177 user(s) are online (111 user(s) are browsing Forums)
Moe_Vette Removin me 92's door panel
33 Posts
Dear all
I have a 92 vette and the passenger door panel has never sat quite right along the top of the door (it pulls away at the top from the main door behind it) I have had a poke around and nothing seems broken or cracked - I am just hoping the last guy put it on wrong.
So in my handy 101 projects for your corvette book I turned to page 180 which goes over removing the door panel (my logic being I remove it and then re-attach it properly - so it fits right at the top etc) also me trunk open button does not work on that side so hoped to trouble shoot that too.
Here not there I have followed the steps as best I can in the 101 projects but cant get the door off - I have removed the following screws
the 5 along the bottom
the 2 up the left side of the door
the 1 off the right side of the door (next to the trunk butt)
the 2 inside the hand grip well
the 1 behind the interior light
** the only one mentioned that I could not find was when you pop off the window switch there should be a screw there too (well I got it off but what in there looks like a rivet to me - there is no screw head of any kind nor would it fit a not (shape is a circle)
Is there supposed to be one there - could the last clown have riveted it in place?
It seems to me the thing keeping the door panel on is the door handle/lock mechanism - is still seems to be firmly attached
if any of you guys have gone through this on a late model c4 I would sure luv hearing what I am dealing with here
many thanks
Posted on: 2010/6/3 18:27
pianoguy Re: Removin me 92's door panel
On my '96 you have to pry the lock slider off and there is a screw behind it.
Also note that at least on my car, the screw from behind the light by the door handle is shorter than the others.
Posted on: 2010/6/3 18:49
1Fast04Vert Re: Removin me 92's door panel
And one behind the door handle (the inside handle of course). Easy to see without taking anything off.
Posted on: 2010/6/3 19:14
BillH Re: Removin me 92's door panel
Yea, like Brad said, you have to pop off the black plastic lock slider. Pry up the end with the point. It's attached to a round L shaped rod. There's a screw behind it. Betchya that's what's holding you up.
You can then remove the trim piece by pulling out the door handle.
I fairly sure I didn't remove the door lock on my 92, just unpluged the connector.
It's shown nicely in the FSM.
Posted on: 2010/6/3 19:20
Fluff Re: Removin me 92's door panel
Winchester UK & Alicante ES
247 Posts
I don't know the answer to removing the panel, but my passenger door panel is the same (feels loose and floppy).
I read sometime ago that there are moulded lugs/brackets on the inside of the door panel that break off and cause the problem.
There is a write up somewhere on the web, I can't find it at the moment, but it was written (I think) by one of the Corvette magazine that publish on-line articles.
Posted on: 2010/6/3 21:58
93 LT1 Coupe.
corvetteronw Re: Removin me 92's door panel
Lowell, MI
Posted on: 2010/6/4 17:40
BrianCunningham Re: Removin me 92's door panel
those hidden screws are a royal PITA
I realize the stylist didn't like seeing them
But there reaches a point of being ridiculous.
Posted on: 2010/6/4 18:47
bigmoe Re: Removin me 92's door panel
Manitoba
118 Posts
If this works here's a pic of the fix. I should add that after I took this pic I ground some of the top of the bracket because it was too high.
jpg  mini-100_0009.jpg (73.93 KB)
2352_4c0f0e3be5810.jpg 640X480 px
Posted on: 2010/6/9 3:44
