299 user(s) are online (236 user(s) are browsing Forums)
Mizzou89 89 LT1 won't stay running
1 Posts
I have an 89 with minimal actual miles. I took out for a spin a couple of weeks ago. Took it to the store, when I came back it would not start. Checked battery, Fuel pump, plugs all the usual suspects. Had it towed to repair shop. They ran diagnosis and changed out two injectors, computer and new jet chip. Seemed to run fine, until they test drove and it stopped running after 15 minutes. They tried to restart and it would not. They ran additional diagnosis and could not diagnosis any problems. After it sits for 15-20 minutes it will restart and run for 15 minutes then die and not restart. Disconnecting the battery and re connecting will reset and get it start after 20 minutes or so, but then same thing. Any ideas? thanks!!!
Posted on: 2008/8/7 2:16
Mekanic Re: 89 LT1 won't stay running
Tampa Bay Florida
827 Posts
sounds like the coil to me since its heat related, but I've never heard of an 89 LT1
Posted on: 2008/8/7 2:20
~Rich
Polo LT4
FATED Re: 89 LT1 won't stay running
Texas
157 Posts
I have read about this problem on other forums and it was often blamed on the Theft Deterrent System. On mine the horn honks and the car will not start unless both doors are locked and then unlocked with the key. Maybe latter years it shuts down. I don't know and maybe everything I've heard, read, and said is B.S..
Oh, by the way I agree with the coil as a possible problem and it would not have been an injector.
Posted on: 2008/8/7 2:55
cuisinartvette Re: 89 LT1 won't stay running
Sounds like a fuel pump on its way out.
Posted on: 2008/8/7 4:16
bogus Re: 89 LT1 won't stay running
hm. throw parts at it until something sticks.
I am with cuisinartvette... fuel pump or filter.
Posted on: 2008/8/7 6:07
NEVRL8T Re: 89 LT1 won't stay running
Little Rock, AR
74 Posts
Its not VATS if it will run for 15 minutes and die.
Posted on: 2008/8/7 19:52
CentralCoaster Re: 89 LT1 won't stay running
or fuel related either for that matter. I would suspect it's ignition related from heat. Bad ignition modules and coils can test fine at room temperature though unfortunately, which makes diagnosis difficult. I had a car with this condition, I let it sit with a timing light hooked up and noticed it cut out shortly before the engine would die.
I'm curious how they came to blame two injectors and the ECM. I see countless shops replace the ECM just because they can't pull a monkey code from it to tell them what to bill you for.
What does the shop have to say for themselves for wasting a couple hundred bucks of yours on their misdiagnosis?
If they were medical doctors, by now you'd have a colostomy bag and a replacement hip to treat your ear infection.
Posted on: 2008/8/11 20:11
BTW, did you typo and your car actually has a 92-96, or do you actually have a TPI? Or was an LT1 swap done at some point? 89s all came with L98s (TPI) with the 8 runner tubes.
Posted on: 2008/8/11 20:13
italian1969 Re: 89 LT1 won't stay running
7 Posts
cant find out why it starts but dies after a while like it has no fuel. replaced feulpump and pressure reg. didnt fix it. the odomiter is showing the word volt. what is this problem
Posted on: 2011/9/4 18:24
dead/dying battery or bad alternator.
Posted on: 2011/9/4 18:45
Ultraman Re: 89 LT1 won't stay running
14760 Posts
Fuel filter?
Not so much with the word "VOLT" appearing in the speedo area.
Italian - what year, mileage, options and mods?
Posted on: 2011/9/4 18:52
7 Posts
all stock. relaced fuelpump, fuelpressur reg. dis coil and ign mod today and new batt, got it started idled fine but dies again after 15 min. is it the optispark. havent touched the fuel filter looks new. got car 8 months ago with 118,000 miles. even had all new vacume lines replaced.im going on 4 days of my summer car sitting. agravated.1996
Posted on: 2011/9/5 19:07
1Fast04Vert Re: 89 LT1 won't stay running
Where are you? And what year and engine Corvette are you having these problems with? Have you scanned it for codes?
Posted on: 2011/9/5 19:14
bam Re: 89 LT1 won't stay running
missouri
250 Posts
My 93 LT1 did the same thing, start fine, run about 15 min then die, not start until engine cool, is that similar to what you are experiencing? For mine it was the connector to the coil module. I touched and wiggled it while the engine was running, it would die instantly. I opened the connector and bent the pins slightly and it was fixed. Might try that, nothing to lose. Also wiggle other connectors in the engine bay, it may be another one, but I would bet it's the coil or module connector. Good luck.
Posted on: 2011/9/5 22:12
