114 user(s) are online (71 user(s) are browsing Forums)
1969 through 1976 Corvette.
rayosequis Dana 36 Pinion Seal
Cypress, Texas
5 Posts
I have a '94 LT1 with a D36 (2.59) that has a leaky pinion seal. I have had the seal changed three times and it's still leaking. Is there something other than the seal that would cause it to keep leaking ? After the car sits for a few days, it will leave a decent sized puddle on the ground.
Posted on: 2009/6/28 4:24
jhammons01 Re: Dana 36 Pinion Seal
I can go to Huntington Beach and ask that Differential expert if you don't get an answer....
Posted on: 2009/6/28 5:07
vetteoz Re: Dana 36 Pinion Seal
Is there any movement in the pinion?
If the bearings are bad the pinion could be running out of round opening up the seal.
Posted on: 2009/6/28 8:21
rayosequis Re: Dana 36 Pinion Seal
Cypress, Texas
5 Posts
Thanks for the replies. I don't know if there is any play in the bearing, but there really shouldn't be as it was replaced. I had bought the rear diff. with 40k on it to replace my 109k one and had it freshened up, the front bearing was apparently worn and was replaced. Unfortunately, the front pinion has leaked ever since and while the gentleman that worked on it has been very accomadating, I have contemplated tackling it myself.
It would seem to me that the next obvious thing to replace would be the pinion shaft itself as it could be grooved or worn, but I didn't want to play the throw parts at a problem game.
Thanks again,
Posted on: 2009/6/28 9:03
Ernie
crash Re: Dana 36 Pinion Seal
WRIGHT CITY MO 63390
977 Posts
i dont think that the pinion shaft would have a groove on it with only 40k on it. but if it does federal mogul or c&r bearing and seal anufacturers make a part called a speedi-sleeve. it slides over the shaft and makes a new surface for the seal to ride on.
also are they replacing the crush sleeve each time they take it apart.
Posted on: 2009/6/28 10:47
Matatk Re: Dana 36 Pinion Seal
I don't know the specs off hand, but have you measured anything to see is it is within tolerance and/or round and not ovaled, etc? Are there any hairline cracks in the case?
Posted on: 2009/6/28 13:41
Cypress, Texas
5 Posts
Well, I looked and made sure that there were not any hairline cracks, and the leak is very obviously coming from behind the dust shield. That was the bearing that was worn, so I had not thought of the possiblity of the pinion shaft being out of round. I will definetely look into this and will see about re-sleeving it or just replacing it if necessary. Thanks again for all of your help.
Posted on: 2009/6/29 3:38
Ernie
CFI-EFI Re: Dana 36 Pinion Seal
Top of Utah
372 Posts
The seal seals against the drive line yoke installed on the pinion, not the pinion (shaft?). The seal surface on the yoke could be worn or grooved as suggested or possibly the pinion nut wasn't properly tightened and the pinion is moving. Of course that would likely ruin the pinion bearings. There is a baffle or slinger on the pinion between the bearings and the yoke. If left out it would tend to over load the seal with grease to try to control.
RACE ON!!!
Posted on: 2009/6/29 14:35
anesthes Re: Dana 36 Pinion Seal
Boston, MA
Mine did the same thing. Changes the seal twice.
Luckily, Gm still stocks the yoke. Was $40 my cost. (shop price) at the time.
New yoke fixed it.
-- Joe
Posted on: 2009/6/29 18:16
Cypress, Texas
5 Posts
Thanks again, guys. The yoke is actually what I was referring to and I believe it may need replacement. All of your help is greatly appreciated, I'm tired of smelling burning diff. fluid, it stinks !
Posted on: 2009/6/29 18:31
Ernie
mikeV Re: Dana 36 Pinion Seal
Top of the world Ma
158 Posts
Probably the companion flange or "yoke" has a groove. Replace or repair with a sleeve. There is no crush collar in a Dana 36.Be sure to use a Viton seal. Federal #5778V
Posted on: 2009/6/29 19:59
