159 user(s) are online (128 user(s) are browsing Forums)
Very stout.
BrianCunningham Corvette ZR-2
No, that wasn't a typo, they actually made them
SilverDevil;
Sunday 5/31 was Metro Long Island Chapter Meet at Mack Pontiac/GMC. 18 cars were judged, 8 of them being C3's.
Here are pictures of the judged C3's:
I know what this plate meant. Yes, that's a ZR-2!
WOW some real nice stuff there
Posted on: 2009/6/5 17:24
Durango_Boy Re: Corvette ZR-2
There was a concept ZR-2 C4 I think, but I don't believe it ever made it to production.
Posted on: 2009/6/5 18:22
pianoguy Re: Corvette ZR-2
Sweet!
Posted on: 2009/6/5 18:39
CSS996 Re: Corvette ZR-2
Mega Guru
Central PA
3644 Posts
I've read several Corvette books, and never heard a mention of a ZR-2.
Posted on: 2009/6/5 18:47
Currently "Between Vettes".
Sweet90 Re: Corvette ZR-2
Edmonton, Alberta
1143 Posts
In 1971 there was only 10 or maybe 12 made. I also
thought there was a mock up or pre-production C4 ZR2, but I've been wrong before.
Jim
Posted on: 2009/6/5 19:38
BrianCunningham Re: Corvette ZR-2
The C4 ZR-2 was in the museum when I was there.
real cool seeing a rat motor in a C4
Posted on: 2009/6/5 21:04
FYI
http://auto.howstuffworks.com/1971-corvette.htm
The ZR1 option available exclusively with the LT1 is significant for engineering, though not many saw production. It was a special racing package that included the solid-lifter small-block engine, heavy-duty four-speed transmission, power brakes, aluminum radiator, and a revised suspension with special springs, shocks, stabilizer bar, and spindle-strut shafts. Since it was competition equipment, the ZR1 could not be ordered with power windows, power steering, air conditioning, a rear-window defogger, wheel covers, or a radio. But the ZR1 package was quite expensive, and few Corvettes were so equipped.
A similar ZR2 package was listed for the big LS6 engine and was just as rare. Per GM policy, 1971 Corvette engines were detuned to run on low-lead fuel -- save the LS6 454, which belatedly bowed with 425 bhp on premium gas. Installations totaled just 188, including a mere 12 cars with a $1,747 ZR2 package, basically the ZR1 with the big-block V-8. This would be the only year for both the LS6 engine and the associated ZR2 equipment.
Posted on: 2009/6/5 21:07
ghoffman Re: Corvette ZR-2
258 Posts
That is what they should of offered in leiu of the LT-5. An aluminum Rat weighs less and the power is essentially unlimited. I like my 427!!
Posted on: 2009/6/5 22:15
CentralCoaster Re: Corvette ZR-2
Posted on: 2009/6/6 1:49
Jeffvette Re: Corvette ZR-2
Except GM did not know how to build a motor. Hence Lotus.
Posted on: 2009/6/6 5:54
258 Posts
The big block made more power than the Lotus, and the new LS series all smoke the LT-5. Seems like they know very well how to make a motor. At a dyno day a couple of years ago, a stone stock LS7 made about 120 RWHP more than a chipped LT-5. Even back then, the LS6 454 crate motor made about 90 more HP than the LT5 and did not weigh any more. I just think Dave McClellan had a 4 cam and bad hair fetish.
Posted on: 2009/6/6 12:28
bogus Re: Corvette ZR-2
I think you nailed it. Dave beleived that for the C4 to go upmarket, it had to have a twin cam, multivalve V8.
It was the engine architecture that Ferrari, Porsche, Lambo, BMW and Mercedes had been using for years. Hense, the perception was that upmarket had to have those features.
An interesting side bar, the Rolls/Bentley V8 was a cribbing of the Packard V8 from the late 1950s... It was pushrod 2 valve. No one questioned that one, eh?
They brought Lotus in because they did have more experience in that arena. GM also owned Lotus at the time, so they might as well use the resource. So yes, GM DID develop the engine, if you want to get technical about it.
The bigblock would not work as a practical solution in the Vette. Weight wasn't the only issue, it was pure size. It is just such a tight fit and with space at such a premium, the air flow would have been affected. That's my thought at least. Besides, it was old school technology.
Think about it: If you wanted to attract the Ferrari/Porsche crowd to your car, which engine is going to do it better? A refined, powerful, high-tech V8 with twin cams and 32 valves, or, a big block, all iron, with pushrods and 16 valves, whose lineage goes back to 1964?
I spoke with Dave about this, and it is also in his book, but the LT5 was concieved to be THE engine in the C5. But the engine team at GM built the LS1 and the rest was history. That and the fact that the C5 was delay 3 years. It was lighter, it was amply powerful, significantly simpler and cheaper. When ODBII entered on the stage for 1996, they junked the LT5 and committed to the LS1. I would love to build a C5 with and LT5 in it, but the question I have is whether it would physically fit!
My bigger question is this: Why didn't they adapt the LT5 ignition system onto the LT1?
Posted on: 2009/6/6 17:16
Newer LS series can thank the LT5 program for the development.
As far as a LS6 454, It does not idle as nice, get the best gas mileage, nor would it be the best at beating the best the world had to offer back in 89.
Posted on: 2009/6/6 22:04
