227 user(s) are online (187 user(s) are browsing Forums)
djxib My Blow Off Valve is bigger than yours
North Georgia
456 Posts
....just sayin'
jpg  BOV2.JPG (290.20 KB)
1691_4e764fb6680a1.jpg 765X1024 px
Posted on: 2011/9/18 20:08
Andy
BrianCunningham Re: My Blow Off Valve is bigger than yours
Are you running a MAF?
If not, how are you dealing with boost?
Stock computer?
Posted on: 2011/9/18 20:28
1Fast04Vert Re: My Blow Off Valve is bigger than yours
Sure looks pretty too. You are sure building an awesome vette.
Posted on: 2011/9/18 20:52
djxib Re: My Blow Off Valve is bigger than yours
North Georgia
456 Posts
Stock computer?
Hi Brian, 1992 is a speed density car so no MAF. I deal with boost in the PE vs. RPM tables. Kind of pluses and minuses on a 1992.
I'll probably upgrade to a FAST in the spring - all this constant driving/scanning and table adjustments are killing me!
Posted on: 2011/9/18 21:45
Andy
Yeah, knew about the speed density, just wondering if you put a later computer in.
FAST is a nice setup, just need to piggyback the old one in to keep the dash going.
worse things than driving a Corvette around
Looking forward to seeing what you make
Posted on: 2011/9/18 22:11
North Georgia
456 Posts
Thanks!
Posted on: 2011/9/19 1:38
Andy
Matatk Re: My Blow Off Valve is bigger than yours
Out of my league...but wow!
Posted on: 2011/9/19 2:05
mistaben Re: My Blow Off Valve is bigger than yours
141 Posts
Stock computer?
/knowthatfeelbro - lol
anyways.... i thought the 92 was an LT1/MAF w/ a SD back up in case of MAF failure? or was that the 94?
and btw, your engine looks gorgeous!
Posted on: 2011/9/19 4:00
AKS_Racing Re: My Blow Off Valve is bigger than yours
62 Posts
I'll probably upgrade to a FAST in the spring - all this constant driving/scanning and table adjustments are killing me!all this constant driving/scanning and table adjustments are killing me!
You will be making adjustments with the FAST as well, just easier to adjust. And MUCH more functionality.
Posted on: 2011/10/1 3:17
Miss Nasty: Bigger SBC with C4SP and just shy of 30 psi boost. Low 9.0s with low 160+MPH with a decent 60' (1.72 is decent for me these days). :thumbleft:
