259 user(s) are online (195 user(s) are browsing Forums)
1st Gear: 1.76/1.82
2nd Gear: 1.00
- 14 Bolt Pan.
- Vac...
vetteblondie Just found out (finally)
Jonesboro, AR
4657 Posts
Will be putting on my 4th opti......
Wet, nasty, broke all that crap
Parts got here Saturday. I so far like this new mechanic, he's been up front with me and is actually getting into it and finding things that need addressed and is more than willing to show me what he finds and explains things.
He tried to look for other things before getting into that. Gets me in there and points it all out to me.... makes me feel a lot better about him working on it. Hell I ought to have a new car almost. I've done a ton of crap to it. Little Heffa has new tires, new rack, new shocks, new alternator, water pump, fuel pump, brake booster, heater core, pke unit, ignition control module, 02 sensor, 02 sensor wiring harness, opti wiring harness and soon new opti. A dang teenager would be cheaper.....
And, Little Miss better not show her butt when she comes back home. Got new headlight bushings, spoiler and lugnut covers (thanks Casey) waiting on her when she gets home!
(Along with a date with the soap and water bucket)
Posted on: 2008/3/17 18:45
�Ugol's Law
MAXXWRENCH Re: Just found out (finally)
COLORADO
118 Posts
MEANS A LOT & GOES A LONG WAY WHEN YA CAN GET A MECHANIC THAT ACTUALLY SHOES & EXPLAINS EVERYTHING TO YOU....THAT IS WHAT WE DO HERE...THAT WAY THE CUSTOMER KNOW WHY WE ARE DOING WE ARE.
Posted on: 2008/3/17 19:39
ONE SHOT, ONE KILL, I WIN
kentucky_vetter Re: Just found out (finally)
somerset, ky
154 Posts
Sounds like you finally found a good mechanic. Dont let him get away !
Posted on: 2008/3/17 19:41
LD85 Re: Just found out (finally)
Indianapolis, Indiana
784 Posts
man the Opti must really suck..
Posted on: 2008/3/18 17:28
2005/Z51
FLYINLOW90 Re: Just found out (finally)
Windsor Ontario Canada
514 Posts
Wow you really have been through that thing haven't you???
Gary
Posted on: 2008/3/18 19:09
Notorious Re: Just found out (finally)
As a mechanic, I'm always more than willing to explain everything about a job to the customer, what I recommend doing about it and etc., for those who care to listen. And the machinist I use is the same way with me, explaining everything he does to the last detail. That's why I continue to use him. That of course and the fact that his work is always flawless.
I don't BS anyone, no need to in a properly run shop with competent help. I've always had customers loyal to me wherever I've worked. And as also the shop supervisor in this new job, this is indeed a well run shop where things are done my way.
Posted on: 2008/3/18 23:16
I hate sporks...
red_johnny Re: Just found out (finally)
Bravo and hats off to you! Its really hard to find a honest AND good mechanic. I had mechanics who were crooks but were good and I had ones that were very honest but sucked. I have yet to find one that is both.
Posted on: 2008/3/19 1:40
vetteblondie Re: Just found out (finally)
Jonesboro, AR
4657 Posts
He even got the car back in for one more last go around and recheck, found a screwed up vacuum line from pcv, fixed it, I paid him in cash for all the work, (quite a long list) so he knocked a small tad off the bill.... Car is home as of an hour ago, ran fine getting here. But, given all my issues, LOL I'm scared to get too far out in the thing. Did manage to get those lugnut covers on though. Gonna drive it for a while and see how it goes. Thanks all of you for your support and kind shoulders offered to catch my whining!!!
Posted on: 2008/3/19 22:50
�Ugol's Law
Oaklands Re: Just found out (finally)
Morristown, TN
480 Posts
Congrats. I am glad to hear you got a good mechanic who could fix your problems. It has been a long road for you. Now, go drive it and enjoy it.
Posted on: 2008/3/19 23:21
Jonesboro, AR
4657 Posts
Drove it like I stole it! Seems ok, runs great, but something with that front end just quite isn't right yet, tho. Feel (and hear) strange things from the driver's side. Feel it in my left foot when it's on the floorboard while I'm driving, slight pulling sometime, and sounds like gravel or something up there, kinda like it did before the new rack assembly. But, the man at the front end place gave me a year to bring it back. Will call him first thing in the morning. But, after $2000 the rest of it seems ok for the moment!
Posted on: 2008/3/20 3:44
�Ugol's Law
jhammons01 Re: Just found out (finally)
I like to call what you describe as the "it is what it is" attitude. There is no reason to BS. Cars break, Honda has spent millions trying to stop them from "Breaking" yet they continue to break.
You sit back and explain to the customer..."It is broken and here is why and how" You're business can't help but grow.
I do the same thing....just with defense contractors....."It is what it is" and trying to make it into something that "It isn't" is just hurting everyone involved.
Posted on: 2008/3/20 16:45
Morristown, TN
480 Posts
Let us know what the front end man says.
Posted on: 2008/3/21 3:08
93Moneypit Re: Just found out (finally)
Santa Cruz Ca
38 Posts
If it sounds like gravel in the front end or it shimmy's when breaking it probably the front wheel bearings.
Sounds like you have a good mechanic there it will all be worth it when it done hang in there.
Posted on: 2008/3/21 9:19
CasetheCorvetteman Re: Just found out (finally)
No, that is a common misconseption, they are exceptionally good, especially the environment in which they operate. Im yet to have to replace mine.
Posted on: 2008/3/23 9:20
biggrizzly Re: Just found out (finally)
I agree with Case - Mine had a !50k miles on it when I pulled it and was still working great. However, when I removed it, I was surprised it was still working when I saw the crap that had found a home on it, and in it.
I got a new MSD unit now, so we will see if it lasts as long as the original did.
Posted on: 2008/3/23 14:47
Jonesboro, AR
4657 Posts
Front end man said it was a pin or bolt gone from the caliper on driver's side, and then car died again - hell. That so far has turned out to be a Coolant Temp Sensor. We'll see - geez, you guys almost need to make me my own complaint/soap opera/saga-drama room for this thing :thumbright:
Posted on: 2008/3/24 19:27
�Ugol's Law
Morristown, TN
480 Posts
You are going to have a fine rebuilt automobile when you get done. Man oh man!!
Posted on: 2008/3/24 23:40
Jonesboro, AR
4657 Posts
Lets hope its all better after all this....
Posted on: 2008/3/24 23:42
�Ugol's Law
