181 user(s) are online (140 user(s) are browsing Forums)
1st Gear: 2.74
2nd Gear: 1.57
4th Gear: 0.67
Reverse: 2.06
400hp427vette Any Repair issues going on?
Long Island, NY
373 Posts
Seems not to many posts in the C-3 tech but we all know these cars need constant repair. Anyone got anything going on that you would like to share? I'd like to hear and help too.
Posted on: 2009/4/29 3:12
Trae1976 Re: Any Repair issues going on?
Johnson City, TN
832 Posts
Not much for me right now - just collecting parts for winter projects.
I've currently got all the hardware to rebuild my headlight mechanisms. But while I'm at that, I'm going to attempt an electric actuator system, kinda like this one:
This is the ECPB System, which we spotted at the Corvette Expo last month. It worked really nicely, but its just a little too pricey for me. Pretty sure I can come up with something similar. :thumbleft:
Posted on: 2009/4/30 11:02
Matatk Re: Any Repair issues going on?
Do the headlights currently work on a vacuum system? That looks nice, but for a cool G I could think of some other items to spend it on.
Posted on: 2009/4/30 22:11
Durango_Boy Re: Any Repair issues going on?
I'm chasing signal problems when the headlights are on, and a host of weird symptoms on all fronts of signals and lights.
Heck, the headlight warning buzzer goes off when I press on the brake pedal when the IGN is off.
I have lots of body work to do when I can afford it, to get me ready for the new paint job sometime after the wedding.
I also need a cam to finish my roller 405, which will get installed with the TH2004R I already have.
Posted on: 2009/4/30 23:00
Johnson City, TN
832 Posts
Yes, they are vacuum operated, and I'm sure they worked fine when new. But after the rebuild I'm only creating about 12" of vacuum - significantly lower than stock. They are operational as-is, but could be much better.
:me2:
Posted on: 2009/5/1 11:45
All went well over the road trip to the Lake and back for the weekend. I lost a little over a quart of oil...most of which is stuck to the underside of the car...so I have to track down where it's coming from. Top all looks dry except around the plug at the back by the distributor. Should be an easy fix.
Posted on: 2009/5/4 23:41
john-roth Re: Any Repair issues going on?
Red Deer, AB, Canada
9 Posts
[quote]
I had the same issue, everything worked fine until the headlights were on. Turned out I had brown & yellow reversed at the front left signal light.
JR
Posted on: 2009/5/4 23:45
dstaley Re: Any Repair issues going on?
Peoria, IL
67 Posts
I'm going through my rear differential now. Apparently GM's design was a bit less than adequate, but thankfully Gary and Mike have figured out what it takes to patch them up. With their help I'll be back in the saddle, hopefully before the summer is over.
Posted on: 2009/5/7 2:57
Very cool - take lots of pics and post them up for future reference!
Posted on: 2009/5/7 13:10
Peoria, IL
67 Posts
I can do that. Here ya go!
New rear suspension resto-modification thread
Posted on: 2009/5/8 4:04
