brian | seafoam | ||
anyone no where to get it and how to use it?
Posted on: 2008/3/25 16:45
DaleD | Re: seafoam | ||
The guru has come of age. Seafoam is here.
Autozone sells it. Pour 1/2 or even a whole can in the gas tank after filling. You can also get a hose, and suck 1/2 can into the intake through a vacuum. You have to be careful not to let it go to fast or you'll hydrolock the car. |
Posted on: 2008/3/25 16:56
Whenever someone says "I'm not book smart, but I'm street smart", all I hear is "I'm not real smart, but I'm imaginary smart". |
brian | Re: seafoam | ||
ok so put it in my gas tank? then i just rev the car up?
Posted on: 2008/3/25 17:28
Just like any additive. Put it in the tank and drive the car normally.
When you're sucking it into the intake, that's when you rev it. And make sure you don't do it too fast. |
Posted on: 2008/3/25 17:39
k sounds good thanks for the advice.
Posted on: 2008/3/25 17:41
pappyfreebird | Re: seafoam | ||
any parts house...ol beer bottles n fill em...shtuff couple ol rags in tops n yer ready fer fire
Posted on: 2008/3/25 17:43
NEVRL8T | Re: seafoam | ||
It can mist an 02 sensor on an LT1 if you suck it up through the intake and may or may not throw a code.
Posted on: 2008/3/25 17:44
mojo92 | Re: seafoam | ||
seafoam in the red and white can that is for bad gas, put a hold can in, it will take awhile maybe the whole tank of gas for it to work right. Seafoam dries up the water in the gas but it's not a over night thing. When my car started running fun I had a full tank of gas and I put 2 cans of seafoam in. We have a really big problem with the gas stations puttong gas in to make it last aliddle longer.
Posted on: 2008/3/25 23:24
Dads90 | Re: seafoam | ||
Just pour it into the brake booster vacuum hose and it sucks it straight into the plenum, might kill multec injectors though. Did mine. Ran great for a week and then it
Posted on: 2008/3/26 3:22
1990 Silver Blue Metallic, ZF6, Hurst shifter, Z51, Dana 44 3.33 ratio, FX3 system, mostly stock. |
Ramrod | Re: seafoam | ||
WOAH!!! Wait a minute. It may not have anything to do with it but I put a can of Foam in my tank. Few days later I had to change my fuel filter????? Coincidence? maybe yes maybe no. The sock on the fuel pump was also plugged so much it was sucked up into the pump???
Posted on: 2008/3/26 4:55
1996 LT-1 DynaSpark Opti, Tapered Rear Wheel Bearings, SS Brake Lines, Speed Bleeders, MC Bias Spring, Hawk HPS Pads, MSD Wires,NGK Iridium, lowered, etc. |
runner140 | Re: seafoam | ||
Love the "stuff". Driving 20000 miles a year, I use it one or two times a year.(the above instructions for use are correct)
Also use it in my power generator. (hurricanes/loss of electricity) |
Posted on: 2008/3/26 11:44
96, white and a ton of miles. Somewhat stock. |
Anyone want to talk about 160 vs 180 thermostats? Just kidding.
Posted on: 2008/3/26 11:46
LD85 | Re: seafoam | ||
I used it on all of my high mileage engines, I just poured a can in the tank with tank 3/4 full or so, drive it out, rinse lather, repeat
Posted on: 2008/3/27 11:24
2005/Z51 |
