust that not as much timing is needed, and with the higher compression timing needs reduced but I was surprised to be down 8 full degrees at WOT.
My 1 time at the track with the new setup was a 12.22, timing at 34 degrees overall and I thought I was being conservative. That was before the heads were shaved down to 60 cc chambers though. I still have a feeling I was detonating up top and didn't hear it. I can't hear it unless I'm driving between buildings or in an area where there are trees on both sides of the road. I can, however, see tiny black specs on the sparkplugs, and it pushes more oil out the breather when it is detonating. It feels more powerful now than it did when I ran the 12.22, especially up top. I wonder if it was firing while the piston was not quite to the top....
I'm betting that you will end up finding out that it will want about 3 to 6 less SA than the TFS heads,and will make more power with that much less timing. Time will tell....
Is it up and running yet?
Posted on: 2009/7/17 13:03
TonyMamo Re: Air Flow Research (AFR) 195's VS Trick Flow Specialties (TFS) 195's - Test within
54 Posts
Why did you get so aggressive with the static CR?
A 23' engine even with our heads wont tolerate as much as a Gen III which has a superior chamber/quench design. You might have made more power with less compression and more timing (closer to 11.0)....in fact likely the case. Most of the dyno testing I conduct seems to favor low/mid 30's for optimal ignition advance. I would be curious what your engine would make with 100 octane no lead mixed 50/50 and more timing added. I bet it would produce even better numbers in that configuration.
IMO, you simply have all the timing your engine will tolerate with the octane fuel your running.....not so much that you optimized your package at that little total timing. Once again, less compression and more timing would have likely produced better results and been alot safer. Knock/detonation over the long haul is certain to cause cracked ringlands or worse depending just how bad it gets/persists.
-Tony
Posted on: 2009/7/19 19:59
I ended up in VA/MD all week/weekend for work, so no the car is not up and running yet. It's really close though, another couple hours and it should be good to go.
Intake is on, all that is left is to install the distributor, spark plugs, wires, connect the wiring harness, etc...
I also need to do the oil pan gasket. It's leaking pretty badly.
I should be able to finish it during the evenings this week, assuming work lets me come back to NC.
Posted on: 2009/7/20 1:59
1114 Posts
Make sure you put dabs of RTV in the four corners of the oil pan gasket, even if it is a one-piece FelPro.
Good Luck
Posted on: 2009/7/20 2:11
-Tony
I upped the static CR to help eliminate some cam surge I get around 45 to 48 mph in 3rd with the converter locked up. It worked, it is all but gone now. No matter what I did with timing/fueling/etc. in the tune it wouldn't go away.
I ran at the track on motor only with your heads out of the box on this combo, which was a 10.7 SCR on my build. I ran a 12.22 @ 111 mph. That was on a 1.6 60' and 34 degrees of timing. I now ran after shaving the heads and going to colder spark plugs with a SCR of 11.4. I babied the launch since it was my first pass of the day. I ran a 12.32 @ 110.5, on a 1.7 60'. I'm sure if I launched the same it would have been a 12.20 or maybe high 12.1 @ 111 or so mph. This was with 28 degrees overall timing. Was also nearly 10 degrees hotter ambient temp the second time out. I really believe the higher compression and less timing is equal to or even a hair better than the lower compression and more timing, at least up to this point. 6 degrees less timing and only .1 slower in the 1/4 with a .1 slower 60' on that pass doesn't seem all that bad to me.
BTW, my mph's might seem slow n/a but this setup is more optimized for nitrous. On that 200 shot my 1/4 mile was 10.66 @ 131.08 and that was on the pass that melted my plugs, will likely be quicker when the plugs aren't turning into lava. Also, I'm at 3520 lb raceweight.
I really don't want to try racing fuel as this is a street weekend cruiser that I want to be able to run nearly as fast on the street as on the track. So far so good.
I have found I need really cold spark plugs to run my 200 shot, which is likely more like 200 at the wheels. I just installed Autolite AR3931's. NGK plugs heat range 8 (similar heat range to the AR 3934) just melted the ground straps during my 10.66 1/4 mile pass so I know they are too hot. My worry is that the combustion chamber temps are too hot even for the coldest possible plugs. Is that possible at this point? I wouldn't think that a 200 shot rated at the wheels and 11.4 SCR, 9.2 DCR would be too much heat, I've seen guys running more on higher compression and they are surviving, so I think I just need the colder plugs. What do you think??
