Dads90 | Simple timing question | ||
Is retarding the timing moving it closer to Zero ? Or is it the opposite ?
Posted on: 2008/2/16 22:16
1990 Silver Blue Metallic, ZF6, Hurst shifter, Z51, Dana 44 3.33 ratio, FX3 system, mostly stock. |
Notorious | RE:Simple timing question | ||
Advanced is moving beyond zero and retarding timing is moving it back toward zero, yes.
Posted on: 2008/2/16 22:18
Dads90 | RE:Simple timing question | ||
Thanks Notorius, I've put in a chip and it says to retard timing if a knock becomes present, of course it does. I didn't want get the present setting screwed before I start.
Posted on: 2008/2/16 22:30
RRTvette | RE:Simple timing question | ||
Advanced is moving beyond zero and retarding timing is moving it back toward zero, yes. |
Posted on: 2008/2/17 2:57
MK 82 | Re: Simple timing question | ||
Is retarding the timing moving it closer to Zero ? Or is it the opposite ? |
Posted on: 2008/2/17 3:01
96 CE Roadster LT4 |
CasetheCorvetteman | Re: Simple timing question | ||
Depends on which side you start off on! My thoughts too as soon as i read it!! |
Posted on: 2008/2/17 8:07
MK 82 | RE:Simple timing question | ||
Great minds think alike!
Posted on: 2008/2/17 14:47
fnsblum | RE:Simple timing question | ||
I never owned a car/truck that fired after top dead center. All were several degrees before TDC. If you are retarding the timing you are removing some of the degrees before TDC. Later! Frank
Posted on: 2008/2/17 20:46
93 Red LT-1 Bought in Nov. First mod is a set of Magnaflows. |
Thanks guys , its done. I knew the setting was at 6 * BTDC. I have adjusted it many times, but never knew the terminology of retard and advance. I feel like a retard sometimes when I go thru so much with this car and it still acts up.
Posted on: 2008/2/18 2:25
