179 user(s) are online (136 user(s) are browsing Forums)
Vettrock Wheels in the air...
Henderson Nv.
34 Posts
Post your pics of your wheels up. Here one of mine.
Doug.
Posted on: 2007/12/31 23:56
1987 Silver Couple, 9.95 @ 138 mph on the bottle. Too many mods to list.
1998 Red Convertible, my daily driver. Pure stock.
CasetheCorvetteman RE:Wheels in the air...
Posted on: 2008/1/1 2:07
CentralCoaster RE:Wheels in the air...
I saw that one coming.
Posted on: 2008/1/1 2:10
RollaMo-LT4 Re: Wheels in the air...
Trivia Winner
Rolla, Missouri
422 Posts
Doug.
That is an awesome shot !!
Posted on: 2008/1/1 2:11
It is mate yes, he obviously hooked up pretty well eh?
Posted on: 2008/1/1 2:39
Vettrock RE:Wheels in the air...
Henderson Nv.
34 Posts
Thanks guys, it does hook hard.
Hey Casethecorvetteman is that all the higher you can get?
Here's another one.
Posted on: 2008/1/1 2:44
HAHAHA!! No mate:
Posted on: 2008/1/1 3:08
Klaus RE:Wheels in the air...
Atlanta, GA
129 Posts
HAHAHA!! No mate:
Is that Mad Max's garage? Looks like you could be fixing the timing cover and welding on the bulldozer blade on that truck.
Posted on: 2008/1/1 3:25
2008 Machine Silver Coupe
LS3 / Z51 / A6 / NPP
HA! No mate, its a mate's big shed, i dont remember why the bonnet was up on the MAN that time, just checking of fluids and a general look around i think. Its a pretty reliable truck
Posted on: 2008/1/1 3:33
Henderson Nv.
34 Posts
You got me Casethecorvetteman.
Posted on: 2008/1/1 3:38
BrianCunningham RE:Wheels in the air...
Posted on: 2008/1/1 3:47
No worries mate, i liked your pics, it would take a fair bit of balls to drive any length with the front up so high you cant see anything
Posted on: 2008/1/1 3:51
Henderson Nv.
34 Posts
Going up is the easy part. It's the landing that hard.
Posted on: 2008/1/1 3:54
RollaMo-LT4 RE:Wheels in the air...
Trivia Winner
Rolla, Missouri
422 Posts
If you're still pulling enough torque, it should come down slower than it would normally by gravity. Although if you shift...
Some of the cars start making massive lift too when they're still pulling the tires at 50 mph, or more... :shaking:
Posted on: 2008/1/1 3:55
BTW I'll be dropping in a 700hp blower engine soon.
So, what the best thing to do if that happens?
Stay on it?
Lift gently, but not too fast?
I've got a stick, so I'm assuming I should keep it in gear and not shift until the nose comes back down.
Posted on: 2008/1/1 3:56
Henderson Nv.
34 Posts
I was lucky. Not to much damage. I've been told to shift gears. Of coarse I have automatic trans with manual valve body. Don't do what I did "LIFT". Next time I'll stay in it but I also put wheelie bars on to help out.
Posted on: 2008/1/1 4:01
Like with drinking mate, its the comming back down that always seems to hurt!!
Posted on: 2008/1/1 4:41
TommyT-Bone RE:Wheels in the air...
33776 Posts
I'm a sucker for wheelie shots. I can never get enough. Just like a few other things I can never get enough of.
Posted on: 2008/1/1 4:50
bogus RE:Wheels in the air...
two words: wheelie bar.
That is pretty bad ass, tho!!!
Posted on: 2008/1/1 5:21
brut RE:Wheels in the air...
New Albany, IN
1308 Posts
Vettrock...badazz ride bro!!!!
Posted on: 2008/1/1 7:50
Skidmarks RE:Wheels in the air...
Blue Mound, Illinois
98 Posts
Vettrock, I'm assuming your IRS has been replaced. Are you running a 9"? Also, did you install tubs in the rear wheel wells? Some pics would be cool if you have any.
Posted on: 2008/1/2 19:04