I'm also considering a small water/meth injection system to help lower the cylinder temps when spraying and to up the octane rating. That would be a longer term plan though, I'm really hoping that all I need is the colder plugs right now.
The reason I pulled the heads and had a chance to shave them down was because I was stupid. I ran NGK heat range 5, or Champion RC12YC plugs, with a 175 shot. I melted them all, and melted the #7 cylinder exhaust valve and slightly damaged the seat. Local machine shop put in a new seat and valve and shaved the heads and put me back in business.
As a side note Tony, I couldn't be happier with these heads. The AFR 195 elims were for sure the right head choice for my build.
Posted on: 2009/7/20 2:43
54 Posts
I will have the second version of the Eliminators finished before the results are in.....LOL
Whats the latest Josh.....inquiring minds want to know!!
-Tony
Posted on: 2009/7/31 3:25
1114 Posts
Are you getting nervous Tony?
Seems like you are getting a little as you are questioning why things were done to his engine, DCR, for example, and this doesnt work well with your heads.
Your heads are definitely a far cry from my factory ported LT1's, thats for sure.
Posted on: 2009/7/31 5:12
The car started last night for the first time with the AFR heads on it.
I should have results from the dyno within 10 days. I could do it this weekend, but I'm out of town (again) for work.
Everyone hold their breath, lol.
Tony didn't question the DCR/SCR on my motor, he was asking about Dan's set up.
Posted on: 2009/7/31 14:07
1114 Posts
Cool, I guees I need to drink more coffee before reading/posting.
Posted on: 2009/7/31 16:08
54 Posts
Nope....
Just trying to figure out how expensive a cigar I want to purchase after getting the results....LOL
:thumbright:
Posted on: 2009/7/31 20:04
I'm back in town now, car should be done tomorrow or Wednesday. Looking for dyno and track numbers before weeks end.
Posted on: 2009/8/3 23:57
61 Posts
Sounds good. We are anxiously waiting.
Posted on: 2009/8/4 1:36
I dyno'd the car today with the AFR heads. It made 414 RWHP and 396 RWTQ. Here's the chart with the AFR heads in red and the TFS heads in blue:
The AFR heads made more power everywhere in the RPM band, and 25 more RWHP at peak. Draw your own conclusions as to the value of the heads, but I'm pretty pleased with the results.
I think we all thought the AFR heads would make more power, but here's the results. Same dyno, same car, as close as I could make the tests.
Tuning didn't change very much. The AFR heads seemed more tolerant of timing and fuel changes without swings in power. For example, I leaned it out all the way to 14.0 and didn't pick up any power. I also ran the timing all the way to 38 knock without knock, but it didn't make any more power there than it did at 32 degrees. Right now, it is about 13.5:1 (measured at the tail pipe) and 32 degrees of timing. There was less than 1 RWHP difference between this tune and 14.0:1 and 38 degrees of timing.
All in all, both heads performed admirably. The AFR is clearly the winner on power production, and with the cost of the mods to the TFS heads the AFR heads also won in the dollar per HP category.
Thanks for all the forum support.
Posted on: 2009/9/1 0:09
vettef6 Re: Air Flow Research (AFR) 195's VS Trick Flow Specialties (TFS) 195's - Test within
Germany
8 Posts
Would it be possible to post another picture showing AFR and RPM's, since they can't be seen???
Posted on: 2009/9/1 9:40
92 LT1, ZF 6 sp. 397ci, Ross pistons, heavily ported 210cc LT4 AFR heads, ported LT4 intake, 1.6 RR, SR 247/255 .664/.664 112°, 11.3:1 CR, 58mm TB, 36# injectors, Fidanza alum. fw, Hooker 1 3/4" lt headers, no cats, self made dual SS 3" exhaust, X-pi...
Weavsvet Re: Air Flow Research (AFR) 195's VS Trick Flow Specialties (TFS) 195's - Test within
446 Posts
I believe Photobucket is doing maintenance.
Posted on: 2009/9/1 9:58
I'll take another pic tonight where you can see the RPM. The right hand edge of the graph is 7,000. The vertical lines are 1000 RPM apart. I pulled the motor to about 6700 with the AFR heads, and 6,000 with the TFS heads.
Posted on: 2009/9/1 12:17
Germany
8 Posts
It 'll be interesting to see your AFR. I set mine to 13.0--13.2 and it runs very good. I take my reading off my WB, this should show slightly richer than in back at the tailpipe shouldn't it??
Posted on: 2009/9/1 13:01
« 1 (2) 3 »
