185 user(s) are online (160 user(s) are browsing Forums)
Print in friendly format Send this term to a friend  Ruby
Refers to 1993 Anniversary Editions.
These are the actual cars honored as anniversary cars. They have RPO Z25 to prove it....
captmike13 Dead alternator
Hillsboro Mo
2165 Posts
Ok guys as mentioned in the daily chat my alternator died on the way home from work.
I'm not getting the auto zone replacement.
I was thinking of getting a replacement from rock auto.
Matt suggested the CS144.
Question is where would I get one?
Other suggestions are welcome.
For those to lazy to read signature car is an 85.
Posted on: 2012/3/8 3:37
13 GMC 3500 dually
captmike13@yahoo.com
TommyT-Bone Re: Dead alternator
I'm in the local starter, alternator, generator repair shop crowd. Probably a quick turn around there and you know everything fits because it's yours.
Posted on: 2012/3/8 3:43
Ft Wayne Starter &... - Info
local.yahoo.com
(260) 484-4707 - 2624 Goshen Rd, Fort Wayne, IN..2A & J Alternators &... - Info
local.yahoo.com
(260) 495-1655 - 1188 E State Road 120, Fremont, IN..3Quality Auto & Truck... - Info
local.yahoo.com
(260) 244-7777 - 405 E Chicago St, Columbia City, IN..4Huntington Alternator &... - Info
local.yahoo.com
(260) 356-1469 - 1205 Gardendale Ave, Huntington, IN..5Elkhart Starter &... - Info
local.yahoo.com
(574) 293-2196 - 929 S Main St, Elkhart, IN.
Posted on: 2012/3/8 3:45
marv02 Re: Dead alternator
California City Ca
130 Posts
I using NAPA parts Alt, A/C compressor ect so far all of them have worked great for me.
I know some others thta have tryed Auto Zone and most of them have said dont you be changing them out alot.
Posted on: 2012/3/8 3:56
captmike13 Re: Dead alternator
Hillsboro Mo
2165 Posts
Thanks for the head start on the research Tommy.
I will check into some other local places.
Posted on: 2012/3/8 11:18
13 GMC 3500 dually
Matatk Re: Dead alternator
For the easiest route, napa or a rebuilder that is local to you. The CS144 can be found online or at the parts store, and requires minor modifications (measuring and filing) od the case and bracket.
Posted on: 2012/3/8 19:17
jhammons01 Re: Dead alternator
Would you want an GM replacement?
Posted on: 2012/3/8 22:55
bogus Re: Dead alternator
Check with K&B. They sell GM/ACDelco/Delphi parts. All new. All to OEM standard (whatever the hell that really means).
I would suspect a fresh OEM alternator will do all you need. The 1985 wasn't filled with as much computer power as the later cars, so it's kinda lost on them.
I put a 144 on my 92, and can't complain, but for me, it's an easy swap.
You can look at Powermaster, but they are EXPENSIVE.
Posted on: 2012/3/8 23:21
Hillsboro Mo
2165 Posts
GM replacement would be nice but not required. The stock one is only 108 amps. The replacements I've seen are 120 amps which should be more than adequate. I don't have window shattering stereo.
Posted on: 2012/3/9 1:01
13 GMC 3500 dually
Hillsboro Mo
2165 Posts
Update. Ordered replacement parts from our registered vender Rock Auto. Parts should be here this week. Putting on new belt, plugs and alt.
Posted on: 2012/3/11 16:27
13 GMC 3500 dually
Glad to hear it! Do you have a serpentine belt tool? If not, I highly recommend having that - you can rent it from AZ or buy one for $20 at HF.
Posted on: 2012/3/11 16:40
Hillsboro Mo
2165 Posts
Thanks for the info Matt. No I don't last time I needed to remove the belt I used a socket I believe
Posted on: 2012/3/11 20:04
13 GMC 3500 dually
First time I did my alternator I used a socket adapter and vise-grips. Not the best method, but works in a pinch.
http://www.harborfreight.com/serpentine-belt-tool-kit-66344.html
Posted on: 2012/3/12 1:25
BillH Re: Dead alternator
I made my own, took about 10 minutes.
Posted on: 2012/3/12 2:27
Doesn't a 1/2 breaker bar fit right in the hole?
Posted on: 2012/3/12 16:10
No, not on the later cars. It's a 16mm nut.
Posted on: 2012/3/12 17:19
It is a 1/2" square head in the tensioner on the L98s at least. But the serpentine belt tool has an adjustable end that lets you get in there better without hitting the other pulleys and is much easier to use.
Posted on: 2012/3/12 17:58
Or 5/8ths
Posted on: 2012/3/12 18:13
BillH wrote:
Or 5/8ths
Not SAE or metric...they're Whitworth
Posted on: 2012/3/12 18:19
Matatk wrote:
BillH wrote:
Or 5/8ths
I remember that store - J.C. Whitworth.
Posted on: 2012/3/12 18:24
When you need cash now...
Posted on: 2012/3/12 18:36
BillH wrote:
Matatk wrote:
BillH wrote:
Or 5/8ths
I thought he was J.C., superstar?
Posted on: 2012/3/12 18:37
That's JG Wentworth. Good job, Andy. Way to go putting a technical thread way off topic from the original intended purpose. I hope Mike isn't mad at you
Posted on: 2012/3/12 18:39
