167 user(s) are online (112 user(s) are browsing Forums)
The ...
BrianCunningham portable pooper saves pilot
http://www.avweb.com/eletter/archives ... ash/1367-full.html#200306
No Full Plane Parachute? No Problem
A Cessna 182 crashed Friday after departing Thun Field, Wash., when the aircraft reportedly lost power and the pilot tried to turn back for the runway -- a move that often puts pilots in a world of ... excrement. Things were no different in this case, but as fate would have it, that world may be exactly what saved the pilot from substantial injury. The aircraft fell short of the runway, clipped a fence and flipped upside-down into a stand of porta-potties. Fortunately for the pilot, the portable toilets had what it took to absorb or dissipate the remaining kinetic energy of the crash and the pilot "walked away apparently unhurt," according to the Associated Press. Fortunately for everyone else (including, we assume, the NTSB), the porta-potties were not deployed in service at the time, but were sitting idle and empty (we pray, of everything) in a storage yard.
A local Sheriff's spokesman said the aircraft had gained about 150 feet before the engine quit. Further details were not available at the time AVweb went to press and the pilot's identity was graciously not made available.
Posted on: 2009/5/5 19:51
Sweet90 Re: portable pooper saves pilot
Edmonton, Alberta
1143 Posts
Well that's sort of a shitty story Brian
Jim
Posted on: 2009/5/5 20:33
CSS996 Re: portable pooper saves pilot
Mega Guru
Central PA
3644 Posts
Divine intervention?
Holy shit!
Posted on: 2009/5/5 20:51
Currently "Between Vettes".
Dads90 Re: portable pooper saves pilot
Pearland, Tx
318 Posts
I bet he used one, after he climbed out of that plane.
Posted on: 2009/5/6 3:02
400hp427vette Re: portable pooper saves pilot
Long Island, NY
373 Posts
nothng like being in a world of shit both in the air and then back on the ground.
Posted on: 2009/5/6 3:13
CentralCoaster Re: portable pooper saves pilot
I bet he didn't lose power... he just couldn't hold pucker position for the remainder of the flight.
What do you do when you've got to pinch a loaf in a small airplane 15,000 feet over Dallas? Or do they all have bathrooms on board?
Posted on: 2009/5/6 4:49
Matatk Re: portable pooper saves pilot
22812 Posts
I think it was about 2 minutes too late for that.
:pottytrain4:
Posted on: 2009/5/6 11:28
Durango_Boy Re: portable pooper saves pilot
Posted on: 2009/5/6 12:45
